MIPSPro (IRIX IDO 5.0-5.1.1) Test Compilation
Daneguy
Unread postby Daneguy » Sat Mar 31, 2018 10:25 am
We're trying to track down the MIPSPro version used to compile Super Mario 64 (in an attempt to recreate the source). After testing a few versions we've narrowed it down to the versions used in IRIX IDO 5.0-5.1.1, but these have been rare to come across. If anyone has any of these versions and would be willing to compile a test file to help us confirm the version, you'd be amazing!
If you're willing to help, we just need these compiled with O0, O1, O2, and to get the .o files (or dissasembled objdump).
cc -c test.c -o test.o -O0
test.c
extern void func_80279650(int, int);
void func_80279700(int var)
    int i;
    for(i = 0; i < 15; i++)
        func_80279650(var, i);
Thanks again guys!
Re: MIPSPro (IRIX IDO 5.0-5.1.1) Test Compilation
Unread postby Raion-Fox » Sat Mar 31, 2018 2:27 pm
That's amazing dude.
I am probably posting from yangxiaolong, HP Z230 with Xeon E3-1245v3, 16GB RAM, GeForce 750ti, and running Xen on NetBSD dom0 with FreeBSD and Windows 8.1 Embedded.
Daneguy
Unread postby Daneguy » Thu Apr 05, 2018 4:09 pm
Follow up: we were able to test 5.1 versions (no luck), but still trying to look for 5.0 versions which are likely to be buggy enough to match the behavior we've seen in the disassembly. Any leads to that would be fantastic!
