Can someone build a ResidualVM package?
eudatux23
Unread postby eudatux23 » Tue Jan 06, 2015 4:01 am
Hi,
I just found out, that ResidualVM seems to be buildable in IRIX if I see this link correctly:
https://github.com/residualvm/residualv ... dists/irix
Sadly I don't have a compiler here. Can someone build a pakage out of it?
With such a package, many old LucasArts 3D adventure games like Grim Fandango would work on our SGI machines!
Thanks in advance
:Octane2: SGI Octane 2 - Dual R12K 400 MHz - 250 0MB RAM - 73 GB HDD - vPro v12 - IRIX 6.5.30
:Indigo2IMP: SGI Indigo² - R10K 175 MHz - 320 MB RAM - 73 GB SCSI HDD - High Impact-AA + TRAM - IRIX 6.5.22f
:O2: SGI O2 - R5K 180 MHz - 96 MB RAM - 18 GB HDD - CRM - IRIX 6.5.30
nongrato
Re: Can someone build a ResidualVM package?
Unread postby nongrato » Wed Jan 07, 2015 3:06 am
Unfortunately.
engines/grim/emi/sound/track.cpp: In member function `void Grim::SoundTrack::updatePosition()':
engines/grim/emi/sound/track.cpp:89: error: `isfinite' was not declared in this scope
engines/grim/emi/sound/track.cpp:89: warning: unused variable 'isfinite'
engines/grim/emi/sound/track.cpp: In member function `int Grim::SoundTrack::getEffectiveVolume()':
engines/grim/emi/sound/track.cpp:149: warning: converting to `int' from `float'
gmake: *** [engines/grim/emi/sound/track.o] Error 1
:Octane2: :320:
Unread postby jan-jaap » Wed Jan 07, 2015 3:21 am
isfinite() is C99 and MIPSpro doesn't allow C99 features in C++.
The underlying primitives:
extern int _isfinite(double);
extern int _isfinitef(float);
extern int _isfinitel(long double);
are in libm (I think, could be libc).
You just need the isfinite() macro, then:
#define isfinite(x) \
     (sizeof (x) == sizeof (float)                                            \
      ? _isfinitef (x)                                                         \
      : sizeof (x) == sizeof (double)                                         \
      ? _isfinite (x) : _isfinitel (x))
(not tested, but you'll figure it out)
eudatux23
Unread postby eudatux23 » Wed Jan 07, 2015 5:43 am
May it work when building with GCC instead of MIPSpro?
nongrato
Unread postby nongrato » Wed Jan 07, 2015 10:12 am
I thought I tried it with gcc. I'll check later.
:Octane2: :320:
Unread postby foetz » Wed Jan 07, 2015 1:36 pm
nongrato wrote:I thought I tried it with gcc. I'll check later.
yes, the error output you posted is gcc
joostp
Unread postby joostp » Mon Jan 12, 2015 4:13 pm
While the current 0.2.0 release of ResidualVM should compile without problems (it does for me, anyway), it has a bug that makes Grim Fandango not work on IRIX.
This issue has been fixed for the next release. When that comes out I'll do an 'official' IRIX build that can be grabbed from the ResidualVM downloads page.
eudatux23
Unread postby eudatux23 » Tue Jan 13, 2015 1:53 am
joostp wrote:While the current 0.2.0 release of ResidualVM should compile without problems (it does for me, anyway), it has a bug that makes Grim Fandango not work on IRIX.
Great! Can't wait for it and play Grim Fandango on my Octane! Thanks! :)
joostp
Unread postby joostp » Sun Jan 25, 2015 10:57 am
ResidualVM 0.2.1 has been released now.
It would be good to know how well it works on your octane 2 (hardware and software renderer).
eudatux23
Unread postby eudatux23 » Sun Jan 25, 2015 2:47 pm
Thank you very very very much! :)
I will try it in the next days and give you informations about how it runs on my machine.
joostp
Unread postby joostp » Fri Feb 06, 2015 6:00 am
Any luck?
Unread postby hamei » Sun Feb 08, 2015 7:12 am
joostp wrote:Any luck?
I can't tell you anything about how it works cuz I have no game experience at all, but it opens and the buttons that aren't greyed out work. It doesn't crash or complain to the console.
Thank you.
eudatux23
Unread postby eudatux23 » Wed Feb 18, 2015 3:23 pm
Hi,
sorry that I only reply this late.
I tested it yesterday on my Octane with V12. It kind of works but with a low framerate of approximately 10 fps. Also there seem to be some glitches, i.e. Manny walking over a table etc. When the glitches appear, it also writes stuff into the terminal, which I will post here on Saturday. In Software Mode the Framerate is a bit better than in OpenGL mode, but the colors are a bit washed out. I will create a video to further describe it on Saturday and will post it here then.
Anyway, thank you very very much for making it possible to run Grim Fandango on IRIX. :)
eudatux23
Unread postby eudatux23 » Sat Feb 21, 2015 11:44 am
I just made a video showing Grim Fandango in ResidualVM using both OpenGL and software renderer:
joostp
Unread postby joostp » Sun Feb 22, 2015 1:09 pm
Thanks for the feedback and recording the video. It's best to report this bug directly on the ResidualVM issue tracker.
I've noticed the same z-buffer issue on my Fuel with V10. It's been a while since I've tried it on my Octane with (E)SI graphics, but seem to remember it being okay on that, so perhaps it's a VPro-specific issue. It would be interesting to see how well it fares on your O2...
Users browsing this forum: Google [Bot], Yandex [Bot] and 1 guest
