1 R12k 300mhz, ESI. SI, ESI, 896mb, Xbow 1.3, Irix 6.5.22
OSWebman
Unread postby OSWebman » Wed Mar 17, 2004 8:04 pm
My new system running 6.5.22
hinv -vm:
PM10300MHZ Board: barcode HKW763 part 030-1355-001 rev K
IP30 Board: barcode JEZ981 part 030-1467-001 rev B
PWR.SPPLY.ER Board: barcode AAE9050592 part 060-0035-001 rev C
FP1 Board: barcode JLR735 part 030-0891-003 rev E
MOT10 Board: barcode HRG178 part 030-1241-002 rev G
GM10 Board: barcode FEP305 part 030-0938-003 rev Z
GM10 Board: barcode FGX376 part 030-0938-003 rev N
1 300 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 896 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: ESI
Graphics board: SI
Graphics board: ESI
PCI Adapter ID (vendor 4265, device 5) pci slot 3
gfxinfo:
HQ rev B, GE12 rev A, RE4 rev C, PP1 rev G,
VC3 rev A, CMAP rev E, Heart rev F
21" monitor (id 0xb)
Video Output: 1280 pixels, 1024 lines, 75.92Hz (1280x1024_76)
Managed (":0.1") 1280x1024
MGRAS revision 0, RA revision 0
Graphics board 2 is "IMPACTSR" graphics.
Unmanaged 1280x1024
HQ rev B, GE12 rev =, RE4 rev C, PP1 rev A,
Xvc info not available for unmanaged boards
Anyone know how to get that third Board to be recognized by the Octane?
Thanks,
Eugene Redko
0ctane
Unread postby 0ctane » Thu Mar 18, 2004 11:08 am
Good luck. I tried three boards in an Octane (2 SI, one ESI in slots A-C), but no love. I may have actually damaged one of the boards in the process. :o In a different thread, someone mentioned that 3 might be possible. http://forums.nekochan.net/viewtopic.php?t=1858&highlight=
