Octane R10k-250/2 MB Cache, MXI+SI
andreas@rootprompt
Unread postby andreas@rootprompt » Tue Feb 24, 2004 7:43 pm
Octane250 6# hinv -mv
PM10250MHZ Board: barcode HRY712 part 030-1426-001 rev C
IP30 Board: barcode GXP904 part 030-0887-005 rev A
FP1 Board: barcode FTK338 part 030-0891-003 rev C
PWR.SPPLY.ER Board: barcode AAE8510113 part 060-0035-001 rev B
GM20 Board: barcode EBC244 part 030-0957-003 rev G
GM10 Board: barcode GBS798 part 030-0938-003 rev T
1 250 MHZ IP30 Processor
Heart ASIC: Revision E
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: MXI
Graphics board: SI
PCI Adapter ID (vendor 4265, device 5) pci slot 3
Octane250 7# /usr/gfx/gfxinfo
VC3 rev A, CMAP rev E, Heart rev E
unknown, assuming 19" monitor (id 0x9)
Video Output: 1280 pixels, 1024 lines, 72.24Hz (1280x1024_72)
Managed (":0.1") 1280x1024
HQ rev B, GE11 rev B, RE4 rev C, PP1 rev H,
Octane250 8#
... my ex SSI-Octane now with two freshly reworked TRAMs :)
