Comix 0.3 - a CBZ/CBR viewer for IRIX.
jimmer
Unread postby jimmer » Tue Jan 07, 2014 5:15 pm
Hi All,
New project is underway. Still very early days, but we gotta start someplace.
What does it do?
Comix unpacks a cbr/cbz file and then displays it page by page via OpenGL.
Where is it?
http://sillypages.org/sgi/comix/
How do I make it?
0. Build and install my VkNew library
1. Unpack comix and modify the Compiler flags at the top of the Makefile to suit your setup.
2. Build comix.
Both VkNew and comix should compile cleanly with MIPSpro and GNU make.
If you want to have a looksey at the code, run the 'resume' script. It will load the relevant files into nedit for you. As ever, I disclaim being any good at writing C++, all I can say is that the code compiles for me on redbox.
How do I use it?
0. File->Open to open a cbz/cbr file.
1. [right arrow] or [down arrow] to go to next page.
2. [left arrow] or [up arrow] to go previous page.
3. [PgUp] to jump to the beginning of the 'comic'.
4. [PgDn] to jump to the end of the 'comic'.
5. Resize the window to force comix to display the whole page.
Major Caveat: the filename handling in Comix is fragile. In particular, jpeg filenames inside the cbz/cbr files with CR/LF stuck to their names, wont display properly. Fixing this is on the TODO list.
Dassit for now.
J.
:Fuel: redbox 800Mhz 4Gb V12
Re: Comix 0.3 - a CBZ/CBR viewer for IRIX.
Unread postby hamei » Sat Jan 11, 2014 6:53 am
jimmer wrote: New project is underway.
I hate you. My /usr/local was a read-only empty file ... anyway, good chance I am doing this wrong but
fool 29# gmake
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c Globals.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c App.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c Main.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c UI.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c Viewer.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c Reader.C
CC -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c VkOpenGL.C
cc-3970 CC: WARNING File = VkOpenGL.C, Line = 75
  conversion from pointer to same-sized integral type (potential portability
          problem)
        XtSetArg(args[0], GLwNvisualInfo, (XtArgVal) visInfo);
CC Globals.o App.o Main.o UI.o Viewer.o Reader.o VkOpenGL.o -L/usr/local/lib -lifl -lvk -lvknew -lGLw -lGLU -lGL -lSgm -lXm  -lXt -lX11 -lPW  -lC -lCio -lm -woff 15,84 -o comix
--- C++ prelinker: Globals.o ---
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 Globals.C
--- C++ prelinker: App.o ---
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 App.C
--- C++ prelinker: Reader.o ---
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 Reader.C
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 Globals.C
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 App.C
 CC -DEFAULT:abi=n32:isa=mips4:proc=r10k -DEFAULT:abi=n32:isa=mips4:proc=r10k -O3 -r16000 -LANG:std -DDEBUG -I. -I/usr/local/include -c -n32 Reader.C
ld32: ERROR   33 : Unresolved text symbol "getAppFileSelectionDialog(VkComponent*)" -- 1st referenced by UI.o.
        Use linker option -v to see when and which objects, archives and dsos are loaded.
ld32: ERROR   33 : Unresolved text symbol "getAppProgressDialog(VkComponent*)" -- 1st referenced by Reader.o.
ld32: ERROR   33 : Unresolved text symbol "VkApp::getGlobalData(void)" -- 1st referenced by App.o.
ld32: ERROR   33 : Unresolved text symbol "VkApp::newDisplay(char*,char*,int*,char**,void*)" -- 1st referenced by App.o.
ld32: ERROR   33 : Unresolved text symbol "VkApp::newScreen(char*,VkDisplay*,Arg*,unsigned int,void (*)(_WidgetRec*),void*)" -- 1st referenced by App.o.
ld32: ERROR   33 : Unresolved text symbol "VkComponent::getGlobalData(void)" -- 1st referenced by UI.o.
ld32: ERROR   33 : Unresolved text symbol "VkComponent::getScreen(void)" -- 1st referenced by Viewer.o.
ld32: INFO    152: Output file removed because of error.
gmake: *** [comix] Error 2
fool 30# cd /usr/local/include
fool 31# ls
VkNew
fool 32# cd VKNew
VKNew - No such file or directory
fool 33# ls
VkNew
fool 34# cd VkNew
fool 35# ls
VkConfig.h      VkEntry.h        VkProgress.h  VkTimer.h
VkConfigItem.h  VkEntryFinder.h  VkSplash.h
It looks like we were looking in /usr/local/include but the VkNew headers are all in /usr/local/include/VkNew ?
Unread postby foetz » Sat Jan 11, 2014 9:27 am
overhauled the makefiles a bit. give them a try, worked for me.
vknew:
LIB_NAME   = vknew
LIB_NAME_DIR   = VkNew
LIB_MAJOR   = 0
LIB_MINOR   = 7
LIB_TARGET   = /usr/local/jimmer
LIB_DIR    = lib
INC_DIR    = include
MAN_DIR    = man
INCDIRS    = -I. -I/usr/include
LIBDIRS    = -L/usr/lib32
STDLIBS      = -lm
STDCPPLIBS    = -LC -lCio
X11LIBS    = -lXpm -lXt -lX11 -lPW
MOTIFLIBS    = -lSgm -lXm
VKLIBS       = -lvk
LIBS       = $(VKLIBS) $(MOTIFLIBS) $(X11LIBS) $(STDCPPLIBS) $(STDLIBS)
CXX      = CC
CXXOPTS    = -O3 -LANG:std -LANG:exceptions=off -OPT:Olimit=0
LIB_OBJS =    VkEntry.o      \
         VkEntryFinder.o   \
         VkConfig.o      \
         VkConfigItem.o   \
         VkSplash.o      \
         VkTimer.o      \
         VkProgress.o
all : lib
lib : $(LIB_OBJS)
   $(CXX) -shared -o ../$(LIB_DIR)/lib$(LIB_NAME).so $(LIB_OBJS)
   cp *.h ../$(INC_DIR)
install:
   mkdir -p $(LIB_TARGET)/$(LIB_DIR) $(LIB_TARGET)/$(INC_DIR)/$(LIB_NAME_DIR) $(LIB_TARGET)/$(MAN_DIR)/man3
   cp ../$(LIB_DIR)/* $(LIB_TARGET)/$(LIB_DIR)
   ln -sf $(LIB_TARGET)/$(LIB_DIR)/lib$(LIB_NAME).so $(LIB_TARGET)/$(LIB_DIR)/lib$(LIB_NAME).$(LIB_MAJOR).$(LIB_MINOR).so
   if test -d $(LIB_TARGET)/$(INC_DIR)/$(LIB_NAME_DIR); then echo "$(LIB_TARGET)/$(INC_DIR)/$(LIB_NAME_DIR) exists."; else mkdir $(LIB_TARGET)/$(INC_DIR)/$(LIB_NAME_DIR); fi
   cp ../$(INC_DIR)/* $(LIB_TARGET)/$(INC_DIR)/$(LIB_NAME_DIR)
   cp ../$(MAN_DIR)/* $(LIB_TARGET)/$(MAN_DIR)/man3
%.o : %.C
   ${CXX} ${CXXOPTS} ${INCDIRS} -c $<
clean :
   rm -rf $(LIB_DIR)/*
   rm -rf $(INC_DIR)/*
   rm -rf *.o core *~ ii_*
comix:
CXXC      = CC
CXXC_OPTS    = -O3 -LANG:std -LANG:exceptions=off -OPT:Olimit=0
APP_NAME    = comix
APP_OBJS    = \
      Globals.o   \
      App.o      \
      Main.o       \
      UI.o      \
      Viewer.o   \
      Reader.o   \
      VkOpenGL.o
DIRS_INC    = -I. -I/usr/local/jimmer/include
DIRS_LIB   = -L/usr/local/jimmer/lib
LIBS_STD_C   = -lm
LIBS_STD_CXX= -lC -lCio
LIBS_X11   = -lXt -lX11 -lPW
LIBS_MOTIF   = -lSgm -lXm
LIBS_OPENGL   = -lGLw -lGLU -lGL
LIBS_VK    = -lvk -lvknew
LIBS_EXTRA    = -lifl
LIBS      = $(LIBS_EXTRA)    \
           $(LIBS_VK)       \
           $(LIBS_OPENGL)    \
           $(LIBS_MOTIF)      \
           $(LIBS_X11)      \
           $(LIBS_STD_CXX)   \
           $(LIBS_STD_C)
# Suppress MIPSpro compiler warnings:
# 15 - Multiply defined
# 84 - libxxx not used for resolving any symbol
LINK_OPTS   = -woff 15,84
all : $(APP_NAME)
$(APP_NAME): ${APP_OBJS}
   ${CXXC} ${APP_OBJS} ${DIRS_LIB} ${LIBS} ${LINK_OPTS} -o ${APP_NAME}
%.o : %.C
   ${CXXC} ${CXXC_OPTS} ${DIRS_INC} -c $<
clean :
   rm -rf ${APP_NAME} *.o core *~ ii_* dir.txt
just in case i attached the finished package. just add its lib dir to the LD_LIBRARYN32_PATH.
in case of a dso that's only used for one program a static build usually is better. jimmer might consider that.
comix_03.tar.bz2
(182.37 KiB) Downloaded 62 times
Unread postby hamei » Sat Jan 11, 2014 8:26 pm
Thanks, j & f. My excuse is, I only had about ten minutes to play with it, otherwise the dog would pee on the floor ...
It opens, it runs, kind of interesting. I had no problems with file handliing. Some things :
The splash screen is nice, could you replace the Help -> Product Information with that or is that something we are stuck with ? I've always thought that the About screens in Irix were awful. $10,000 application and the About looks like some spastic kindergartener created it.
Grabbed a comic for test, whoo boy. Spears into flaming eye sockets, hunh ? :P
Display is excellent, sharp as a tack. However, at high resolution, I can't see an entire page. And there's no sliders ... not that I'd want sliders, resizing the page would be better.
foetz has a good point, for most people a single executable would be more convenient. It's not very big.
This could become the quick-n-dirty graphics application for Irix. I can see where it could do everything that Pho and the other thingy I found do. In fact, it could be SGI's Answer to Irfanview .... nice, J. Real nice.
Where's all the guys who want to open source Irix ? Time to step up to the plate and make yourselves useful ...
edit : ah. I see what happens with the size. In the vertical direction, if you expand the window, the display grows until it hits the horizontal width of the window. Then it adds a grey area above the size of the jpg. In the horizontal direction, if you widen the display window it grows right out the top of the screen without adding a slider bar or hitting a limit and adding an empty area. Easy to work around for the moment, but I would think that eventually the slider bars would be necessary, in case you want to zoom in on one area.
Are these comics all pornography without the sex, or just the one I grabbed ? It's kind of ... interesting :shock:
edit_2 : ah_again ... Made a comic book by zipping up a bunch of jpegs. We scooted right through the stack nicely. Lots of interesting possibilities. Now if I can just talk the Assistant into doing a little posing ... "It's for a comic book ! really !" :P
jirka
Unread postby jirka » Sun Jan 12, 2014 2:45 am
foetz wrote:just in case i attached the finished package.
Thank your for the compiled version! It works on my O2 (IRIX 6.5.27).
jirka
Unread postby jirka » Sun Jan 12, 2014 2:48 am
jimmer wrote:Hi All,
J.
Thanks! It is quite fast on my O2 (R10k/250).
jimmer
Unread postby jimmer » Thu Jan 16, 2014 5:15 am
foetz wrote:in case of a dso that's only used for one program a static build usually is better. jimmer might consider that.
Fair point. I have removed the dependency on VkNew. For extra Hamei Happiness this means there's also nothing going on in /usr/local anymore. Downside is that there's no pretty splash screen for the moment.
hamei wrote:The splash screen is nice, could you replace the Help -> Product Information with that or is that something we are stuck with ? I've always thought that the About screens in Irix were awful. $10,000 application and the About looks like some spastic kindergartener created it.
ViewKit giveth, ViewKit taketh away. I'm using the stock viewkit 'about' stuff. That said, it is possible to override the default ViewKit help menu. Issue added to the very bottomest bottom of the TODO list.
hamei wrote:However, at high resolution, I can't see an entire page. And there's no sliders ... not that I'd want sliders, resizing the page would be better.
I've changed the scaling and centering in 0.3.1. Please report back if this issue is solved.
Changes in 0.3.1:
- removed dependency on VkNew
- better image scaling and centering in the viewing window
- added a little statusbar thingy
comix-0.3.1.tar.gz
C++ sources
(199.95 KiB) Downloaded 59 times
Unread postby foetz » Thu Jan 16, 2014 8:55 am
oh i didn't mean ditching it but rather having a static build.
anyway binary attached ...
comix_031.bz2
6.5, mips4
(49.08 KiB) Downloaded 66 times
Unread postby hamei » Fri Jan 17, 2014 12:18 am
Don't hate me ...
jimmer wrote:Fair point. I have removed the dependency on VkNew.
I can't actually tell the difference but thought the same as foetz, VkNew is good, just static that hummer. It's small, we don' need no steenking dso's :D
<does ecstatic but tasteful dance of joy in living room. Dog looks up bemused, 'Hope it's not something in the water. They just refilled my bowl. Did I drink out of that yet ?">
Well, I never ! I'm going to have a word with your agent, young man ...
jimmer wrote:I've changed the scaling and centering in 0.3.1. Please report back if this issue is solved.
It's ... different. Keep in mind that these are extreme numbers, so if it works here you probably won't have a problem with smaller sizes.
The image auto-centers now, that's nice.
As you drag the lower edge of the window down and down, the image gets larger and larger until ... poof ! it disappears. Drag the bottom edge back up and it reappears. Drag the side of the window frame and the image continuously self-centers (appropriate for today's society) until it reaches a certain point, then smallens in vertical height.
I dunno. For reading a comic book, this way is good. For zooming in on the gratuitous panty shots, the other way was better. Not sure what to say here ... but maybe I preferred the other method, since it was a little more versatile.
Little is the operative word :D Not a bad idea, tells you where you are in the series of jpegs.
Reader::navigate() - page: 2
Reader::navigate() - page: 3
Reader::navigate() - page: 4
Reader::navigate() - page: 5
Reader::navigate() - page: 6
Reader::navigate() - page: 7
Reader::navigate() - page: 24
However, don't think I saw the following before ? No idea what it means ?
RGB, unsigned char
RGB, unsigned char
RGB, unsigned char
RGB, unsigned char
RGB, unsigned char
Is it a little faster, or is that just because I'm looking at a smaller version ?
Unread postby foetz » Fri Jan 17, 2014 6:33 am
hamei wrote:Is it a little faster, or is that just because I'm looking at a smaller version ?
i used 2 more compiler options but i'm not sure if it'd have a noticeable impact
jimmer
Unread postby jimmer » Fri Jan 17, 2014 11:51 am
Comix version 0.3.2:
- Core: improved filename handling
- Core: rewritten unpack/load routines
- Core: opens CBZ/CBR file where you left off
- UI: filename now shown in window title bar
- UI: page numbers centered under image
- Makefile: a little more quiet
The opens-where-you-left-off thing is a little slow at the moment when you restart comix after having loaded a large comic. This will improve when the 'load each image from disk' option is implemented.
Also there's a buglet with the pagination on the first and last images; the usual off by 1 thing. Hopefully fixed in 0.3.3.
J.
comix-0.3.2.tar.gz
C++ sources
(200.11 KiB) Downloaded 61 times
Unread postby hamei » Sat Jan 18, 2014 3:56 am
jimmer wrote:Comix version 0.3.2:
I guess this is no worse than self-criticism, but I'm having a linking problem :(
What can I say ? I'm stoopid :(
Unread postby foetz » Sat Jan 18, 2014 7:40 am
jimmer, any reason why you don't attach a build with the source?
jimmer
Unread postby jimmer » Sat Jan 18, 2014 9:44 am
Not really. I'll move up the FTR+packaging bullet on the TODO list so the next 'progress drop' will be a full tardist.
Unread postby vishnu » Sat Jan 18, 2014 10:37 am
hamei wrote:I guess this is no worse than self-criticism, but I'm having a linking problem :(
Sounds like you're not linking to the Viewkit library, which IIRC is libiVk.so - no idea why there's an "i" between the lib part and the Vk part but then again who knows why sgi did anything the way they did... :lol:
