fu:el R14K/600MHz, 2GB RAM, V12, DVD, DM8
fu
Unread postby fu » Wed Jan 23, 2008 3:06 pm
i finally unpacked the fuel + (thanks to joerg) the F190, after re:seating RAM + V12 my fuel seems to work OK... it had quite a ride from michigan to london but steve (pas1tech) is a nice guy and set me up with mint skins :) ...
now i have to follow joerg's advice and buy some fujitsu hds cause the louder thing inside this fuel is the maxtor hd (i can't stand high:pitch sounds :x )
if anyone who understands all of this output(s), spots something worng with the fuel, please give me a shout (i just copied neko's commands)
fuel 1% hinv -vm
            IP34 Board: barcode NCK628     part 030-1707-004 rev -A
        IP34PIMM Board: barcode NCK657     part 030-1730-002 rev -E
          ASTODY Board: barcode NJY535     part 030-1726-005 rev -A
1 600 MHZ IP35 Processor
Main memory size: 2048 Mbytes
Graphics board: V12
USB controller: type OHCI
fuel 2%
fuel 2% /usr/gfx/gfxinfo
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: SGX 8192
fuel 3% l1cmd --scdev /hw/module/001c01/L1/controller env
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.48
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.12
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
PIMM0 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
     Fuel SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.52
      Fuel CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.61
    PIMM0 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.49
PIMM0 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
  PIMM0 5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.12
  XIO 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.94
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.46
  XIO 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
FAN 0  EXHAUST    Enabled          920         1180
FAN 1       HD    Enabled         1560         2220
FAN 2      PCI    Enabled         1120         1506
FAN 3    XIO 1    Enabled         1600         2163
FAN 4    XIO 2    Enabled         1600         2070
FAN 5       PS    Enabled         1600         2657
Description    State       Temp       Temp       Temp       Temp
NODE 0            Enabled   Disabled   Disabled   70C/158F   36C/ 96F
NODE 1            Enabled   Disabled   Disabled   70C/158F   38C/100F
NODE 2            Enabled   Disabled   Disabled   70C/158F   26C/ 78F
PIMM              Enabled   Disabled   Disabled   70C/158F   47C/116F
ODYSSEY           Enabled   Disabled   Disabled   70C/158F   37C/ 98F
BEDROCK           Enabled   Disabled   Disabled   85C/185F   38C/100F
fuel 4% l1cmd --scdev /hw/module/001c01/L1/controller version
L1 1.24.11 (Image B), Built 10/29/2003 00:05:26    [Fuel/PE 1MB image]
fuel 5% configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1   MODULE_001c01            NA                  NA            NA        NA
    2              L1        001c01                  NA            NA        NA
    3            IP34        001c01              NCK628  030-1707-004        -A
    4       MEMBANK_0        001c01                  NA            NA        NA
    5       MEMBANK_1        001c01                  NA            NA        NA
    6       MEMBANK_2        001c01                  NA            NA        NA
    7       MEMBANK_3        001c01                  NA            NA        NA
    8          R14000        001c01                  NA            NA        NA
    9              NA        001c01                  NA            NA        NA
   10            IP34        001c01              NCK628  030-1707-004        -A
   11          ASTODY      XTALK_13              NJY535  030-1726-005        -A
   12            IP34      XTALK_14              NCK628  030-1707-004        -A
   13     SCSI_CTLR_0            NA                  NA            NA        NA
   14         DRIVE_1            NA            E6VV942C  IC35L073UWDY10-0      S27C
   15     SCSI_CTLR_1            NA                  NA            NA        NA
   16         CDROM_6            NA                  NA            NA        NA
   17    ETHERNET_EF0            NA                  NA            NA        NA
fuel 6% scsicontrol -i /dev/scsi/sc*
/dev/scsi/sc0d1l0:  Disk          SGI     IC35L073UWDY10-0S27C
Device is  ready
/dev/scsi/sc1d6l0:  CD-ROM        TOSHIBA DVD-ROM SD-M17111005
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
Re: fu's pheeew:el R14/600MHz, 2GB RAM, V12, DVD
Unread postby recondas » Wed Jan 23, 2008 3:26 pm
Very nice, congratulations.
Unread postby nekonoko » Wed Jan 23, 2008 3:28 pm
fu wrote:if anyone who understands all of this output(s), spots something worng with the fuel, please give me a shout (i just copied neko's commands)
Looks perfect. Congratulations!
fu
Unread postby fu » Wed Jan 23, 2008 5:07 pm
thanks dave+pete
gotta grab one m-audio card too (forgot it does not come sound-ready)
Unread postby jan-jaap » Thu Jan 24, 2008 2:36 am
fu wrote:the louder thing inside this fuel is the maxtor hd (i can't stand high:pitch sounds :x )
[code]fuel 6% scsicontrol -i /dev/scsi/sc*
Nice box!
Nothing wrong, but that disk looks like an IBM/Hitachi Ultrastar 146Z10 to me. I've got a Seagate 15K3 in my Fuel. It has fluid bearings, so it's very quiet.
Unread postby nekonoko » Fri Jan 25, 2008 1:02 pm
Did you get Z-Term to cooperate? I finally got around to plugging my FTDI and Prolific USB to serial adapters into my Fuel's L1 to confirm the settings for you, but it looks like you've deleted the topic :)
fu
Unread postby fu » Fri Jan 25, 2008 1:51 pm
jan-jaap wrote:...that disk looks like an IBM/Hitachi Ultrastar 146Z10 to me...
true (my bad) it's a noisy hitachi ultrastar (sounds like it's dying too)....
just ordered some fujitsu matxx (following joerg's tip on how low-noise they are)
nekonoko wrote:Did you get Z-Term to cooperate?
no i didn't, didn't gave it enough tries tho... after re-seatting the v12 + ram sticks fuel is alive+kickin...
nekonoko wrote:I finally got around to plugging my FTDI and Prolific USB to serial adapters into my Fuel's L1 to confirm the settings for you, but it looks like you've deleted the topic :)
yup, tried 2 edit and hit the wrong button :roll:
if u've got screengrabs (or if u have your settings handy), please pm
i guess.. i'll need 'em sometime
D-EJ915
Unread postby D-EJ915 » Fri Jan 25, 2008 1:55 pm
I've got some fujitsu 10k 73GB and they are really quiet, when they're not accessing you can barely tell they're on, even by touching them :shock:
fu
Unread postby fu » Fri Jan 25, 2008 2:04 pm
D-EJ915 wrote:I've got some fujitsu 10k 73GB and they are really quiet, when they're not accessing you can barely tell they're on, even by touching them :shock:
kooL disk :)
mine is the loudest thing inside the fuel... guess it didn't like the transatlantic ride (mi-->lndn)
Bishop2K
Unread postby Bishop2K » Fri Jan 25, 2008 2:30 pm
Boohoohoo... sniffle.
I want a Fuel as good as that... :oops:
If anyone actually has a practical use for a 128P Origin 3800, I'd like to know about it...
Unread postby hamei » Sat Jan 26, 2008 10:52 am
Bishop2K wrote:Boohoohoo... sniffle.
I'll sell you mine for ... oh, I dunno ... 2/3 of what I paid ?
Bishop2K
Unread postby Bishop2K » Sun Jan 27, 2008 3:10 am
Specs?
Or should I do a SEARCH.
Unread postby hamei » Sun Jan 27, 2008 9:15 am
Bishop2K wrote:Specs?
No, just thinking about it makes me ill :oops:
Same specs as fu's but 4 gigs of memory and a dcd bolted to the v12.
I was being a little facetious about the offer. Most people today are paying less than what 3*-**c screwed me out of by shilling up the price. I figger in another seventeen years it will be amortized ... have been thinking an 800 mhz cpu would be great but hell, for the price of that cpu I could buy three nice 1 ghz AIX machines and switch from Pro/E to Catia. And no, I'm not telling where :P
dc_v01
Unread postby dc_v01 » Sun Jan 27, 2008 2:19 pm
hamei wrote: but hell, for the price of that cpu I could buy three nice 1 ghz AIX machines and switch from Pro/E to Catia.
Ah, but unless you're already well versed, it's going to cost you a lot more just in time for the software switch. Catia didn't even win quite as many awards for usability, GUI, and standard application interfaces as Pro/E.....
fu
Unread postby fu » Sun Jan 27, 2008 4:40 pm
hamei wrote:Same specs as fu's but 4 gigs of memory and a dcd bolted to the v12.
hex!
2 kool 4 (s)kool
those 1 gig sticks are so freakin' expensive...
