Bug in neko_sqlite3?
nongrato
Unread postby nongrato » Tue Jan 06, 2015 4:12 pm
If this package is installed, Thunderbird crashes with the following message:
2541:/usr/nekoware/lib/thunderbird-2.0.0.23/thunderbird-bin: rld: Fatal Error: attempted access to unresolvable symbol in /usr/nekoware/lib/thunderbird-2.0.0.23/thunderbird-bin: sqlite3_os_switch
Once neko_sqlite3 is removed, Thunderbird functions normally again.
:Octane2: :320:
Re: Bug in neko_sqlite3?
Unread postby hamei » Tue Jan 06, 2015 10:16 pm
nongrato wrote:If this package is installed, Thunderbird crashes ...
This happened with firefox, too. Firefox eventually built its own internal sqlite. Not sure exactly where the problem is but it's not exclusive to neko sqlite .... there's theads about it here dating back to several years ago. If you need both you can make it work but I forget how.
diegel
Unread postby diegel » Tue Jan 06, 2015 11:20 pm
The problem is fixed (linked with rpath) in the thunderbird and seamonkey versions in beta. I think it's a good idea to move these beta versions after more than two years to current. The problem is also fixed in all current versions of firefox.
