Octane1 2x300MHz, 2GB RAM, EMXI
mrthinlysliced
Unread postby mrthinlysliced » Sun Apr 15, 2018 6:47 am
A gentleman kindly dropped this off yesterday. Is a best-parts-from-three mismash the chap had obtained after the science department stopped using them. The gent intended to have a bit of fun with it but after 5 years sitting in a corner of his office and having a young family -> goes up on ebay.
Skins are in great condition as is the machine in general - but needs a bit of love to get rid of dust and muck build up (todays job).
Then onto a fresh network install along with the necessary extra tools + locking down the network.
(Anything special I should look out for to get necessary compilers installed?)
IRIS 1# hinv -vm
      PM20300MHZ Board: barcode HKH112     part 030-1356-001 rev  J
            IP30 Board: barcode HXY417     part 030-1467-001 rev  B
             FP1 Board: barcode JDL871     part 030-0891-003 rev  E
    PWR.SPPLY.ER Board: barcode AAE9160390 part 060-0035-001 rev  C
           MOT20 Board: barcode HLX377     part 030-1240-003 rev  F
2 300 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: EMXI
IRIS 2# /usr/gfx/gfxinfo
        VC3 rev A, CMAP rev F, Heart rev F
        21" monitor (id 0xb)
Irinikus
Re: Octane1 2x300MHz, 2GB RAM, EMXI
Unread postby Irinikus » Sun Apr 15, 2018 6:53 am
Thats very nice! :D
Confirm it's your first SGI?
Image ... Image
mrthinlysliced
Unread postby mrthinlysliced » Sun Apr 15, 2018 7:20 am
First personal SGI :-)
First SGI I've used in 20 years hehe.
Going to have some fun with this. My muscle memory for bash (set -o emacs) is strong and results in constant CTRL-U start agains.
Irinikus
Unread postby Irinikus » Sun Apr 15, 2018 7:22 am
Welcome to the club!
That's a nice config you have there, I hope it serves you well. :D
Image ... Image
mrthinlysliced
Unread postby mrthinlysliced » Sun Apr 15, 2018 12:32 pm
Cheers! We just finished bath time to brighten up the skins.
I dissembled almost everything and gave it all a good clean - apart from the power supply and underneath the front mainboard. Quite the mess under the rear fan when I took it off, nothing some cotton tips couldn't get to and sort out.
Might have a go at those another time but that's enough for today - still have the naked chassis verified as booting and happy.
JacquesT
Unread postby JacquesT » Mon Apr 16, 2018 11:55 am
Lovely config you have, the dual 300mhz is no slouch and should run just about anything you throw at it.
If it's gonna live on your desk / below your desk consider getting the psu fan and scsi backplane fan swapped for quieter ones.
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 300Mhz R5200, 384Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.30
mrthinlysliced
Unread postby mrthinlysliced » Tue Apr 17, 2018 10:22 am
Thanks Jacques, I do feel a little like I struck gold :-)
Some before and after shots of the "big cleaning":
Before 1+2:
After 1+2:
Sunlight really changes the green into blue - quite bizarre - it doesn't look that blue in person!
So - I'm more than happy with that - it came up a treat. I may have to have another go at the front door panel again, I didn't go too hard with the cleaning around there out of fear of damaging the lettering, but it still looks to me like there's some dirt there.
And then last night I managed to get IRIX 6.5.30 network installed together with all the bits and pieces.
So now I have an account and can log in - but my user sees these weird fonts on the desktop:
Shouldn't I be seeing the font(1) instead of the font it's using for (2)?
Anyone have any idea where I've gone wrong or what I've done wrong?
Basically I took the 6.5 base plus the 6.5.30 overlays and added everything, removed the java bits in conflicts and installed.
I think I may have skipped using EZSetup to add the account - possible that's the cause?
Cheers for any pointers,
Dan
JacquesT
Unread postby JacquesT » Tue Apr 17, 2018 11:03 am
Wow, looks great! Is this the eBay 'paypal will be refunded job?'
No, the EZSetup should not have that effect.
Just checked my 6.5.30 O2 install, both fonts match. I assume you installed from overlay 1, fed in the other 'disks' and then just went on from there?
Try Toolchest -> Desktop -> Customize -> Desktop Settings -> change Sizes of Dynamic fonts to 'medium.' Log out / log in.
mrthinlysliced
Unread postby mrthinlysliced » Tue Apr 17, 2018 1:39 pm
RE: "paypal will be refunded" - yep, I'd kinda written that one off - and a little later the seller replied to my inquiries and we exchanged a few messages that convinced me he was legit -> once he changed the payment method so no need for paypal + cash I had little to lose :-)
Turned out to be quite a gent and someone who cares and enjoys these machines too. He'd done a 6.5 install a couple of nights before bringing the machine over - I'm guessing so he could have a bit of fun with it too :-)
Thanks for the pointer on dynamic fonts - it was already set to medium (I did try changing to the various settings there and logging out, for info) - but no go unfortunately.
Strangely it's for all users (I created a new test account too this time using EZSetup) - it's almost like there is a missing font or the font cache doesn't have all of them.
For the install I network minirooted from 6.5, then bundled all of 6.5.30 overlays and other extras during the (DINA) install:
1
2
3
foundation1
foundation2
dev_foundation
development_libraries
applications
compapps
compiler (MIPSPro bits)
I'm not too invested in this install yet so maybe I'll try redo with a base 6.5 install first and afterwards use the .30 overlays + extras.
Unread postby uunix » Tue Apr 17, 2018 1:55 pm
You language is incorrect.
From the Toolchest select.. Desktop -- Customize-- Language
Then ensure:
Country is set to Great Britain (English Latin 1....)
Language English (Latin 1....)
mrthinlysliced
Unread postby mrthinlysliced » Tue Apr 17, 2018 2:15 pm
Thanks uunix, that's got it, fonts are back to normal and readable now.
PEBKAC error during my "ooo, it's running lets play a little" undoubtedly.
Edit: And just in case someone else comes across this - I'd stupidly set the root account language wrong too, which was the "root" (ha) cause of other account issues.
