Xpad compile (success)
necron2600
Unread postby necron2600 » Thu Aug 20, 2015 11:12 pm
I have been using an SGI system as a daily driver the past month (better late than never...) and I can stand slow firefox, no youtube, etc.. but I really could not stand missing a sticky post-it note app. Having 10 or more nedit windows open didnt work well for me.
So, I set out to find any existing sticky post-it note-style app that would work on IRIX. I have all Nekoware packages as of a couple months ago.. up-to-date, etc.. I did not seem to find anything equivalent.. or existing already that still works. (I hope I didnt miss any!)
XPad ( https://launchpad.net/xpad ) fit the bill. Lightweight, cross-platform, C code.
All versions failed to pass a configure due to an older intltool on my system.
However. the older xpad version 3.0 worked fine.
Download xpad-3.0.tar.bz from https://launchpad.net/xpad
I set my PATH to have gcc4.7 first.. instead of using nekoware's gcc version 3 in /usr/nekoware/bin:
export PATH=/usr/nekoware/gcc4.7/bin:$PATH
Note I am using bash shell...
./configure
edit po/Makefile
GMSGFMT = is empty for some reason and a gmake errors out.. but the following line MSGFMT has /usr/nekoware/bin/msgfmt.
I added /usr/nekoware/bin/msgfmt as the value to GMSGFMT:
GMSGFMT = /usr/nekoware/bin/msgfmt
Fix a bug for xpad with newer versions of glib/gdk2 that come from nekoware:
Error message: (xpad:15313): GLib-GObject-WARNING **: IA__g_object_set_valist: construct property "type" for object 'XpadPad' can't be set after construction
fix source: http://www.murga-linux.com/puppy/viewtopic.php?t=65343
--- orig/xpad-4.0/src/xpad-pad.c 2009-05-11 03:44:09.000000000 +0200
+++ xpad-4.0/src/xpad-pad.c 2010-04-09 14:36:50.000000000 +0200
@@ -275,7 +275,7 @@
"gravity", GDK_GRAVITY_STATIC, /* static gravity makes saving
pad x,y work */
"skip-pager-hint", !xpad_settings_get_has_decorations
(xpad_settings ()),
"skip-taskbar-hint", !xpad_settings_get_has_decorations
(xpad_settings ()),
- "type", GTK_WINDOW_TOPLEVEL,
+ //"type", GTK_WINDOW_TOPLEVEL,
"type-hint", GDK_WINDOW_TYPE_HINT_NORMAL,
"window-position", GTK_WIN_POS_MOUSE,
"child", vbox,
What the above means is:
edit src/xpad.pad.c and comment out "type", GTK_WINDOW_TOPLEVEL, line
gmake # note to use gmake not make, or else strange errors show up (bu42, etc..)
all done.. working binary in src/xpad
as root run:
gmake install
to install to /usr/local
I hope this helps someone. Sometime soon I will see about creating a nekoware tardist.
Re: Xpad compile (success)
Unread postby foetz » Fri Aug 21, 2015 12:42 am
thanks for the guide. if you just wanna share it without going through creating a correct nekoware tardist you could also just attach the compressed package
Unread postby hamei » Fri Aug 21, 2015 12:56 am
foetz wrote:thanks for the guide. if you just wanna share it without going through creating a correct nekoware tardist you could also just attach the compressed package
Nekochan also has a /contrib directory structure with a ton of non-nekoware stuff (as foetz well knows, he's the leader in that field :D) Contact Mr Neko and he'll set you up.
Unread postby foetz » Fri Aug 21, 2015 2:58 am
haha yes of course, but that only makes sense if you plan to offer a bunch of stuff
Unread postby hamei » Fri Aug 21, 2015 6:30 am
I knew I remembered something about this ...
viewtopic.php?f=7&t=16726484&p=7349428&hilit=stickynotes#p7349428
so I took advantage of jimmer's absence
to throw a compiler against it, came out with
for those what's adwenturous, here's the binneries and readme.1st
jimmernotes.tar.gz
(94.13 KiB) Downloaded 26 times
but one thing ... read up on the vulcan death grip first. Jimmer may not welcome this ghost-ex-closetus :shock:
duck
Unread postby duck » Fri Aug 21, 2015 6:32 am
In case Xpad doesn't work out for you, there's also the thing jimmer cooked up (viewtopic.php?t=13785), though the link is dead (and that's an old version anyway). I have a copy here: http://duck.at.shangtai.net/files/sgi/.
Damnit, hamei, you ninja :-P
___(o)=
\____)
Unread postby hamei » Fri Aug 21, 2015 6:36 am
duck wrote:Damnit, hamei, you ninja :-P
There's plenty of room here for a team ... maybe you can get it to not seize up the desktop ?
duck
Unread postby duck » Fri Aug 21, 2015 6:41 am
Notes then? I have no issues running it since I first installed it...
___(o)=
\____)
Unread postby hamei » Fri Aug 21, 2015 9:35 pm
duck wrote:Notes then? I have no issues running it since I first installed it...
Okay le, went back to jimmer's preferred opto of -O2 instead of -O3, it seems better.
However, it still exhibits the marks of the Dreaded SIQ if I play with the notes too much. And "hide" does not do anything. I could be misusing it, I'm not much of a postit notes guy, prefer the mmb-to-a-textfile trick.
Could still be several things - Viewkit here at 21 and so is the os. Also I have 2 p's ? One would think everything in Irix would be careful about smp but you never know.
Anyhoo, here's a better binnery. Don't use the other one, she is bad. Do you want to tar yours and stick it up for comparison, duck ?
This is just the executable, the README and chestrc are still in the earlier attachment. No point to getting carried away until we find the problem :(
notes.tar.gz
(92.13 KiB) Downloaded 21 times
duck
Unread postby duck » Sat Aug 22, 2015 12:15 am
Yup, dual R12ks here too, and ViewKit 2.1. I thought I had the 1.0 tardist installed (linked in my earlier post), but the binary is in /usr/local and I don't have a 'notes' package installed, so perhaps I'm running 0.9? I have a vague memory of one of the versions being kind of broken.
Yup, "About Notes" says 0.9.
Find my binary enclosed.
It's not something I use every day (these notes are OLD :-), but quite handy...
notes.gz
Notes binary
(41.2 KiB) Downloaded 24 times
___(o)=
\____)
jimmer
Unread postby jimmer » Sat Aug 22, 2015 1:13 am
Hey there Earthlings,
Thrilled to see somebody is looking into using my spit+ducttape Notes thingy. Will look into the various issues and see if/what to fix.
In the meantime here's something completely unrelated yet utterly useful, coz I always forget. Yay!
#!/bin/sh
motif_version=`ls -l /usr/include/Xm/ | awk '{FS="/"; print $6}'`
text="Currently\ using\ $motif_version"
btn_result=`eval xconfirm -c -header "Motif" -t ${text} -B Ok -icon info`
:Fuel: redbox 800Mhz 4Gb V12
Unread postby hamei » Sat Aug 22, 2015 1:59 am
jimmer wrote:Hey there Earthlings ...
came a voice from the sky on that magical night ...
Heck, if that's all it takes, keep writing software and we'll take care of the rest :D
Meanwhile, I tried duck's with the same result, all is fine until I try < notes - hide >.
Then I looked at the source ... there doesn't appear to be any code for < -hide > ?
Seems like that'd do it :D
necron2600
Unread postby necron2600 » Tue Aug 25, 2015 3:30 pm
XPad 3.0 compiled for mips4 (using gcc4.7)
Extract into /usr/local
-Kevin
xpad-extract-in-usr-local.tar.gz
XPAD 3.0 for mips4
(267.97 KiB) Downloaded 23 times
