It is currently Thu May 23, 2013 11:06 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: uint64_t support
Unread postPosted: Thu May 24, 2012 5:41 pm
Hi all!!
Is this data type uint64_t supported in O2, and previous SGI machines?
I'm trying to so something portable across SGI machines, but I´m not sure if this is supported in old machines.
Thanks in advance, guys!!
__Zacatito__Image 600 MHZ R14000; 17GBytes HD
__Nopalito__Image 200 MHZ R5000; 9GBytes HD
Guadalajara, Jal and Aguascalientes, Ags
Mexico
 Post subject: Re: uint64_t support
Unread postPosted: Fri May 25, 2012 1:31 am
BSDero wrote:
Hi all!!
If uint64_t is supported depends on the compiler, not on the machine.
If you use uint64_t with a 32-bit-compiler, the 64-bit-arithmetics is
emulated with 32-bit-commands.
Unread postPosted: Fri May 25, 2012 1:41 am
Any CPU since the R4000 can do 64bit arithmetic as long as you use the N32 or 64 ABI.
uint64_t is defined in <inttypes.h> and <sys/types.h>
Unread postPosted: Tue May 29, 2012 1:15 pm
What if I'm building a kernel module using uint64_t in a Fuel/Irix 6.5.30?
It's compatible backwards to, maybe O2 with 6.5.x?? Would it run on this machine?
Will be binary compatibility at kernel/driver level?
Thanks in advance guys
Mexico
Unread postPosted: Wed May 30, 2012 12:24 am
I have no experience with building kernel modules. Are you building
a 32- or 64-Bit Kernel?
If you use the "-mips4" compiler-flag (I asume you have the MipsPro-compiler),
the generated code uses the full MIPS IV instruction set, which is supported
on R10000, R5000 and R8000 systems. O2 has a R5000, AFAIK.
http://techpubs.sgi.com/library/tpl/cgi-bin/getdoc.cgi?coll=0650&db=man&fname=/usr/share/catman/u_man/cat1/cc.z
Unread postPosted: Wed May 30, 2012 12:36 am
There is no binary compatibility. Kernel object code (and modules) is compiled separately for each IPxx family (IP27, IP35, IP32, ...).
Additionally, IP32 (the O2) uses 32bit pointers, the rest is 64bit.
Unread postPosted: Fri Jun 01, 2012 12:00 pm
I forgot completely that point about Kernel objects code, but it's true.
Well, i'm cooking something interesting, but I think more work is needed before have something useful.
Thank you guys.
Mexico
