Colourising GNU ls
jimmer
Colourising GNU ls
Unread postby jimmer » Sun Nov 22, 2015 3:05 pm
Hey All,
Finally got round to installing a colourising ls. Here's the recipe:
0. get GNU coreutils 6.12 from http://ftp.gnu.org/gnu/coreutils
1. compile all of it:
CC=c99 CFLAGS="-O2 -mips4" ./configure
but install only the ls binary from $SRC/src
2. nedit $HOME/.Sgiresources:
winterm*background: #000020
3. nedit $HOME/.bashrc:
LS_COLORS='di=35:ln=36:ex=32:'
export LS_COLORS
alias ls='/your/installation/path/ls --color'
4. Log out/in to have it all take effect.
Enjoy :)
:Fuel: redbox 800Mhz 4Gb V12
Re: Colourising GNU ls
Unread postby vishnu » Sun Nov 22, 2015 5:03 pm
I do it just a tad differently, I use both gnu ls and gnu dircolors, and I put it in my ~/.profile so it's always in effect:
ls ()
    command /your/installation/path/ls --color -F "$@"
set LS_COLORS
eval `/your/installation/path/dircolors -b`
Unread postby robespierre » Sun Nov 22, 2015 8:03 pm
If you use tcsh, it has a built-in colorized ls (the actual command is ls-F, but you can assign aliases to it). I think bash does too.
Unread postby vishnu » Sun Nov 22, 2015 11:27 pm
robespierre wrote:If you use tcsh, it has a built-in colorized ls (the actual command is ls-F, but you can assign aliases to it). I think bash does too.
Well I use bash exclusively and the only way I was able to see color ls on any of my Suns or SGI's was by using the GNU ls and dircolors on them, as I detailed above. Also, on my Octane doing man sh | grep-i color gives nothing... :x
Unread postby robespierre » Mon Nov 23, 2015 12:55 am
I will freely admit I could be wrong :)
Unread postby vishnu » Mon Nov 23, 2015 11:41 pm
On my Octane, if I do man tcsh | grep -i color it says "George Hartzell, MCD Biology, University of Colorado-Boulder, 1988" :shock:
Unread postby hamei » Tue Nov 24, 2015 4:56 am
robespierre wrote:I will freely admit I could be wrong :)
But maybe not in this case ... -F is fine but you still have to tell tcsh what color to apply to what filetypes ...
http://docstore.mik.ua/orelly/unix3/upt/ch08_06.ht
weaselwords ; I din't try this. White on blue is about all my brain can deal with.
Unread postby robespierre » Tue Nov 24, 2015 12:46 pm
vishnu wrote:On my Octane, if I do man tcsh | grep -i color it says "George Hartzell, MCD Biology, University of Colorado-Boulder, 1988" :shock:
I think the color features were added sometime between tcsh 3.x.x (is that the version in 6.5?) and 6.x (Astron). It could also be that piping man into grep doesn't really work, since the troff graphic control chars interfere with searchability.
(is it really c^Ho^Hl^Ho^Hr?)
