IRIX's libm is terrible
Re: IRIX's libm is terrible
Unread postby SAQ » Mon Nov 22, 2010 6:50 pm
DSO libraries aren't a problem, and I don't think that static libraries are either. Where the problem has come up is in linking object files from GCC and MIPSpro, but I think that the GCC folks were working on that a couple of years ago.
legalize
Unread postby legalize » Sun Aug 12, 2012 9:24 am
SAQ wrote:DSO libraries aren't a problem, and I don't think that static libraries are either. Where the problem has come up is in linking object files from GCC and MIPSpro, but I think that the GCC folks were working on that a couple of years ago.
For DSOs with C linkage I don't expect there to be a problem as long as the C runtimes are compatible and both the DSO and the executable use the same C runtime.
For DSOs with C++ linkage, you'll need to use the same name mangling technique between MIPSpro and gcc or the symbols won't resolve.
However, a static library just a bag of .o files really, so if there is a problem mixing .o files between compiler toolchains, then I would expect that static libraries would have the same problem.
