neko_supertuxkart-0.5 uploaded to incoming
emachine
Unread postby emachine » Sun Jul 13, 2008 10:40 am
Heres a screenshot:
Its a pretty big tardist... ~128meg.
Runs fine on the Tezro :D
Best regards,
emachine
bplaa.yai
Re: neko_supertuxkart-0.5 uploaded to incoming
Unread postby bplaa.yai » Sun Jul 13, 2008 10:47 am
emachine wrote:Runs fine on the Tezro :D
The question is... does it run on anything else than a Tezro ? ;)
:Onyx2: :O2: :O3x0: :O3x0:
fzalfa
Unread postby fzalfa » Mon Jul 14, 2008 3:40 am
got an error......on Octane2 V6
./supertuxkart -w
Data files will be fetched from: '/usr/nekoware/share/games/supertuxkart/'
Config file '//.supertuxkart/config' does not exist, it will be created.
Highscores will be saved in '//.supertuxkart/highscore.data'.
Music information file 'Ethereal_Spectrum_(ver_loop).music' not found - ignored.
Can't find music file 'Ethereal_Spectrum_(ver_loop).music' - ignored.
FATAL: ssgInit called without a valid OpenGL context.
any idea ?
SGI or die !!!
emachine
Unread postby emachine » Mon Jul 14, 2008 9:51 am
Interesting. I don't believe its related to the music files because I see the same two lines and runs just fine.
Google search looks like its not an IRIX only "problem"? Most references say that its a problem with the GL library (which seems unlikely to me). Would be interesting to see what others see?
Emachine
deBug
Unread postby deBug » Mon Jul 14, 2008 10:33 am
emachine wrote:Interesting. I don't believe its related to the music files because I see the same two lines and runs just fine.
Emachine
I'll see If I can have a go at it tonight when I get home.
Mein Führer, I can walk!
VenomousPinecone
Unread postby VenomousPinecone » Mon Jul 14, 2008 11:01 am
ancalagon 11% /usr/nekoware/games/supertuxkart
95774:/usr/nekoware/games/supertuxkart: rld: Fatal Error: Cannot Successfully map soname 'libopenal.so.0' under any of the filenames /usr/nekoware/lib/libopenal.so.0:/usr/lib32/libopenal.so.0:/usr/lib32/internal/libopenal.so.0:/lib32/libopenal.so.0:/opt/lib32/libopenal.so.0:
It let me install supertuxkart without telling me about openal, so I went and installed openal from nekoware.
ancalagon 12% /usr/nekoware/games/supertuxkart
Segmentation fault (core dumped)
And now this happens.
NOTE You cannot use Virtual Disk Manager to create or to shrink physical hard drives.
deBug
Unread postby deBug » Mon Jul 14, 2008 4:52 pm
emachine wrote:Heres a screenshot:
Best regards,
emachine
Runs pretty well on fuel 600MHz V12 as well.
Sound, working.
Swedish language in menus with no config., go figure.
controls working.
Screen settings not working, always the same size, by design ??
Most games run fine!!!
Great job! another game to IRIX.
update. is to slow on O2 600MHz (5-10fps)
emachine
Unread postby emachine » Mon Jul 14, 2008 6:23 pm
Heres a list of the library dependencies on my box. I need to do a better job of getting the library dependencies in the tardist, was kind of in a hurry when I put this together.
        libglut.so  =>   /usr/nekoware/lib/libglut.so
        libGLU.so  =>    /usr/lib32/libGLU.so
        libGL.so  =>     /usr/lib32/libGL.so
        libintl.so.4  =>         /usr/nekoware/lib/libintl.so.4
        libSDL-1.2.so.1  =>      /usr/nekoware/lib/libSDL-1.2.so.1
        libopenal.so.0  =>       /usr/nekoware/lib/libopenal.so.0
        libvorbisfile.so.4  =>   /usr/nekoware/lib/libvorbisfile.so.4
        libalut.so.1  =>         /usr/nekoware/lib/libalut.so.1
        libCsup.so  =>   /usr/lib32/libCsup.so
        libCio.so.1  =>  /usr/lib32/libCio.so.1
        libXmu.so  =>    /usr/lib32/libXmu.so
        libXi.so  =>     /usr/lib32/libXi.so
        libGLcore.so  =>         /usr/lib32/libGLcore.so
        libXsgivc.so  =>         /usr/lib32/libXsgivc.so
        libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
        libaudio.so  =>  /usr/lib32/libaudio.so
        libdl.so  =>     /usr/lib32/libdl.so
        libvorbis.so.1  =>       /usr/nekoware/lib/libvorbis.so.1
        libogg.so.1  =>  /usr/nekoware/lib/libogg.so.1
        libXt.so  =>     /usr/lib32/libXt.so
        libgen.so  =>    /usr/lib32/libgen.so
VenomousPinecone
Unread postby VenomousPinecone » Mon Jul 14, 2008 7:10 pm
emachine wrote:Heres a list of the library dependencies on my box.
Ah, thank you sir. I shall check tomorrow when in front of the machine.
Unread postby nekonoko » Mon Jul 14, 2008 11:31 pm
Tried it on my Onyx2 IR3 - runs fine on it too ;)
deBug wrote:Screen settings not working, always the same size, by design ??
Same - seems to have the choice of running in a window or running "full screen" with identical output centered in the middle of the screen.
Nice job - looks and runs great!
VenomousPinecone
Unread postby VenomousPinecone » Tue Jul 15, 2008 2:09 pm
I checked and I have everything, but it is still core dumping.
Mark_G
Unread postby Mark_G » Tue Jul 15, 2008 5:26 pm
Works fine on a Fuel 1600 MHZ MIPS R14k + V12 and 2 GB Ram.
Sound works fine, together with xmms :!:
Strange to see all text in Dutch, but translation is well done.
Mark
VenomousPinecone
Unread postby VenomousPinecone » Wed Jul 16, 2008 12:37 pm
Mark_G wrote:Works fine on a Fuel 1600 MHZ MIPS R14k + V12 and 2 GB Ram.
Mark
I guess it is just me then...
I am uninstalling it now, I will try again with the next release. :?
Dr. Dave
Unread postby Dr. Dave » Thu Jul 17, 2008 7:06 am
Worked fine on both a Fuel R14k and an Octane dual R12k-400 here.
Unread postby hamei » Mon Jul 21, 2008 8:03 pm
Mark_G wrote:Works fine on a Fuel 1600 MHZ ...
I want that one. Very much. Better lock your doors. :P
