Problem at building telegram-purple
eudatux23
Unread postby eudatux23 » Sat Apr 04, 2015 8:16 am
Hi,
I just tried to compile telegram-purple on IRIX. It is a plugin to use the Telegram protocol in Pidgin.
The configure-Script ran after I gave it the parameter --with-zlib=/usr/nekoware
Unfortunately gmake doesn't want to do anything:
17:05 root@rocktane /root/telegram/telegram-purple-master
% gmake
gmake: *** Keine Regel vorhanden, um das Target »tgl/scheme.tl«,
  benötigt von »auto/scheme.tl«, zu erstellen.  Schluss.
I also tried the "classic" make from IRIX which just gives a syntax error:
17:06 root@rocktane /root/telegram/telegram-purple-master
% make
make: file `./Makefile.tl-parser' line 5: Syntax error
Here you can see the output of configure if it helps:
17:03 root@rocktane /root/telegram/telegram-purple-master
% ./configure --with-zlib=/usr/nekoware
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a BSD-compatible install... /usr/nekoware/bin/install -c
checking for sqrt in -lm... yes
checking for clock_gettime in -lrt... yes
checking for pkg-config... /usr/nekoware/bin/pkg-config
checking whether compiling and linking against OpenSSL works... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/nekoware/bin/grep
checking for egrep... /usr/nekoware/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... no
checking for unistd.h... yes
checking if zlib is wanted... yes
checking for inflateEnd in -lz... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking pkg-config is at least version 0.9.0... yes
checking for PURPLE... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking for size_t... yes
checking for GNU libc compatible malloc... yes
checking for memset... yes
checking for strdup... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
And a link to the GitHub Repository of it: https://github.com/majn/telegram-purple
Does anybody have an idea why gmake fails?
Thanks in advance!
:Octane2: SGI Octane 2 - Dual R12K 400 MHz - 250 0MB RAM - 73 GB HDD - vPro v12 - IRIX 6.5.30
:Indigo2IMP: SGI Indigo² - R10K 175 MHz - 320 MB RAM - 73 GB SCSI HDD - High Impact-AA + TRAM - IRIX 6.5.22f
:O2: SGI O2 - R5K 180 MHz - 96 MB RAM - 18 GB HDD - CRM - IRIX 6.5.30
duck
Re: Problem at building telegram-purple
Unread postby duck » Sun Apr 05, 2015 10:32 am
It fails because there's no rule to make the default target (whatever happens to be first in the makefile) if I translate your localized error message correctly. Either read it to find out or try something like "make all" (or "gmake all" since GNU is most often all these people know about).
Are you sure this master branch snapshot actually builds?
___(o)=
\____)
eudatux23
Unread postby eudatux23 » Sun Apr 05, 2015 10:57 am
Hi,
thanks for the hint! I recloned it (This time on my Linux machine, because I'm not at home at them moment) and seen that it cloned "tgl-parser" etc too. I think the case is closed.
Tomorrow I will test it out with a new git clone.
eudatux23
Unread postby eudatux23 » Mon Apr 06, 2015 12:59 pm
I guess I ran into a new problem..
21:41 root@rocktane /root/telegram-purple
% LANG=C gmake
gcc  -g -O2 -I/usr/nekoware/include/libpurple -I/usr/nekoware/include/glib-2.0 -I/usr/nekoware/lib/glib-2.0/include   -DHAVE_CONFIG_H -Wall -Wextra -Wno-deprecated-declarations -Wno-unused-parameter -I. -I. -fno-strict-aliasing -fPIC -I/usr/nekoware/include -I/usr/nekoware/include -DFLAGS -iquote ./tgl/tl-parser -c -MP -MD -MF dep/tl-parser.d -MQ objs/tl-parser.o -o objs/tl-parser.o tgl/tl-parser/tl-parser.c
gcc: ./tgl/tl-parser: linker input file unused because linking not done
cc1: error: unrecognized command line option "-iquote"
cc1: ./tgl/tl-parser: No such file or directory
gmake: *** [objs/tl-parser.o] Error 1
This was fixed easily by using the newer GCC (neko_gcc46)
However, after that I got a new error:
21:50 root@rocktane /root/telegram-purple
% LANG=C gmake
gcc  -g -O2 -I/usr/nekoware/include/libpurple -I/usr/nekoware/include/glib-2.0 -I/usr/nekoware/lib/glib-2.0/include   -DHAVE_CONFIG_H -Wall -Wextra -Wno-deprecated-declarations -Wno-unused-parameter -I. -I. -fno-strict-aliasing -fPIC -I/usr/nekoware/include -I/usr/nekoware/include -DFLAGS -iquote ./tgl/tl-parser -c -MP -MD -MF dep/tlc.d -MQ objs/tlc.o -o objs/tlc.o tgl/tl-parser/tlc.c
tgl/tl-parser/tlc.c:40:22: fatal error: execinfo.h: No such file or directory
compilation terminated.
gmake: *** [objs/tlc.o] Error 1
Maybe my libpurple or glibc is too old? Exactly the same source files build just fine on my Linux workstation.
Thanks in advance!
Unread postby foetz » Mon Apr 06, 2015 6:46 pm
eudatux23 wrote:Exactly the same source files build just fine on my Linux workstation.
what a surprise, i guess you didn't read any of the threads in the development section here ... ever :P
and neither tried google. very first hit brings you to http://www.gnu.org/software/gnulib/manu ... 002eh.html
bottom line: remove the include and see if something is missing then.
eudatux23
Unread postby eudatux23 » Mon Apr 06, 2015 10:47 pm
Thanks for the hint! This seemed to help. After that I got the error that "-rdynamic" is not supported. After removing that, it seemed to work. But after some time:
7:36 root@rocktane /root/telegram-purple
% gmake
gcc objs/tl-parser.o objs/tlc.o objs/crc32.o -L/usr/nekoware/lib -L/usr/nekoware/lib -L/usr/nekoware/lib   -L/usr/nekoware/lib -lpurple -lglib-2.0 -lintl   -lz -lrt -lm  -lcrypto -ggdb -o bin/tl-parser
ld32: WARNING 84 : /usr/nekoware/lib/libpurple.so is not used for resolving any symbol.
ld32: WARNING 84 : /usr/nekoware/lib/libz.so is not used for resolving any symbol.
ld32: WARNING 84 : /usr/lib/../lib32/librt.so is not used for resolving any symbol.
ld32: WARNING 84 : /usr/nekoware/lib/libcrypto.so is not used for resolving any symbol.
bin/tl-parser -e auto/scheme.tlo auto/scheme.tl
gcc  -g -O2 -I/usr/nekoware/include/libpurple -I/usr/nekoware/include/glib-2.0 -I/usr/nekoware/lib/glib-2.0/include   -DHAVE_CONFIG_H -Wall -Wextra -Wno-deprecated-declarations -Wno-unused-parameter -I. -I. -fno-strict-aliasing -fPIC -I/usr/nekoware/include -I/usr/nekoware/include -DFLAGS -iquote ./tgl -c -MP -MD -MF dep/generate.d -MQ objs/generate.o -o objs/generate.o tgl/generate.c
tgl/generate.c: In function 'get_string':
tgl/generate.c:134:3: warning: implicit declaration of function 'strndup' [-Wimplicit-function-declaration]
tgl/generate.c:134:13: warning: incompatible implicit declaration of built-in function 'strndup' [enabled by default]
gcc  -g -O2 -I/usr/nekoware/include/libpurple -I/usr/nekoware/include/glib-2.0 -I/usr/nekoware/lib/glib-2.0/include   -DHAVE_CONFIG_H -Wall -Wextra -Wno-deprecated-declarations -Wno-unused-parameter -I. -I. -fno-strict-aliasing -fPIC -I/usr/nekoware/include -I/usr/nekoware/include -DFLAGS -iquote ./tgl -c -MP -MD -MF dep/tools.d -MQ objs/tools.o -o objs/tools.o tgl/tools.c
tgl/tools.c: In function 'tgl_asprintf':
tgl/tools.c:84:3: warning: implicit declaration of function 'vasprintf' [-Wimplicit-function-declaration]
gcc objs/generate.o objs/tools.o -L/usr/nekoware/lib -L/usr/nekoware/lib -L/usr/nekoware/lib   -L/usr/nekoware/lib -lpurple -lglib-2.0 -lintl   -lz -lrt -lm  -lcrypto -ggdb -o bin/generate
ld32: WARNING 84 : /usr/lib/../lib32/libm.so is not used for resolving any symbol.
ld32: ERROR   33 : Unresolved data symbol "strndup" -- 1st referenced by objs/generate.o.
        Use linker option -v to see when and which objects, archives and dsos are loaded.
ld32: ERROR   33 : Unresolved data symbol "vasprintf" -- 1st referenced by objs/tools.o.
ld32: INFO    152: Output file removed because of error.
collect2: error: ld returned 2 exit status
gmake: *** [bin/generate] Fehler 1
Seems to be that it doesn't support vasprintf and strndup?
GCC is version 4.7.1 from Nekoware:
7:46 root@rocktane /root/telegram-purple
% gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/nekoware/gcc-4.7/libexec/gcc/mips-sgi-irix6.5/4.7.1/lto-wrapper
Target: mips-sgi-irix6.5
Configured with: ../gcc-4.7.1/configure --prefix=/usr/nekoware/gcc-4.7 --with-gmp=/usr/nekoware/gcc-4.7 --with-mpfr=/usr/nekoware/gcc-4.7 --with-mpc=/usr/nekoware/gcc-4.7 --with-cloog=/usr/nekoware/gcc-4.7 --with-ppl=/usr/nekoware/gcc-4.7 --with-as=/usr/nekoware/gcc-4.7/bin/as --with-gnu-as --without-gnu-ld --with-ld=/usr/bin/ld --with-host-libstdcxx=/opt/gcc-4.7.1/lib32/libstdc++.a --disable-libssp --disable-nls --disable-lto --disable-shared --enable-static --enable-threads=posix --enable-libgomp --enable-obsolete --enable-checking=release --enable-languages=c,c++,fortran,objc,obj-c++ --with-arch=mips4 --with-abi=n32
Thread model: posix
gcc version 4.7.1 (GCC)
Thanks in advance!
Unread postby foetz » Tue Apr 07, 2015 1:05 am
eudatux23 wrote:Seems to be that it doesn't support vasprintf and strndup?
exactly. these don't exist on irix.
diegel
Unread postby diegel » Tue Apr 07, 2015 2:04 am
You can use g_vasprintf and g_strndup form glib.
eudatux23
Unread postby eudatux23 » Tue Apr 07, 2015 2:50 am
Any idea how to do this? Is it enough to just change the words in the source code? I can try it this evening.
diegel
Unread postby diegel » Tue Apr 07, 2015 3:00 am
eudatux23 wrote:Any idea how to do this? Is it enough to just change the words in the source code? I can try it this evening.
You have to include glib.h and change the source. The code is linked with glib already, so you don't need to change anything for linking.
eudatux23
Unread postby eudatux23 » Tue Apr 07, 2015 9:34 am
That worked. But now after these changes I even got a new error:
18:29 root@rocktane /root/telegram-purple
% LANG=C gmake
bin/generate -H auto/scheme.tlo > auto/auto-header.h
Assertion failed: EX, file tgl/generate.c, line 1511, pid 1489
gmake: *** [auto/auto-header.h] Error 1
Unread postby foetz » Tue Apr 07, 2015 9:39 am
well, have a look into generate.c at line 1511 and see what happens there
eudatux23
Unread postby eudatux23 » Tue Apr 07, 2015 9:48 am
The content of this line is:
assert (t->constructors_num >= 0 && t->constructors_num <= 1000);
It is part of the following struct:
struct tl_type *read_types (void) {
  struct tl_type *t = malloc0 (sizeof (*t));
  t->name = get_int ();
  t->id = get_string ();
  t->print_id = strdup (gen_print_id (t->id));
  assert (t->print_id);
  t->constructors_num = get_int ();
  t->constructors = malloc0 (sizeof (void *) * t->constructors_num);
  t->flags = get_int ();
  t->arity = get_int ();
  t->params_types = get_long (); // params_types
  t->extra = 0;
  tl_type_insert_by_name (t);
  return t;
Any ideas? Thanks!
Unread postby vishnu » Tue Apr 07, 2015 10:53 am
Just comment that line out and see what happens next.
eudatux23
Unread postby eudatux23 » Tue Apr 07, 2015 11:15 am
After uncommenting this line, the problem sadly hasn't changed. I also tried a gmake clean to make sure that no rests of the old binaries is there. The message is still the same at the end.
20:09 root@rocktane /root/telegram-purple
% LANG=C gmake
cat tgl/scheme.tl tgl/encrypted_scheme.tl tgl/binlog.tl tgl/append.tl tgl/mtproto.tl > auto/scheme.tl
gcc  -g -O2 -I/usr/nekoware/include/libpurple -I/usr/nekoware/include/glib-2.0 -I/usr/nekoware/lib/glib-2.0/include   -DHAVE_CONFIG_H -Wall -Wextra -Wno-deprecated-declarations -Wno-unused-parameter -I. -I. -fno-strict-aliasing -fPIC -I/usr/nekoware/include -I/usr/nekoware/include -DFLAGS -iquote ./tgl/tl-parser -c -MP -MD -MF dep/crc32.d -MQ objs/crc32.o -o objs/crc32.o tgl/tl-parser/crc32.c
tgl/tools.c:85:3: warning: implicit declaration of function 'g_vasprintf' [-Wimplicit-function-declaration]
bin/generate auto/scheme.tlo > auto/auto.c
Assertion failed: EX, file tgl/generate.c, line 107, pid 1226
gmake: *** [auto/auto.c] Error 1
