Firefox 3.0.19 tarball
diegel
Unread postby diegel » Tue May 03, 2016 2:08 pm
I build a Firefox 3.0.19 with all dependencies under /opt/mozilla . It is completely independent from nekoware, so you can modify any nekoware packages without destroying your firefox installation. I did this for myself, but possibly this can be useful for others:
ftp://3b1.de/diegel/mozilla.tgz
I also build a version with auto parallelization enabled in some libraries:
ftp://3b1.de/diegel/mozilla-mp.tgz
You can start it with /opt/mozilla/bin/firefox
Re: Firefox 3.0.19 tarball
Unread postby foetz » Tue May 03, 2016 2:30 pm
ah that's nice. especially the second one. will try :D
icebalm
Unread postby icebalm » Tue May 03, 2016 3:44 pm
Thanks diegel, seems to be working quite well for me.
:Fuel: nitro
jimmer
Unread postby jimmer » Tue May 03, 2016 3:48 pm
Many thanks :)
:Fuel: redbox 800Mhz 4Gb V12
Unread postby ClassicHasClass » Thu May 05, 2016 3:47 am
Excellent!
Unread postby foetz » Sun May 22, 2016 1:08 pm
just tried it and it's working like a charm. writing this very post using it :-)
Krokodil
Unread postby Krokodil » Sun May 22, 2016 4:40 pm
Thank you diegel.
Unread postby uunix » Mon May 23, 2016 3:47 am
Brilliant diegel, even using it remotely seems to make the colours much better than what I was using.
I was going to attach this screen shot via firefox running on IRIX, but adding the file gave me an error about the file extension
Invalid file extension: file_1ajeim1g7khd1sb83ct1bo61gelc
Anyone else have this issue?
Unread postby uunix » Mon May 23, 2016 12:29 pm
And now another issue on my Fuel 800MHz 6.5.30 directly on the machine (ie: not remote)
Running './firefox &' produces
[1] + Stopped (tty output) ./firefox
Very similar to the thread below..
http://forums.nekochan.net/viewtopic.php?f=7&t=16718711&p=7279244&hilit=suspended+tty#p7279244
Running without the fork & and it runs, although incredibly slow. I am running the correct version that isn't Multi-Processor. I am running from within /opt/mozilla/bin directory
jirka
Unread postby jirka » Mon May 23, 2016 12:33 pm
Nice! Many thanks!
TruHobbyist
Unread postby TruHobbyist » Mon May 23, 2016 1:12 pm
uunix wrote:And now another issue on my Fuel 800MHz 6.5.30 directly on the machine (ie: not remote)
In the terminal where you run the command, type:
# stty -tostop -loblk
Run firefox again.
Unread postby uunix » Mon May 23, 2016 1:35 pm
Run firefox again.
Stopped has been replaced by Suspended
TruHobbyist
Unread postby TruHobbyist » Mon May 23, 2016 3:26 pm
uunix wrote:Stopped has been replaced by Suspended
What is the output of the following commands from the same terminal/shell/directory???
# echo $SHELL
# echo $TERM
# which stty
# file ./firefox
Unread postby uunix » Mon May 23, 2016 3:46 pm
fuel01 1# echo $SHELL
/bin/tcsh
fuel01 2# echo $TERM
iris-ansi
fuel01 3# which stty
/sbin/stty
fuel01 4# cd /opt/mozilla/bin
fuel01 5# file ./firefox
./firefox:      /bin/sh script text
TruHobbyist
Unread postby TruHobbyist » Mon May 23, 2016 4:12 pm
uunix wrote:
/bin/tcsh
iris-ansi
/sbin/stty
Please send me the ./firefox script. Something is muddying the waters here (switching tty modes silently, for example), and this shell script is a very good candidate.
I'll take a look at it tomorrow.
Good night ;)
