Darktable
JacquesT
Darktable
Unread postby JacquesT » Thu Dec 21, 2017 12:39 pm
http://www.darktable.org
Knowing next to nothing of compilers / dependancies etc, what is the chance of getting the source for Darktable compiled on Irix? I suspect too many GTK funky goodness??
Just a wild thought...
Re: Darktable
Unread postby foetz » Thu Dec 21, 2017 2:19 pm
they seems to require gtk3 which afaik wasn't successful on irix so far
necron2600
Re: Darktable
Unread postby necron2600 » Thu Dec 21, 2017 7:00 pm
2.0 and newer releases need gkt3, but earlier did not.
However, all releases prior fail very quickly to build due to:
Glib version check failed. Version 2.28.8 was found, at least version 2.30 is required
I tested all darktable versions way back till 1.4. Our Nekoware glib version is still at 2.28.8. (Unless we have some new Beta versions of glib around?)
Not sure if its possible to hack the build scripts to force it to compile with our 2.28.8 version... or what consequences could come from that within darktable (if it even compiles at all).
Re: Darktable
Unread postby foetz » Thu Dec 21, 2017 9:04 pm
necron2600 wrote:Not sure if its possible to hack the build scripts to force it to compile with our 2.28.8 version
of course it is. as you said, they're just scripts
that's simple, if they use stuff that 2.28.8 doesn't have it won't work. the second, rather unlikely problem could be that stuff which both gtk versions in question have changed in 2.30 which might lead to funny results :P
in both cases the solution would be to check the affected functions and look for alternatives.
Re: Darktable
Unread postby vishnu » Fri Dec 22, 2017 10:54 am
If we got 2.28.8 to compile it can't be that insurmountable to get 2.30 to compile, I'll take a look at it this weekend...
JacquesT
Re: Darktable
Unread postby JacquesT » Fri Dec 22, 2017 1:21 pm
Thanks all, appreciated!
