MPlayer won't compile
praetor242
Unread postby praetor242 » Fri Oct 27, 2017 3:40 pm
I'm trying to compile the latest MPlayer, and I had it compiled, and then I got a new hard drive from Raion-Fox, and now it won't compile. I can't remember what I did last time and I'm at a loss
I have SDL installed from Nekoware, and all the little hacks I had to do last time, but it says:
error: implicit declaration of function 'XShmGetEventBase'
I can't remember how I got past this :(
Ideas?
Re: MPlayer won't compile
Unread postby foetz » Fri Oct 27, 2017 6:55 pm
check where XShmGetEventBase is defined and add that header as an include to the file that caused the error
Unread postby Raion-Fox » Fri Oct 27, 2017 8:53 pm
Aww dude I appreciate you telling everyone where you got the drive from but you make it sound like I'M THE PROBLEM....
Just kidding. Thanks for the poke.
praetor242
Unread postby praetor242 » Sat Oct 28, 2017 7:43 am
Aww, raion-fox :3 Gotta pimp out my favorite SGI crack dealer! But it is kinda your fault. I had a really nice install on that other drive, and you had to ruin that by selling me a bigger, better drive :p
Foetz, I'll try adding those headers and report back. Thanks! :D
Unread postby Trippynet » Sat Oct 28, 2017 8:06 am
You could have used xfsdump to mirror your data/OS across to the bigger drive, that's what I did when I replaced the HDD in my Fuel with a bigger one last year :)
praetor242
Unread postby praetor242 » Sat Oct 28, 2017 4:19 pm
Ohhhhhhh suuuuuuureeeee.....now you tell me :p
foetz wrote:check where XShmGetEventBase is defined and add that header as an include to the file that caused the error
I tried that to no avail. It still gives the same error. I wish I could remember what I did. I'll have to take this to the mplayer devs me thinks.
Reason: merged
Unread postby foetz » Sat Oct 28, 2017 6:44 pm
praetor242 wrote:I tried that to no avail. It still gives the same error.
then you didn't include the right one.
alternatively you could add the prototype manually to the top of the file in question.
can you give me a link to the version you're trying to build and also the name of the source file that causes the error?
praetor242
Unread postby praetor242 » Sat Oct 28, 2017 6:49 pm
It's the mplayer from their SVN repository.
svn checkout svn://svn.mplayerhq.hu/mplayer/trunk mplayer
Here's the error:
libvo/vo_x11.c: In function 'getMyXImage':
libvo/vo_x11.c:144:9: error: implicit declaration of function 'XShmGetEventBase' [-Werror=implicit-function-declaration]
libvo/vo_x11.c: In function 'draw_slice':
libvo/vo_x11.c:501:5: warning: passing argument 2 of 'sws_scale' from incompatible pointer type [enabled by default]
In file included from libvo/vo_x11.c:59:0:
ffmpeg/libswscale/swscale.h:217:5: note: expected 'const uint8_t * const*' but argument is of type 'uint8_t **'
cc1: some warnings being treated as errors
gmake: *** [libvo/vo_x11.o] Error 1
Unread postby foetz » Sat Oct 28, 2017 7:08 pm
vo_x11.c, around line 125, change it to this:
static XVisualInfo vinfo;
int XShmGetEventBase(Display *);
static void getMyXImage(void)
praetor242
Unread postby praetor242 » Sat Oct 28, 2017 7:14 pm
Nope. That just made it super angry.
libvo/vo_x11.c:131:5: warning: no previous prototype for 'XShmEventBase' [-Wmissing-prototypes]
libvo/vo_x11.c: In function 'XShmEventBase':
libvo/vo_x11.c:134:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:224:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:255:1: error: parameter 'fmt2Xfmt' is initialized
libvo/vo_x11.c:256:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:256:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:256:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:256:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:257:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:257:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:257:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:257:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:258:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:258:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:258:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:258:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:259:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:259:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:259:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:259:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:260:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:260:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:260:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:260:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:261:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:261:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:261:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:261:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:262:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:262:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:262:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:262:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:263:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:263:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:263:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:263:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:264:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:264:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:264:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:264:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:265:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:265:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:265:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:265:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:266:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:266:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:266:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:266:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:267:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:267:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:267:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:267:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:268:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:268:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:268:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:268:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:269:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:269:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:269:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:269:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:270:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:270:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:270:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:270:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:271:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:271:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:271:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:271:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:272:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:272:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:272:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:272:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:273:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:273:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:273:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:273:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:274:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:274:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:274:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:274:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:275:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:275:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:275:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:275:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:276:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:276:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:276:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:276:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:277:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:277:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:277:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:277:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:278:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:278:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:278:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:278:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:279:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:279:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:279:3: warning: initialization makes pointer from integer without a cast [enabled by default]
libvo/vo_x11.c:279:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:280:3: warning: braces around scalar initializer [enabled by default]
libvo/vo_x11.c:280:3: warning: (near initialization for 'fmt2Xfmt') [enabled by default]
libvo/vo_x11.c:280:3: warning: excess elements in scalar initializer [enabled by default]
libvo/vo_x11.c:286:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:414:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:446:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:452:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:459:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:507:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:533:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:568:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:585:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:598:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
libvo/vo_x11.c:131:5: error: old-style parameter declarations in prototyped function definition
libvo/vo_x11.c:131:1: error: parameter name omitted
libvo/vo_x11.c:633:1: error: expected '{' at end of input
In file included from libvo/vo_x11.c:26:0:
libvo/vo_x11.c: At top level:
libvo/video_out_internal.h:31:12: warning: 'control' used but never defined [enabled by default]
libvo/video_out_internal.h:32:12: warning: 'config' used but never defined [enabled by default]
libvo/video_out_internal.h:43:12: warning: 'draw_slice' used but never defined [enabled by default]
libvo/video_out_internal.h:45:13: warning: 'draw_osd' used but never defined [enabled by default]
libvo/video_out_internal.h:46:13: warning: 'flip_page' used but never defined [enabled by default]
libvo/video_out_internal.h:48:13: warning: 'uninit' used but never defined [enabled by default]
libvo/video_out_internal.h:50:12: warning: 'preinit' used but never defined [enabled by default]
libvo/video_out_internal.h:49:12: warning: 'query_format' declared 'static' but never defined [-Wunused-function]
libvo/vo_x11.c:49:12: warning: 'Shmem_Flag' defined but not used [-Wunused-variable]
libvo/vo_x11.c:52:24: warning: 'Shminfo' defined but not used [-Wunused-variable]
libvo/vo_x11.c:53:12: warning: 'gXErrorFlag' defined but not used [-Wunused-variable]
libvo/vo_x11.c:54:12: warning: 'CompletionType' defined but not used [-Wunused-variable]
libvo/vo_x11.c:81:23: warning: 'ImageDataOrig' defined but not used [-Wunused-variable]
libvo/vo_x11.c:85:12: warning: 'depth' defined but not used [-Wunused-variable]
libvo/vo_x11.c:85:19: warning: 'bpp' defined but not used [-Wunused-variable]
libvo/vo_x11.c:86:26: warning: 'attribs' defined but not used [-Wunused-variable]
libvo/vo_x11.c:90:12: warning: 'Flip_Flag' defined but not used [-Wunused-variable]
libvo/vo_x11.c:91:12: warning: 'zoomFlag' defined but not used [-Wunused-variable]
libvo/vo_x11.c:95:17: warning: 'image_height' defined but not used [-Wunused-variable]
libvo/vo_x11.c:96:17: warning: 'in_format' defined but not used [-Wunused-variable]
libvo/vo_x11.c:98:12: warning: 'out_offset' defined but not used [-Wunused-variable]
libvo/vo_x11.c:99:12: warning: 'srcW' defined but not used [-Wunused-variable]
libvo/vo_x11.c:100:12: warning: 'srcH' defined but not used [-Wunused-variable]
libvo/vo_x11.c:102:12: warning: 'old_vo_dwidth' defined but not used [-Wunused-variable]
libvo/vo_x11.c:103:12: warning: 'old_vo_dheight' defined but not used [-Wunused-variable]
libvo/vo_x11.c:118:13: warning: 'draw_alpha' defined but not used [-Wunused-function]
libvo/vo_x11.c:127:27: warning: 'swsContext' defined but not used [-Wunused-variable]
libvo/vo_x11.c:128:12: warning: 'dst_width' defined but not used [-Wunused-variable]
libvo/vo_x11.c:130:20: warning: 'vinfo' defined but not used [-Wunused-variable]
libvo/vo_x11.c:633:1: warning: control reaches end of non-void function [-Wreturn-type]
Unread postby foetz » Sat Oct 28, 2017 7:27 pm
please try this file
vo_x11.c.bz2
(5.11 KiB) Downloaded 5 times
praetor242
Unread postby praetor242 » Sat Oct 28, 2017 7:53 pm
And that seemed to have done the trick. I really need to go back and relearn C. I used to be good at it, but if you don't use it you loose it :\
Unread postby foetz » Sat Oct 28, 2017 9:17 pm
sure, refreshing the basics never hurts :-)
praetor242
Unread postby praetor242 » Sun Oct 29, 2017 11:40 am
Okay, so from here, it should compile as expected (thanks to foetz's patch). So I'm going to just do a stock compilation, and then go back and apply IRIX optimizations to it. Hamel mailed me this morning saying there were a bunch of patches applied that really makes MPlayer performant on IRIX. Then I'll build a package to share.
Jack Luminous
Unread postby Jack Luminous » Tue Oct 31, 2017 8:21 am
Great news ! Eager to try the thing ! BTW, I was slightly disappointed the other day. I found the right cable to connect my Octane2 (2x600Mhz) to my new LCD and immediately proceeded to test some videos. I hadn't realized that mplayer on a dual 600 machine wasn't able to play 720p videos. Max is 480. I'm pretty sure that there's enough computing power in there to take care of that. Maybe current nekochan mplayer doesn't use both processors or isn't properly optimized for SGI. :cry:
