Indigo2 Killer Impact
codemonkey
Unread postby codemonkey » Tue May 17, 2005 11:20 am
Well, as I now have a console going to my lovely machine, I can post it's hinv. It's pretty much just a standard I2 Killer Impact.
IRIS 7# hinv
1 175 MHZ IP28 Processor
On-board serial ports: 2
Main memory size: 192 Mbytes
EISA bus: adapter 0
Graphics board: Solid Impact
Even the reverse side has a reverse side - Japanese Proverb
