Origin2000: 8x 250MHz, 5GB RAM
Dodoid
Unread postby Dodoid » Wed Jan 31, 2018 9:04 pm
Running the Origin2000 today (just set up an Xvnc server, hope to have an IO6G so that the SI graphics I installed work soon). I should be able to get a video on my channel about this system out soon-ish, though it does require some strange special considerations given that I can't film it on my normal white background.
Hinv below, but the "simple" specs are as follows:
  • 8x 250MHz CPUs across 4 nodeboards
  • 5GB memory
  • SI graphics (installed, appears in PROM hinv, seemingly not used by IRIX yet)
  • 18GB disk
  • Both nodeboards standard routers
  • IRIX 6.5.30
Pics below, hope these are better resolution than the whopping 300x294 image I had to use for my SGI History series (before I owned an Origin2000 of my own) :D . Skins are in good condition, thanks to PixelDust1 who I bought this system from. Same goes for my Onyx, hope I can get that running soon.
Front. Nice skins. The system lives under my desk, which is exactly where it is pictured here. I have cables for ethernet, serial, etc running out the back, connected to my Hackintosh workstation and my network so that I can run it remotely just by turning the key. I can even use it as a footwarmer if I want to.
Front slidey-panel-thing down. As you can see, I only have one hard drive in it (my SGI "server" is actually an 400mhz O2, for power consumption and noise reasons). That CD-ROM is the same model used in the O2, seen here with the factory faceplate (as opposed to the three-piece blue and black replacement design used on the O2. It required the same eject gear repair, but now works great.
I pulled the system out to get some pics. It's on wheels of course, so I've positioned it so that I can just roll it in and out from under the desk. The cables remain attached and the system remains running, since I use long cables with enough slack to move the system out if I need to.
SI graphics card. I stole the bracket thing off a SCSI card it had in there that I didn't need, card came from the parts bin. I have just stuck the tab out the side for now, rather than cutting a new hole. Works well enough, holds the card in, shows up in PROM hinv. The blank card next to it loses about a milimeter of space, so I just bent it's back plate in a tiny amount to get it to fit beside the slightly wider SI card.
hinv -vm
        MODULEID Board: barcode K0019523   part              rev
       8P12_MPLN Board: barcode HJG486     part 030-0762-006 rev  M
            IP31 Board: barcode JEA753     part 030-1255-003 rev  D
        IP31PIMM Board: barcode FXZ207     part 030-1313-002 rev  A
            IP31 Board: barcode DDP546     part 030-1255-003 rev  A
        IP31PIMM Board: barcode GFE410     part 030-1313-002 rev  A
        IP31PIMM Board: barcode GFJ969     part 030-1313-002 rev  A
            IP31 Board: barcode FXN470     part 030-1255-003 rev  A
            IP31 Board: barcode DGK911     part 030-1255-003 rev  B
        IP31PIMM Board: barcode GBY993     part 030-1313-002 rev  A
      ROUTER_IR1 Board: barcode KCF653     part 030-0841-003 rev  B
      ROUTER_IR1 Board: barcode KDK186     part 030-0841-003 rev  B
       XTALK_PCI Board: barcode LHY742     part 030-1275-003 rev  A
          BASEIO Board: barcode EPB029     part 030-1124-002 rev  B
8 250 MHZ IP27 Processors
FPU: MIPS R10010 Floating Point Chip Revision: 3.4
CPU 0 at Module 1/Slot 1/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 2/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 4 at Module 1/Slot 3/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 5 at Module 1/Slot 3/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 6 at Module 1/Slot 4/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 7 at Module 1/Slot 4/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 5120 Mbytes
Memory at Module 1/Slot 1: 896 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 128 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
  Bank 4 contains 128 MB (Standard) DIMMS (enabled)
  Bank 5 contains 128 MB (Standard) DIMMS (enabled)
  Bank 6 contains 128 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 2: 640 MB (enabled)
Memory at Module 1/Slot 3: 256 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 4: 3328 MB (enabled)
ROUTER in Module 1/Slot 2: Revision 2: Active Ports [4,5,6] (enabled)
ROUTER in Module 1/Slot 4: Revision 2: Active Ports [4,5,6] (enabled)
  PCI Adapter ID (vendor 0x10b7, device 0x5900) PCI slot 1
HUB in Module 1/Slot 3: Revision 5 Speed 100.00 Mhz (enabled)
HUB in Module 1/Slot 4: Revision 5 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n3: Revision 6.156
IP27prom in Module 1/Slot n4: Revision 6.156
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
Like I said, hope to get more out about this system soon. I have been slowly cleaning up my bedroom (where my larger systems are located), so I should be able to film in there.
and a small army of Image
Re: Origin2000: 8x 250MHz, 5GB RAM
Unread postby josehill » Thu Feb 01, 2018 6:58 am
Very nice system!
VenomousPinecone
Unread postby VenomousPinecone » Thu Feb 01, 2018 9:12 am
Man I love it. Always wanted my own deskside system, it seemed like the coolest compromise between big iron and a workstation. Now all you need are some moody low light pics to show of all the blinkenlights in true glory.
