OpenSSL
armanox
OpenSSL
Unread postby armanox » Tue Mar 17, 2015 9:14 pm
Anyone using newer versions of OpenSSL with IRIX? Like say...a 1.x build? And have it work pretty correctly? I can get 1.0.1 to build, but make test fails all over the place. I'm now using mbedTLS (used to be PolarSSL) with curl so that I can download stuff via https with out hassle, since everyone has disabled SSL2 and 3 at this point it seems....
:Octane: :Octane: :O2:
Re: OpenSSL
Unread postby foetz » Tue Mar 17, 2015 10:29 pm
armanox wrote:I'm now using mbedTLS (used to be PolarSSL) with curl
and that causes problems?
armanox
Re: OpenSSL
Unread postby armanox » Wed Mar 18, 2015 9:32 am
No, in fact, I was quite pleased when it built with only one modification (I'm going to send it back to them so they can support us!). The issue is the amount of software that does depend on OpenSSL or GNUTLS.
Re: OpenSSL
Unread postby Raion-Fox » Wed Mar 18, 2015 9:45 am
Someone got LibreSSL working, honestly that is what I would push for.
armanox
Re: OpenSSL
Unread postby armanox » Wed Mar 18, 2015 11:23 am
TeamBlackFox wrote:Someone got LibreSSL working, honestly that is what I would push for.
I had said I got it to build, not that it all worked. The SGI compatibility stuff in there (and I might add, the AIX stuff) was all me, but it requires some pieces that I don't have the time to try to port or develop.
Re: OpenSSL
Unread postby foetz » Wed Mar 18, 2015 4:02 pm
well one step at a time. do certain programs only work right with openssl 1.x?
if so does openssl 1.x fail to build? and if yes is it something that is irix specific and cannot be fixed?
armanox
Re: OpenSSL
Unread postby armanox » Wed Mar 18, 2015 4:12 pm
foetz wrote:well one step at a time. do certain programs only work right with openssl 1.x?
OpenSSL 1.0.1 will build, but fails miserably when you run "make test" on calculating SHA1, and I remember it failing to work correctly when I attempted to use it (things just...didn't work).
OpenSSL 0.9.8 is too old to be useful for a lot of things (since everyone has disabled SSL2 and SSL3), but is the last version that is packaged by nekoware for IRIX.
Re: OpenSSL
Unread postby foetz » Wed Mar 18, 2015 4:23 pm
armanox wrote:OpenSSL 0.9.8 is too old to be useful for a lot of things
could you give a few examples?
Re: OpenSSL
Unread postby vishnu » Wed Mar 18, 2015 5:12 pm
One thing's for sure, the LibreSSL guys didn't think too highly of the state of the OpenSSL code when they forked it.
armanox
Re: OpenSSL
Unread postby armanox » Wed Mar 18, 2015 5:15 pm
It doesn't support TLS 1.1 and 1.2, for example.
Re: OpenSSL
Unread postby Raion-Fox » Wed Mar 18, 2015 5:16 pm
Well then, what are our options? Use an old OpenSSL library, somehow debug the newer version, or port libressl - in both latter cases the task is likely to be monumental, but I would imagine the clean codebase of LibreSSL would be marginally easier
Re: OpenSSL
Unread postby foetz » Wed Mar 18, 2015 5:26 pm
vishnu wrote:One thing's for sure, the LibreSSL guys didn't think too highly of the state of the OpenSSL code when they forked it.
they should've kept the build system tho. libressl comes with a bunch of crap such as hardcoded, gcc specific cflags and such
Re: OpenSSL
Unread postby vishnu » Wed Mar 18, 2015 5:41 pm
Well that's retarded. But apparently not as retarded as the OpenSSL codebase:
http://www.openbsd.org/papers/bsdcan14-libressl/mgp00001.html
Even if only a tiny fraction of what he's saying is accurate, wowwwwww... :shock: :roll:
armanox
Re: OpenSSL
Unread postby armanox » Wed Mar 18, 2015 5:56 pm
In case you're curious, my efforts for IRIX (and AIX) ended due to issues with arc4random and getentrophy. If I have a sudden explosion of free time I might start hacking away at it again, but my port is pretty dead for the moment (plus I'm a few versions behind now too).
Oh, and the fact that IRIX does not support mapping anonymous pages doesn't help either.
Re: OpenSSL
Unread postby foetz » Wed Mar 18, 2015 6:03 pm
funny to read "- Do portability right. " in there. at that they not only completely failed so far but actully made it much worse.
"- Preserve API/ABI compatibility with OpenSSL - We want to be essentially a drop in replacement." which failed as well. e.g. they simply dropped egd stuff completely without leaving any kind of warning, replacement dummy or whatsoever in place.
that aside i'm curious about why the presentation looks like from a 5th grader :P
armanox wrote:Oh, and the fact that IRIX does not support mapping anonymous pages doesn't help either.
that's an easy fix. i did that for my last postgresql builds. i can dig out the details if you're interested
Users browsing this forum: rosehillbob and 1 guest
