stat !
stat !
Unread postby hamei » Sun Sep 20, 2015 7:14 pm
I would like to build a static executable for portability ... no shared libaries, build it all into the executable. MIPSPro 7.4.4, Irix 6.5.21
Is this possible ? How ?
Re: stat !
Unread postby foetz » Sun Sep 20, 2015 9:10 pm
in most cases you don't wanna link system libs statically but only 3rd party such as libxml or whatever else doesn't come with a default installation. to do so you have 3 options:
1. put the archive files (.a) on the link line right after your object files (.o)
2. the libs in question are only static anyway. nothing to do then
3. explicitly tell the linker to link the mentioned stuff statically by using "-B static" on the link line
if you're going for option 3 make sure to change back to dynamic for system libs after the static parts. an example that combines all 3 options:
cc proggy.c /usr/local/lib/libxml.a -B static -lcurl -lssl -B dynamic -lSgm -lXm -lXt -lX11 -lmalloc
here xml, ssl and curl are added to the resulting binary while the default irix libs remain dynamic. you can mix option 1 and 3 at will.
also note that static linking may require more libs on the link line than the dynamic counterparts so you might need a few runs before all deps are satisfied
Re: stat !
Unread postby hamei » Mon Sep 21, 2015 2:12 am
foetz wrote:if you're going for option 3 make sure to change back to dynamic for system libs after the static parts. an example that combines all 3 options:
Perfect ! thank you, thank you very much :)
Now ... ah ... would anyone with an Octane happen to have a zipped-up unix file ? I did gmake uninstall and fontforge helpfully rm /*-ed me. As root. Luckily there's not much in there and rm won't delete directories but my backup is from an O350. That won't work with an Octane, I presume ?
Meanwhile, we're going to enter the uptime competition :P
nongrato
Re: stat !
Unread postby nongrato » Mon Sep 21, 2015 4:42 am
hamei wrote:. would anyone with an Octane happen to have a zipped-up unix file ?
PM sent.
:Octane2: :320:
Re: stat !
Unread postby hamei » Mon Sep 21, 2015 5:01 am
nongrato wrote:PM sent.
Thank you ! I think the backup is okay but you know how that goes ....
nongrato
Re: stat !
Unread postby nongrato » Mon Sep 21, 2015 5:16 am
hamei wrote:Thank you !.
;) you're welcome. Nice User-Agent btw.
:Octane2: :320:
Re: stat !
Unread postby foetz » Mon Sep 21, 2015 12:08 pm
let me guess:
Mozilla 9.99 [en] (X11; U; Loonix V666 AppleWatch)
Re: stat !
Unread postby hamei » Mon Sep 21, 2015 5:54 pm
foetz wrote:let me guess:
Not exactly :P But we should make this a contest, see who can come up with the best user-agent :D
