xu4 (Ultima IV) for IRIX (mips4 + gcc3)
necron2600
Unread postby necron2600 » Tue Dec 05, 2017 2:15 pm
XU4:
"xu4 is an open source project focused on the playability of Ultima IV on modern systems. Their engine uses the original data files from the game. The engine's primary goal is to recreate the original Ultima IV with 100% accuracy while also providing many optional bonus features to improve the enjoyment of the game."
I compiled xu4-1.0beta3 for IRIX 6.5 (mips4) with GCC3 (in hindsight I probably should have checked out its source to get most up-to-date than the last release). This may be a candidate for mips3 compilation...
Just untar the usrlocal.tar while in /usr/ as root. It will extract a local dir. Ensure your PATH and LD_LIBRARYN32_PATH are already setup to use /usr/local/bin and /usr/local/lib. You can then run 'u4' in a directory that contains these files:
ultima4.zip
u4upgrad.zip
Ultima 4 is freeware as it says here:
http://www.ultima-universe.com/maineng.htm
Get the online manual and details from that website.
I will attach those zips to this thread just in case ultima-universe.com dissappears one day.
I only tested this quickly.. aside from some main menu display weirdness (which you are still able to navigate).. once playing it seemed ok.
If your sound comes out static.. ensure you do not have SDL_AUDIODRIVER environment variable set.
usrlocal.tar
XU4 Ultima IV mips4+gcc3
(2.96 MiB) Downloaded 15 times
ultima4.zip
Ultima4 game freeware
(516.77 KiB) Downloaded 14 times
u4upgrad.zip
Ultima4 game freeware upgrade.. gives music and VGA,etc..
(617.26 KiB) Downloaded 15 times
Original source + IRIX patch:
xu4-1.0beta3.tar.gz
XU4 Ultima IV original source code
(408.69 KiB) Downloaded 15 times
patch.txt
IRIX patch to source code
(5.52 KiB) Downloaded 16 times
I plan to create a tardist eventually.. once things with xu4 are tested out.
Re: xu4 (Ultima IV) for IRIX (mips4 + gcc3)
Unread postby Raion-Fox » Tue Dec 05, 2017 5:41 pm
Awesome. You should setup a paypal for this so we can tip you - if you build more stuff for IRIX and other OSes on here it would be awesome. We need more guys like you.
necron2600
Unread postby necron2600 » Tue Dec 05, 2017 5:55 pm
Just standing on the shoulders of giants. As you well know, many others here build and maintain the foundation of everything nekoware that allows little apps like xu4 to be ported to IRIX ;)
Unread postby Raion-Fox » Tue Dec 05, 2017 6:58 pm
I think every developer for hobbyist platforms (yeah I think by and large the commercial usage of IRIX is essentially dead besides perhaps the Cray X1E) should keep a donation jar of sorts open. I would tip the developers of apps I use and apps that also contribute to the ecosystem profoundly.
Hakimoto
Unread postby Hakimoto » Wed Dec 06, 2017 1:53 am
Very nice work! I fondly remember playing Ultima IV way back when! Good stuff!
grace, elegance and style.
necron2600
Unread postby necron2600 » Wed Mar 07, 2018 10:54 am
MIPS3 compile for those with MIPS3-based Indys and Indigo2s (compiled on an Indy with 6.5.22 and nekoware/mips3)
While it does work, it did seem sluggish and did core dump eventually when i was moving around the map. I did not investigate any further yet.
xu4-mips3-usrlocal.tar
XU4 Ultima IV mips3+gcc3
(4.62 MiB) Downloaded 12 times
