It is currently Sun May 19, 2013 7:21 pm
Post new topic Reply to topic  [ 5 posts ]
 Post subject: ImageVision alternative
Unread postPosted: Sat Jan 31, 2004 5:15 am
Unfortunatelly my system did not come with ImageVision development environment installed. Is there an alternative library for image processing? What I really need though is simple image I/O supporting many formats.
Thanks
Vassilis
 Post subject:
Unread postPosted: Sat Jan 31, 2004 6:15 am
We've had that question before. Basically there are libraries like imlib or ImageMagick which support lots of formats and can do lots of manipulation for you. So check out these packages at freeware.sgi.com.
These are not a drop-in replacement for ImageVision, so recoding some source is required, if you have existing code.
 Post subject: Re
Unread postPosted: Sat Jan 31, 2004 6:27 am
Basically I have some code in Java using the Advanced Imaging API and the javax.ImageIO library.... but it
is very very slow on my O2 and I would like to
try it using something else. I use JPEG images for input and my output is in PNG format.
 Post subject: Re: Re
Unread postPosted: Sat Jan 31, 2004 6:47 am
Hmm... I think that what you are looking for is the development environment of IFL (Image Format Library), which is available on the standard IRIX distro. For the ImageVision sdk, indeed, you are right in that is not directly available with IRIX (only the runtime environment is).
Andrea
 Post subject:
Unread postPosted: Thu Feb 26, 2004 12:07 pm
try http://perso.wanadoo.fr/pierre.g/xnview/engfl.html
r-a-c.de
