SGI Octane, 2xR12k 400 MHz, RAM 2 GB, SI
jirka
Unread postby jirka » Sat Dec 23, 2017 9:13 am
My new Octane:
      PM20400MHZ Board: barcode KZT572     part 030-1476-001 rev  D
            IP30 Board: barcode HXX514     part 030-1467-001 rev  B
             FP1 Board: barcode JLJ268     part 030-0891-003 rev  E
    PWR.SPPLY.ER Board: barcode AAE0230452 part 060-0035-002 rev  A
            GM10 Board: barcode GAK809     part 030-0938-003 rev  T
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: SI
It's this one:
http://forums.nekochan.net/viewtopic.php?f=4&t=16732540
Irinikus
Re: SGI Octane, 2xR12k 400 MHz, RAM 2 GB, SI
Unread postby Irinikus » Sat Dec 23, 2017 9:46 am
Very nice, and she's in excellent condition.
She will give your O2's a serious hiding! :D
Image... Image Image Image Image Image Image Image Image Image
Image... Image
Image... Image
Image... Image Image Image... Image Image
Image... Image nForce 680i SLI, 3.2 GHz Core2 Extreme, 4GB, Image
Image... Image Rampage III extreme, 3.3 GHz i7 980X, 24GB, OCZ RevoDrive 3 X2, X-FI Fatality Pro, Image
jirka
Unread postby jirka » Sat Dec 23, 2017 11:14 am
The O2 will continue to be my main desktop. I don't need so much power (and noise) every day ;)
