Fuel R14000 512Mb
cascatino
Fuel R14000 512Mb
Unread postby cascatino » Mon Jan 29, 2018 10:46 am
Hi there, I tried to pull off the screenshot 'cause some posts below I put the hinv text with code tags, but I failed.
This is a fuel belonged to a dear friend of mine, it has some issues which I hope to solve (with your help!)
ciao a tutti
:Fuel: "Enzo", R14K, 512MB RAM, V10, 6.5.29
:O2: "Frodo", R5k, 192Mb RAM
Re: Fuel R14000 512Mb
Unread postby Trippynet » Mon Jan 29, 2018 10:48 am
Nice little system, and should be up to 1.5GB of RAM with a bit of fixing. Do you have any photos?
cascatino
Unread postby cascatino » Mon Jan 29, 2018 10:59 am
Oh it's a lovely machine, she's my first sgi (i'm waiting for an O2 too).
About the RAM modules: I did a check and Irix (or the PROM) tells me that the 512Mb DIMM modules aren't responding well so the mahcine disabled it.
Actually I removed them, next time I'll mount only them in the first bank (slot 0 and 2, I know).
Here's a shot I did as soon as the fuel crossed my door, actually I'm looking for a door for a good price, if you have one.... ;-)
cascatino
Unread postby cascatino » Tue Jan 30, 2018 10:36 am
OK, I-ve got it, today I learned to copy and paste text from the shell.
Here they are the hinv /vv and the gfxinfo>
1 500 MHZ IP35 Processor
CPU: MIPS R14000 Processor Chip Revision: 2.3
FPU: MIPS R14010 Floating Point Chip Revision: 2.3
CPU 0 at Module 001c01/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 2 MB Speed 250 Mhz  Tap 0x1a
Main memory size: 512 Mbytes
Memory at Module 001c01/Slot 0: 512 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
  Bank 1 contains 256 MB (Standard) DIMMS (enabled)
  Bank 2 contains 512 MB (Standard) DIMMS (disabled)
  Bank 3 contains 512 MB (Standard) DIMMS (disabled)
Graphics board: V10
IP35prom in Module 001c01/Slot n0: Revision 6.117
USB controller: type OHCI
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: SAM 637
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (1280x1024_60_safe)
japes
Unread postby japes » Tue Jan 30, 2018 12:54 pm
cascatino wrote:About the RAM modules: I did a check and Irix (or the PROM) tells me that the 512Mb DIMM modules aren't responding well so the mahcine disabled it.
Long ago I had a Fuel that only the first bank worked - I could enable the second bank - it even seemed to work, but would fail on next post. Hope this isn't that machine, or that it hasn't the same problem. I figured a broken connection between the memory controller and slot or a failing controller.
If you find your 1gb kit is just bad, I think I have some 1gb kits I could sell.
Unread postby Trippynet » Tue Jan 30, 2018 2:36 pm
cascatino wrote:actually I'm looking for a door for a good price, if you have one....
Well, as much as I'd like to rip the front door off my own Fuel, I'm afraid I'm going to have to pass. Hope you find one though! :)
Anyway, it's a very decent little starter system. As you've seen, the Fuel can be a bit finicky and flaky, but they are pretty speedy for SGI systems (when they work).
cascatino
Unread postby cascatino » Tue Jan 30, 2018 11:36 pm
The weird thing about tha RAM hinv text passage is that the two 512Mb weren't even there when I performed the hinv command! How is this possible?!
Another thing: why on earth the fuel manual speaks about "pairs" and "sockets" and the PROM deals with banks?! It drives me crazy, sockets and banks aren't the same thing either!
Actually I have the first 256MB mounted on socket 0 and the second one on Socket 3. Pulled off the two 512Mb because of the disabling message, I'll try to mount them on socket 0 and 3 alone, wothout the two 256MB and see what happens...but I have to deal with other little big issues on this machine so, my scientific approach (solve one issue at a time) would be not so straight.
japes
Unread postby japes » Wed Jan 31, 2018 8:58 am
Once the memory modules are disabled the PROM probably doesn't even check if it's there.
Haha, documentation and software out of sync? Never...yeah, you have to just let things like that go.
Irinikus
Unread postby Irinikus » Wed Jan 31, 2018 9:52 am
Try opening up the prom command monitor and type in the command "enableall" without the inverted commas. Reboot the machine and check see if all of the RAM is enabled.
Image ... Image
cascatino
Unread postby cascatino » Wed Jan 31, 2018 10:27 am
Irinikus wrote:Try opening up the prom command monitor and type in the command "enableall" without the inverted commas. Reboot the machine and check see if all of the RAM is enabled.
Thank you, already performed the command the PROM said the two banks of 512Mb RAM weren't working fine and disabled them...
Intuition
Unread postby Intuition » Wed Jan 31, 2018 2:03 pm
Did you find a faceplate for it?
Image O2 - 300mhz
aka Casey Christopher
cascatino
Unread postby cascatino » Wed Jan 31, 2018 11:44 pm
Intuition wrote:Did you find a faceplate for it?
Found something but a bit expensive....do you have one? :?:
