GTK+-2.10.14 working - dbus not working -Firefox3.5 limbo
rosehillbob
Unread postby rosehillbob » Tue Nov 03, 2015 3:37 pm
I decided to take a break from porting GCC4.80 and take a look at why Firefox3.5 not working. I didn't some testing of the libraries in found faults in GTK>=2.6 and a faulty DBUS library currently in Neko beta. I have a fixed GTK2.10.14 with cairo 1.8 now. I working on DBUS now and hopefully will have something working later today.
I did a quick check to see if Firefox 3.5 would compile OK and quickly came to a conclusion I will need a patch to build it with GCC. I was wondering does anyone have one for Firefox 3.5 or later?
I didn't try compiling Firefox 3.5 under Mipspro. Does anyone know if it will build under Mipspro 7.4m without a patch?
:Onyx2: :O2: :Octane:
Re: GTK+-2.10.14 working - dbus not working -Firefox3.5 limbo
Unread postby dexter1 » Tue Nov 03, 2015 4:24 pm
My attempts with Firefox 3 series was with version 3.0.15. Yes, it does need a substantial amount of patches in the MIPSPro build, at least for that version. I haven't attempted a gcc build yet, but check the search feature. There are some posts pertaining 3.5.5 builds by PymbleSoftware, see viewtopic.php?f=15&t=16725898
Unread postby hamei » Tue Nov 03, 2015 5:25 pm
rosehillbob wrote: I didn't some testing of the libraries in found faults in GTK>=2.6 and a faulty DBUS library currently in Neko beta. I have a fixed GTK2.10.14 with cairo 1.8 now.
Did you try the file handling features ? With the Firefox 3.0.19 in nekoware, I was able to build gtk 2 up to 2.10.16 (iirc) without too many problems, but the file handling went to hell at about x.12. Firefox would run fine but if you tried to download or save a file, kerblammo.
rosehillbob
Unread postby rosehillbob » Tue Nov 03, 2015 8:29 pm
I decided to use gtk2.10.14 to do testing (yes I did test/fix a file handling bug) simply because Firefox3.5 requires gtk >=gtk2.10. I decided not try any later version simply because firefox3.5 must have gone under a lot of testing with gtk2.10 before release. The other library I need to test is DBUS. The use of DBUS was added in firefox3.5 and later. Currently every version of DBUS fails its own validation suite whether compiled with gcc or mipspro. The version in Nekoware also fails the validation suite so I assume the builder didn't test it. The Library is used for communication between process so the predicted result right now is firefox on startup would display a blank page but the moment it tries to render a page over the internet and launches a background process to prefetch DNS lookups it will core dump. This is my prediction even through I have never seen Firefox3.5 on IRIX and from what I read in post's that prediction is correct.
I hope to have a debugged DBUS in a couple of days and hopefully someone will send me a diff file to compile firefox3.5 or 3.6 with either gcc or mipspro or this will be a wasted effort.
Unread postby nekonoko » Tue Nov 03, 2015 8:40 pm
Check with diegel - I believe he was working on firefox 3.5 not too long ago. He also built the 3.0.19 version in Nekoware as far as I recall.
Unread postby hamei » Tue Nov 03, 2015 10:26 pm
Woops, I was mistooken :oops: It's gtk 2.12.16 that's easy to get to. After that, it wasn't too hard to get through the 18's, as I remember.
Then there was a big hurdle. Maybe at 2.14.0 ? Somewhere right around there.
Anyway, gtk 2.12.12 even passes the tests, then up to 2.12.16 is also easy but the file handling goes kerput, then up to 2.12.18 had a couple more hangups but still pretty simple. There were some improvements and fixes mixed in with the goofiness. In fact, I was running 2.12.2?-something, I think. It was noticeably better except had to be careful to not download any file in Firefox or the world came to an end. So if you have a little spare time ....
rosehillbob wrote:firefox3.5 must have gone under a lot of testing ...
Umm, yeah. You might want to revisit that assumption. In fact, I'm kinda curious about how you got "testing" and "firefox" into the same sentence ?
diegel
Unread postby diegel » Wed Nov 04, 2015 12:19 am
That's great news. I am currently at work and don't have access to my build system. I will post my current ff3.5 build config later this day. I will also have a look at dbus. By the way, it is quite common that nekoware packages do not pass their test suite.
diegel
Unread postby diegel » Wed Nov 04, 2015 3:32 am
dexter1 wrote:My attempts with Firefox 3 series was with version 3.0.15.
You have been very close to a working ff3. The only change I had to do is to add the following line to .mozconfig to avoid the bus error:
ac_add_options --disable-safe-browsing
If you want to see you ff3.0.15 running you can try this.
rosehillbob
Unread postby rosehillbob » Wed Nov 04, 2015 4:26 pm
Which version of firefox3.5 are you using for the build? I have 3.5.09 and with gcc it stops with message cc1 error '-march=-mips2' not compatible with the slected ABI. If try mipsPro7.4m i get 'as unrecognized option -_ASM'.
I gather from the above post 'ac_add_options --disable-safe-browsing' is a minor change to make things build...that is not what I am seeing here.
Note I did try a simple patch and got past the compiling this particular file with gcc only hit another road block (failed to link NSPR), made a second patch to links NPSR only to find a link problem in JS and so on. The rate I am going I will have to make dozen's of source code changes to just get it to build then comes the fun part of debugging it.
Is that your experience with 3.5?
rosehillbob
Unread postby rosehillbob » Wed Nov 04, 2015 5:10 pm
I just notice something interesting on the Mozilla site concerning the requirements to run Firefox version 22. It states for the Linux platform DBUS isn't required to run but is listed as a "optional library to increase performance". I next downloaded the Firefox source code for 22 and found in the configure program the check for DBUS is still there! Hmmm... so DBUS is required to compile but not required to run (at least for the Linux case) so this must mean DBUS is loaded via DLOPEN! If that is the case and I am pretty sure IRIX supports dlopen as well so maybe a test of possible DBUS problems is to simply uninstall DBUS after you build Firefox3.5 and see if Firefox3.5 starts up without link errors. If it does well that is one way to see if DBUS is at fault!
diegel
Unread postby diegel » Wed Nov 04, 2015 10:41 pm
I am working with ff3.5.19. I build it with dbus disabled. Attached you find my current patch. This is my build environment:
export CC=/usr/nekoware/gcc-4.7/bin/gcc
export CXX=/usr/nekoware/gcc-4.7/bin/g++
export CFLAGS='-march=r12000 -mips4 -mabi=n32'
export CXXFLAGS='-march=r12000 -mips4 -mabi=n32 -fpermissive'
export CPPFLAGS='-I/usr/nekoware/include'
export LDFLAGS='-L/usr/nekowazre/lib'
export LIBS="-lfastm -lm -lpthread"
export PERL="/usr/nekoware/bin/perl"
export BUILD_OFFICIAL=1
export MOZILLA_OFFICIAL=1
Here comes the .mozconfig:
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/ff-deb-static
ac_add_options --prefix=/opt/mozilla
ac_add_options --enable-application=browser
ac_add_options --disable-optimize
ac_add_options --enable-debug
ac_add_options --with-pthreads
ac_add_options --with-system-sqlite
ac_add_options --enable-tests
ac_add_options --enable-system-cairo
ac_add_options --disable-updater
ac_add_options --disable-update-channel
ac_add_options --disable-dbus
ac_add_options --disable-gnomevfs
ac_add_options --disable-gnomeui
ac_add_options --enable-plugins
ac_add_options --disable-accessibility
ac_add_options --disable-inspector-apis
ac_add_options --disable-pref-extensions
ac_add_options --disable-extensions
ac_add_options --disable-installer
ac_add_options --enable-official-branding
ac_add_options --disable-parental-controls
ac_add_options --disable-javaxpcom
ac_add_options --disable-url-classifier
ac_add_options --disable-strip
ac_add_options --disable-install-strip
ac_add_options --disable-ogg
ac_add_options --disable-wave
mk_add_options BUILD_OFFICIAL=1
mk_add_options MOZILLA_OFFICIAL=1
mk_add_options MOZ_MAKE_FLAGS="-j12"
ac_add_options --enable-ipv6
ac_add_options --disable-crashreporter
ac_add_options --disable-xft
ac_add_options --enable-freetype2
ac_add_options --disable-jsd
ac_add_options --disable-shared
ac_add_options --enable-static
The ff3.0.19 build instructions are still working:
Build instructions:
Get the source code from:
ftp://ftp.mozilla.org/pub/firefox/relea ... ce.tar.bz2
extract it and apply the attached patch.
Get a current version of sqlite3:
http://www.sqlite.org/download.html
Copy sqlite3.c and sqlite3.h from current sqlite3 to mozilla/db/sqlite3/src
There may be a problem with signlib during build. Make sure there
are no shared libs in /usr/nekoware/lib/firefox-3.0.19 during build instead
you must have a firefox2 or seamonkey1 lib directory in your LIB search path.
Otherwise signlib may coredump.
set the environment and start the build:
gmake -f client.mk build
There is one assembler file in libfreebl you have to compile manually with gcc3.
cd security/nss/lib/freebl
gcc -x assembler-with-cpp -o /work/mozilla-1.9.1/ff-deb-static/nss/freebl/IRIX_SINGLE_SHLIB/mpi_mips.o -Wp,-P -Wp,-traditional-cpp -c mpi/mpi_mips.s
ff3.5.19.patch
(20.84 KiB) Downloaded 34 times
Unread postby dexter1 » Thu Nov 05, 2015 1:57 am
Yesterday i got my main O200 fileserver back online after it shut down two years ago. i have located various build directories, one of which was firefox 3.5.5 with MIPSPro 7.4 and nekoware from 2009
I'll share this firefox 3.5.5 work in progress build as well. I haven't done much since 2010, but there is one more O200 i have to revive that i think has firefox 3.0.19 build directory with the bus error.
mozconfig
CC=c99
CXX=CC
CFLAGS='-n32 -INLINE -woff 1174'
CPPFLAGS='-I/usr/local/include -I/usr/nekoware/include'
LDFLAGS='-L/usr/local/lib -L/usr/nekoware/lib'
LIBS='-lm'
CXXFLAGS='-Zf,_245 -ptused -n32 -INLINE -woff 1110,1171,1201,1355,1460,3201,3303,3625,3649'
PERL=/usr/nekoware/bin/perl
PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:/usr/nekoware/lib/pkgconfig
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/ff-dbg-static-cc
mk_add_options MOZ_CO_PROJECT=browser
mk_add_options MOZ_MAKE_FLAGS="-j3"
#ac_add_options --enable-optimize=-O2
ac_add_options --enable-libxul
ac_add_options --disable-tests
Two patch files, one for the firefox main source one for the XPTC/NS bruhaha
firefox35_irix.patch
(14.49 KiB) Downloaded 34 times
xptcall.patch
(15.68 KiB) Downloaded 32 times
There are other hurdles on the road, but this should get a MIPSPro build going
diegel
Unread postby diegel » Thu Nov 05, 2015 2:06 am
I think the current problem is still in xpcom. This is possibly a start to find out more: https://bugzilla.mozilla.org/show_bug.cgi?id=482759
rosehillbob
Unread postby rosehillbob » Wed Nov 11, 2015 6:54 pm
I downloaded ff3.5.19 and diegel's patch and attempted a build. The build stopped at xpcom saying unable to build a stubsdef... file. I found the missing file in dexter1's xptcall patch. I added the file only to find it the IRIX assembly files in xptcall wouldn't assemble without error. The fault ended up being gcc was calling the gnu assembler and the gnu assembler was choking on the syntax. The solution was to modify Makefile.in to use the system assembler instead. I also modifed Makefile.in in security/nss/lib/freebl as well so the build continues to the end without interruption. I was now able to attempt to run firefox. What happens is it shoots a bunch of messages about registering various components then display several assertion failed messages and does a graceful shutdown (it doesn't crash with a bus error or dump core) instead display memory stats while shutting down. I did check the above link since the missing file is related to the above bug report link. Bugzilla resolved the problem with the change in GCC 3.0 abi by a patch which reads the stub file and generates the necessary C++ decoration on the fly. Diegel's patch uses a 'hand modified stubs file' todo the same thing. This file was missing in diegel's patch so I used the one from dexters patch file which may or may not be correct. I plan to implement the change tonight listed in bugzilla tonight to see if it corrects the problem...Building takes hours whenever a change is made. I calculated using an Onyx2 added $2 to my electric bill so far so I may have to pass the hat if I need to do a bunch of debugging!
diegel
Unread postby diegel » Thu Nov 12, 2015 1:02 am
rosehillbob wrote: I found the missing file in dexter1's xptcall patch.
Sorry, this file was indeed missing in my patch but it's the same file I use for ff3 and also ff3.5. I am glad to read that you are able to build it now. If you are starting an optimized build it will take at least twice the time to build. There was an attempt to port ff10 some time ago, he stopped this project after he was unable to link a huge libmoz because of Irix ld limitations. If you are interested in this work, I can provide this for you. If I can support your work please let me know.
