Octane1 2x400 MHZ, 640MB RAM, EMXI card.
Intuition
Unread postby Intuition » Thu Feb 01, 2018 3:56 pm
Octane 1# hinv
2 400 MHZ IP30 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
Main Memory Size: 640 Mbytes
Xbow ASIC: Revision 1.3
Instruction cache size: 32 kbytes
I0C3/I0C4 serial port: tty1
I0C3/I0C4 serial port: tty2
I0C3 parallel port: EMXI
Integral Fast Ethernet: ef0, version1, pci 2
Well here is the result of the Octane Fox gave for a generous price.
As per my last post it had a buggy dual r12k 400mhz that was intermittent.
Marshall sold me another 2x400 for a great price. It is solid. No more random "does it boot today" situations where I am reseating the processor. It is quite solid now.
The network wasn't working as one would predict but having learned how to set it up on the other o2s I went through the same process and it still wasn't coming up. For some reason, and I wouldn't assume it would make a difference, but the drive I bought off ebay had appletalk setup and apache_something in chkconfig set to "on".
I switched them to "off", went through the System manager network setup routines and... BAM... internet works.
BUT, I am posting from my win7 machine because.... look at how Nekochan looks using the Netscape on this Irix setup drive.
What I am attempting to do now is get Firefox going and to setup the machine with lots of Nekoware.
Currently the machine also says it has no video demon. So I can't run any desktop capture until I get the software setup to use the hardware correctly.
At the moment I have Lightwave 5.0, Maya 4.0, and i3d running. Though, if I could get my o2 networked to the Octane it has that backup directory that has tons of software in it. I could probably install from the o2.
Image O2 - 300mhz
aka Casey Christopher
JacquesT
Re: Octane1 2x400 MHZ, 640MB RAM, EMXI card.
Unread postby JacquesT » Fri Feb 02, 2018 10:33 am
Nice and clean, you have a bonus in a Cherokee PSU so can pop in a V8 if you get one.
I have to do a clean install + nekoware as well but trying to sort out my vid card first.
Unread postby vishnu » Sat Feb 03, 2018 2:45 pm
Very nice! You're an Odyssey and XBow 1.4 away from having a stealth Octane2... :mrgreen:
Users browsing this forum: Baidu [Spider] and 2 guests
