gimp image format plugin, help :-P
Unread postby foetz » Wed Dec 09, 2015 2:39 pm
this is probably trivial but for some reason i just can't see the right way. i tried a couple of ways but no luck :P
i want to make a gimp plugin that can read (writing would be the next stage) wavefront images. rla and rlb which are almost the same. of course i had a closer look at the other gimp plugins for file formats but different formats are, well, different so i didn't see enough similarities to apply it to this case.
i have a sample here from wavefront (full demo attached):
for (scan = rlb_head.window.bottom; scan <= rlb_head.window.top; scan++) {
   /* check for black regions outside active window */
   if ((scan < rlb_head.active_window.bottom) || (scan > rlb_head.active_window.top)) {
      /* write out a blank scanline */
      fwrite(blank, 4, width, out);
   } else {
      /* seek to file location */
      if (fseek(fp, (long) offset[scan - bottom], 0)) {
         printf("rlb file incomplete!\n");
         exit(-7);
      /* read red scanline */
      fread(&len, sizeof(short), 1, fp);
      fread(buf, sizeof(U_CHAR), (int) len, fp);
      decode(buf, red, (int) len);
      /* read green scanline */
      decode(buf, green, (int) len);
      /* read blue scanline */
      decode(buf, blue, (int) len);
      /* read matte scanline */
      decode(buf, matte, (int) len);
      /* write out RGBM for each pixel */
      for (x = rlb_head.window.left; x <= rlb_head.window.right; x++) {
         if ((x < rlb_head.active_window.left) || (x > rlb_head.active_window.right)) {
            fwrite(blank, 4, 1, out);
         } else {
            fwrite(&red[x - left], 1, 1, out);
            fwrite(&green[x - left], 1, 1, out);
            fwrite(&blue[x - left], 1, 1, out);
            fwrite(&matte[x - left], 1, 1, out);
all fine and cozy. i do of course not want to write to a dump file but hand it over to gimp. the gimp stuff is as follows:
image_ID = gimp_image_new(width, height, imgtype);
gimp_image_set_filename(image_ID, filename);
layer_ID = gimp_layer_new(image_ID, _("Background"), width, height, gdtype, 100, GIMP_NORMAL_MODE);
gimp_image_add_layer(image_ID, layer_ID, 0);
drawable = gimp_drawable_get(layer_ID);
gimp_pixel_rgn_init(&pixel_rgn, drawable, 0, 0, drawable->width, drawable->height, TRUE, FALSE);
tile_height = gimp_tile_height();
gimp_pixel_rgn_set_rect(&pixel_rgn, data, 0, 0, width, height);
the important part here is the last one which actually puts the data into gimp. data is guchar i.e. glib's unsigned char. as a pointer.
the thing that made me struggle now is to change the fwrites into something else that i can use for writing to some dummy variable i allocated in advance or whatever else does the job.
also i wanna emphasize that this is not a commercial project in any way. in fact i'd like to share the finished product here in case i get it done somehow :P
any ideas or help in whichever way would be welcome :-)
rlb_read.c.bz2
(1.6 KiB) Downloaded 29 times
Re: gimp image format plugin, help :-P
Unread postby vishnu » Thu Dec 10, 2015 12:56 pm
Have you tried using gimp_pixel_rgn_init() to write the Wavefront image data directly into a GIMP image region, and then you can save that as a new image?
Unread postby foetz » Thu Dec 10, 2015 10:12 pm
rgn_init() doesn't take any actual image data afaik but just, well, inits the region :P
but yeah the idea of using some of the region_set functions inside the decode function could be an option. however the decode function is meant to read one full row per color (and alpha) only so i'd need a new one or change the current one because gimp wants rgba, rgba, rgba ... per row.
my general idea was to replace the fwrites at the bottom so that i store whatever the colors like red[x - left] have in a buffer. once the row is done i give that to gimp, update the progress bar and go for the next row.
the rather basic problem i have there is making a "copy" of whatever red[x - left] and the others have to a buffer. i tried a simple = and bcopy and a few others but nothing worked.
icebalm
Unread postby icebalm » Fri Dec 11, 2015 10:13 am
I'm assuming the matte is alpha channel? wtf else would it be really used for? Do all your gimp image init before hand, and then maybe something like this?
      guchar rowdata[width * 4];
         } else {
            guint pos = 4 * (x - left);
            rowdata[pos] = &red[x - left];
            rowdata[pos+1] = &green[x - left];
            rowdata[pos+2] = &blue[x - left];
            rowdata[pos+3] = &matte[x - left];
      /* write row to GIMP */
      gimp_pixel_rgn_set_row(&pixel_rgn, &rowdata, 0, scan, width);
:Fuel: nitro
Unread postby foetz » Fri Dec 11, 2015 8:59 pm
much thanks for that. unfortunately it doesn't work.
A value of type "guchar *" cannot be assigned to an entity of type "guchar"
in case you didn't grab the full file, the colors are declared as (guchar *). another example of how they're assigned
guchar *red, *green, *blue, *matte;
size_t suc = sizeof(guchar);
red = (guchar *)malloc(suc * width * 4);
green = &red[width];
blue = &green[width];
matte = &blue[width];
pointer-party :P
icebalm
Unread postby icebalm » Fri Dec 11, 2015 10:46 pm
Ahh, ok, then change the lines to be:
rowdata[pos] = *red[x - left];
rowdata[pos+1] = *green[x - left];
rowdata[pos+2] = *blue[x - left];
rowdata[pos+3] = *matte[x - left];
:Fuel: nitro
Unread postby foetz » Sat Dec 12, 2015 12:37 am
sorry, still no dice
The operand of the indirection operator ("*") must be a pointer
Unread postby foetz » Mon Apr 11, 2016 4:04 pm
i had another look at this and this time i took a closer look at the alias pix plugin hoping to find some clues in there. but instead i discovered something that confusesd me even more :P
the plugin does support writing the alias files with and without rle. the curious part now is that the function for loading files just reads them as they come. no special rle detection or support otherwise but it does work nevertheless :shock:
i can't shake the feeling that i'm missing something fundamental about image files ...
EDIT: i hope no seasoned gfx programmer will read this. feels like it's getting a little embarassing :P
