O2 R5200 300MHz 384Mb
JacquesT
Unread postby JacquesT » Fri Apr 20, 2018 2:45 pm
CPU: MIPS R5000 Processor Chip Revision: 10.0
FPU: MIPS R5000 Floating Point Coprocessor Revision: 10.0
1 300 MHZ IP32 Processor
Main memory size: 384 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Iris Audio Processor: version A3 revision 1
Video: MVP unit 0 version 1.4
Vice: TRE
   32 bitplanes
    Monitor 0 type: DEL -24554
    Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
    Video Format Flags:  (none)
    Sync Disabled
    Using Gamma Map 0
While a 300MHz proc helps for general system use fireflop still makes the machine feel like it's wading through a pool of molasses. Otherwise a fun little system.
:Octane: - 1xR12k 400Mhz, 1GB, V8, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384MB, SSE, 18Gb 10K HDD, 6.5.30
:O2: :1600SW: - 300Mhz R5200, 384MB, 36Gb 15K HDD, A/V, FPA, 4x CD-ROM, 6.5.30
"Ho Ho," Says the keeper of the beat.
Intuition
Re: O2 R5200 300MHz 384Mb
Unread postby Intuition » Fri Apr 20, 2018 7:54 pm
Any pics of the machine?
Also, I have a 180mhz o2 I have to pick up someday from south of San Fran. I plan on getting a 300mhz just like you for it.
My plan for all the o2s is to get Dodoids d1 which will hopefully make the net browsing less painful.
Image O2 - 300mhz
aka Casey Christopher
JacquesT
Unread postby JacquesT » Sat Apr 21, 2018 12:49 am
Intuition
Unread postby Intuition » Sat Apr 21, 2018 10:18 pm
WOW, very nice condition. :shock:
Image O2 - 300mhz
cascatino
Unread postby cascatino » Mon Apr 23, 2018 3:50 am
I'm glad you made it, excellent piece!
....what about the plastic fan cover? ;)
:Fuel: "Enzo", R14K, 1.5Gb RAM, V10, 6.5.29 **NOT WORKING, PSU issues** :evil:
:O2: "Frodo", R5k@300MHz, 768Mb RAM, A/V module
JacquesT
Unread postby JacquesT » Mon Apr 23, 2018 7:24 am
Don't have the fan cover, or the metal pull ring for the psu.
The machine was an ex demonstration machine to show clients software for modelling shoe last forms and learher cutting patterns I believe. Spyro will know more detail.
It has a few rub marks on the av module side where somebody removed a sticker, but otherwise in good condition. :)
Irinikus
Unread postby Irinikus » Mon Apr 23, 2018 7:26 am
You can buy a cover from Mashek on eBay. (Thats where I got mine.)
Image ... Image
JacquesT
Unread postby JacquesT » Mon Apr 23, 2018 12:50 pm
I think Spyro may still have the plastic cover, somewhere in his stash of stuff. I'll swing by his in the future to see if he's managed to dig it out.
spiroyster
Unread postby spiroyster » Mon Apr 30, 2018 1:16 am
JacquesT wrote:I think Spyro may still have the plastic cover, somewhere in his stash of stuff. I'll swing by his in the future to see if he's managed to dig it out.
Yep sat here right in front of me... and broken off clip (thats rare, I mean who still has the clip of the fan cover o.0)
JacquesT wrote:Don't have the fan cover, or the metal pull ring for the psu.
omg, your forensic skills are good... completely forgot about that sticker (branding :roll:). Yes it was demo machine for CSM3D Shoemaster (https://atom-shoemaster.com/en/) when it ran on Irix.... circa ~2002/03, before the migration to Windows (via Softwindows 95 :shock:).
Trivia: The original Shoemaster code had one of the first implementations of Bezier curves outside Renault :D
CLICK HERE to find out what click bait is. You will not believe what you discover.
#NaN singles in your area are already making gazzilions by using this trick.
Cambridge Analytica approved!!
