It is currently Wed Jun 19, 2013 6:25 am
Post new topic Reply to topic  [ 13 posts ]
 Post subject: Indigo 2 XZ (R4600)
Unread postPosted: Sun Oct 02, 2005 9:25 am
I've got just another one of the weirder Indigo 2 models (the other being the R8000):
Code:
CPU: MIPS R4600 Processor Chip Revision: 2.0
FPU: MIPS R4600 Floating Point Coprocessor Revision: 2.0
1 133 MHZ IP22 Processor
Main memory size: 96 Mbytes
Secondary unified instruction/data cache size: 512 Kbytes on Processor 0
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: GR3-Elan
EISA bus: adapter 0
Code:
        4 GEs, 1 RE, 24 bitplanes, 4 auxplanes, 4 cidplanes, Z-buffer
        GR2 revision 4, VB2.0
        HQ2.1 rev A, GE7 rev B,  RE3.1 rev A, VC1 rev B, MC rev C
        unknown, assuming 19" monitor
 Post subject:
Unread postPosted: Sun Oct 02, 2005 9:42 am
Wow, didn't know they made an R4600 Indigo2.
-ks
:Onyx: :Onyx: :Crimson: :O2000: :Fuel: :Octane: :Octane2: :PI: :Indigo: :Indigo: :O2: :O2: :Indigo2: :Indigo2: :Indigo2IMP: :Indigo2IMP: :0300: :Indy: :Indy: :320: :540: :1600SW: :1600SW: :hpserv:
See them all >here<
 Post subject:
Unread postPosted: Sun Oct 02, 2005 9:51 am
I only read about them so far... but this one is real and sitting right next to me. The CPU module (I'll upload pics these days) looks like a R4400 module with the large heatsink removed and a small one glued to the CPU itself.
Found it on Ebay last week and I just had to get it - although it was the most lowend of 3 Indigo2 being sold by the same seller. I'll probably try to add the FHVJR video board. Probably can't make much use of it (as I dont have the BOB), but at least there is a useable IndyCam port.
Gerhard
 Post subject: Upgrade
Unread postPosted: Tue Oct 04, 2005 8:46 am
It's done, it is now equiped with the board... all I need is the BOB and the cable, I guess. ;-)
Code:
Indigo2 video (ev1): unit 0, revision 3.
EISA bus: adapter 0
Code:
        Video board revision 3
 Post subject:
Unread postPosted: Tue Oct 04, 2005 2:24 pm
Yeah, I could use an extra also, have three Indigo2's with the ev1 boards and only two BOBes :(
-ks
See them all >here<
 Post subject:
Unread postPosted: Thu Oct 27, 2005 8:30 am
Hey Gerhard, any chance of you dumping the PROM for me? I can show you how via a serial cable. :)
 Post subject:
Unread postPosted: Sat Oct 29, 2005 6:22 am
Chances are quite good... I'll fetch it from storage to see what PROM revision it claims to have.
I've tried some of the I2/Indy I have around here during the "PROM dumping" thread including my R8K but nothing turned up that hadn't already been posted. Maybe the R4600 has something new though...
Gerhard
 Post subject:
Unread postPosted: Sat Oct 29, 2005 8:53 am
Alrighty. Just do a "version" in the command monitor and compare it against the list of versions that I have that I posted in the "PROM Archive" thread in the SGI Hardware forum, so you can save yourself the trouble of dumping it if it's already there.
 Post subject:
Unread postPosted: Sun Nov 06, 2005 8:51 am
I've got it up and running beside me now and I think you already have the PROM:
Code:
PROM Monitor SGI Version 5.3 Rev C IP22 Oct 20, 1994 (BE)
Does the "(BE)" mean anything?
Gerhard
 Post subject:
Unread postPosted: Sun Nov 06, 2005 10:47 am
"Big-Endian". And yup, I already have the PROM.
 Post subject:
Unread postPosted: Sun Nov 06, 2005 12:26 pm
Oops... it's that easy? Hmmm... is there any reason they specifically mention Big Endian? ACE/ARC?
 Post subject:
Unread postPosted: Thu Nov 10, 2005 3:42 am
oly 512K of cache? itneresting.
My R4000 indigo2 has 1MB...
 Post subject:
Unread postPosted: Thu Nov 10, 2005 5:39 am
Rumour has it that there was a modified version of the Indigo2 that ran Windows NT, and that the modification was mostly a different PROM.
NT on MIPS hardware was little endian, and so any PROM used to boot into NT must have been LE as well.
There is also a rumour that NT ran on a modified Indigo(1), and late Indigo PROM revisions have the BE tag as well. Coincidence? Let the conspiracy theories begin ...
