OpenSSL / OpenSSH for mips3
Fleeno
Unread postby Fleeno » Thu Dec 29, 2016 7:52 am
I've been trying to install OpenSSL and OpenSSH on a mips3 machine and have run into some issues with what I've found in Nekoware.
If I try to use SSL and SSH from mips3/current, I get this:
OpenSSL version mismatch. Built against 9070bf, you have 90807f
I tried to use the versions from mips3/beta, but that OpenSSH is actually for mips4:
[IRIS]:/usr/nekoware/sbin $ file sshd
sshd: ELF N32 MSB mips-4 dynamic executable MIPS - version 1
Does anyone know if the correct versions are out there somewhere? Thanks!
:O2: :O2: :O2: :1600SW: :Octane: :Indy: :BA123:
Re: OpenSSL / OpenSSH for mips3
Unread postby dexter1 » Thu Dec 29, 2016 4:24 pm
Packaging a recent openSSL/SSH for mips3 and mips4 is high on my to-do list, but i'm currently tied up in gemrb development.
There are some package inconsistencies in current nekoware directories, apologies for that.
You can get an openssl/openssh from recent IRIX media: version 6.5.22m has openSSH 3.6.1p2 with openSSL 0.9.7d
Make sure you are running an R4400 CPU: the R4000 rev 2.2 has a few processor bugs which renders your machine useless when installing the most recent openssl/ssh from IRIX media (they didn't test that :roll:)
Unread postby foetz » Fri Dec 30, 2016 3:42 am
i made a standalone package for you. it contains openssl 1.0.2f, zlib 1.2.8 and openssh 7.4p1. just throw the mips3 folder into /usr/local and adjust your environment variables.
http://r-a-c.de/dist/sgi/6.5/openssh_74 ... ne.tar.bz2
Fleeno
Unread postby Fleeno » Fri Dec 30, 2016 2:26 pm
Thanks so much, I'll try it this weekend!
And I have a super advanced R4600, so hopefully I'm good!
Fleeno
Unread postby Fleeno » Wed Jan 11, 2017 6:14 pm
I finally got around to trying this, but for some reason I can't get it to work:
[IRIS]:~ $ ssh
-bash: /usr/local/bin/ssh: Bad request code
The included openssl binary does run, however!
Unread postby foetz » Thu Jan 12, 2017 7:02 am
Fleeno wrote:[IRIS]:~ $ ssh
which is why i said:
foetz wrote:adjust your environment variables.
Fleeno
Unread postby Fleeno » Thu Jan 12, 2017 9:58 am
Which environment variables do I need to adjust? I updated my path, and library search path, but is there anything else?
Unread postby foetz » Thu Jan 12, 2017 9:19 pm
Fleeno wrote:I updated my path, and library search path
please show me
