(less) dubious Onyx350/4 - 8CPU/V12/MAD/RAD/FW/USB/FC/10Gbe
jwhat
Unread postby jwhat » Fri Dec 15, 2017 3:25 am
Hi Nekochaners,
thought I would post new hinv for dubious (was Tezro) as it has now morphed into Onyx350/4 with V12 and various other bits of paraphernalia inside.
Main details are: 2 x Numalink'ed Onyx350/4 with 4 x 1GHz + 4 x 800MHz, V12, 16GB RAM, RAD/MAD PCI Audio Cards, LSI Dual 4GB FC, Adaptec 3 x USB + 2x Firewire (reports as DM10) and 10Gb Ethernet (Neterion XFrame) running IRIX 6.5.29.
So less dubious than before and original Tezro, that started this rebuilt is now gutted and banished to the garage, once I have removed all the part from it I am going to use it as a garden seat, as curved plastics are quite comfortable and steel chassis is pretty robust... ;-)
Please do not say this is sacrilege, as chassis got bent on shipping and so not really a keeper.
Here is hinv:
       IP59_4CPU Board: barcode RAG401     part 030-1989-003 rev -C
       2U_INT_53 Board: barcode REF634     part 030-1809-006 rev -D
             IO9 Board: barcode NZT098     part 030-1771-006 rev -A
       IP53_4CPU Board: barcode NRG676     part 030-1956-003 rev -A
      ODY128B1_2 Board: barcode RCZ635     part 030-1909-008 rev -B
       2U_INT_53 Board: barcode RHM011     part 030-1809-006 rev -D
Location: /hw/module/001c02/IXbrick/xtalk/15/pci-x/0/1/ioc4
             IO9 Board: barcode NFV336     part 030-1771-005 rev -A
Processor 0: 1.0 GHZ IP35
Processor 1: 1.0 GHZ IP35
Processor 2: 1.0 GHZ IP35
Processor 3: 1.0 GHZ IP35
Processor 4: 800 MHZ IP35
Processor 5: 800 MHZ IP35
Processor 6: 800 MHZ IP35
Processor 7: 800 MHZ IP35
CPU 0 at Module 001c01/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
  Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz  Tap 0x15
CPU 1 at Module 001c01/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c02/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 5 at Module 001c02/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c02/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c02/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 16384 Mbytes
Memory at Module 001c02/Slot 0: 8192 MB (enabled)
Integral SCSI controller 3: Version IDE (ATA/ATAPI) IOC4
Integral SCSI controller 7: Version Fibre Channel LS949X Port 1
Integral SCSI controller 8: Version IEEE1394 SBP2
Integral SCSI controller 5: Version QL12160, low voltage differential
Integral SCSI controller 6: Version Fibre Channel LS949X Port 0
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
IOC3/IOC4 serial port: tty9
IOC3/IOC4 serial port: tty10
Graphics board: V12
Gigabit Ethernet: tg1, module 001c02, PCI bus 1 slot 4
10 Gigabit Ethernet: xg1, module 001c02, 100 MHz PCIX bus 2 slot 2
Iris Audio Processor: version MAD revision 1, number 3
Iris Audio Processor: version RAD revision 13.0, number 2
  PCI Adapter ID (vendor 0x3388, device 0x0021) PCI slot 2
  PCI Adapter ID (vendor 0x1412, device 0x1724) PCI slot 1
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 2
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 8
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 8
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 12
  PCI Adapter ID (vendor 0x1000, device 0x0640) PCI slot 1
  PCI Adapter ID (vendor 0x17d5, device 0x5831) PCI slot 2
IOC4 firmware revision 83
IOC4 firmware revision 79
Dual Channel Display
USB controller: type OHCI
Rest of hinv is pretty much as per original hinv posting: viewtopic.php?f=14&t=16732345
Motivation for posting updated hinv was due to putting in 10Gb Ethernet, was hoping to get big NFS performance boost with this.
The card is SGI sourced Neterion XFrame and the optical interface is: Infineon XPAK 850mm Optical (it confirms to XFP standard I think).
EDIT: Further reading on XPAK ... it is not Infineon brand but industry form factor/electrical spec defined by: Infineon, Intel & Picolight. Different to XFP, which has same electrical as SFP+, but slightly bigger form factor. Other related GBIC standards are: XENPAK (precursor to XPAK from Agilent/HP) & X2 (Cisco only I suspect, but has 10GB-T available :-( ).
I did this at expense of voiding the warranting and taking off the big sticker attempting to stop you.
Here is picture of optical interface unit:
Was hoping that you might be able to swap this out for 10GBASE-T one, but the form factor appears to be have been supplanted by SFP+ and only copper connection is 10GBASE-CX4.
I had to move equipment to be next to 10Gb Ethernet switch to test it, but cannot keep it where it is, so will have to work out a not to expensive way to get onto copper based 10Gbe network.
Cheers from oz,
jwhat
Irinikus
Re: (less) dubious Onyx350/4 - 8CPU/V12/MAD/RAD/FW/USB/FC/10Gbe
Unread postby Irinikus » Fri Dec 15, 2017 3:43 am
Thats one super cool system, and one really cool ethernet card!
Image ... Image
JacquesT
Unread postby JacquesT » Fri Dec 15, 2017 12:39 pm
Starting to look a bit like the neural net core of the Terminator...
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 180Mhz R5k, 128Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.22m
jwhat
Unread postby jwhat » Sun Dec 17, 2017 9:45 pm
Hi JacquesT,
tapping into main control network ... ;-)
and speaking of "The Terminator" I think all of early ones were done on SGI boxes.
Cheers from Oz,
jwhat.
jwhat
Unread postby jwhat » Mon Dec 25, 2017 7:40 pm
Hi Nekochaners,
seems that Chimera (Origin350/Onxyx350/4/Tezro/Fuel) XIO2 is not available for use in chassis without CPU board (IP53_4CPU or IP59_4CPU)
After bit of swapping and testing, it is always that case that L1 never reports either Odyssey (V12) or DM3 when installed in chassis without CPU board.
So to get a combination that allowed V12 / DM3 to work I had to swap out 4x1GHZ board and replace with 4x700MHZ board.
Here is resulting hinv (+V12 with DCD / + DM3 / + DM10 / + 10GbE):
dubious 3# hinv -mv
       XT-DIGVID Board: barcode NDJ045     part 030-1927-003 rev  B
       IP53_4CPU Board: barcode NET662     part 030-1868-001 rev -C
       2U_INT_53 Board: barcode RBY376     part 030-1809-006 rev -D
Location: /hw/module/001c03/IXbrick/xtalk/15/pci-x/0/1/ioc4
             IO9 Board: barcode RBG126     part 030-1771-006 rev -A
Processor 0: 800 MHZ IP35
Processor 1: 800 MHZ IP35
Processor 2: 800 MHZ IP35
Processor 3: 800 MHZ IP35
Processor 4: 700 MHZ IP35
Processor 5: 700 MHZ IP35
Processor 6: 700 MHZ IP35
Processor 7: 700 MHZ IP35
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 1 at Module 001c01/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c03/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xc
CPU 5 at Module 001c03/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c03/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c03/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Memory at Module 001c03/Slot 0: 8192 MB (enabled)
Integral SCSI controller 9: Version IDE (ATA/ATAPI) IOC4
Integral SCSI controller 15: Version IEEE1394 SBP2
Integral SCSI controller 10: Version QL12160, low voltage differential
Integral SCSI controller 11: Version QL12160, low voltage differential
Integral SCSI controller 17: Version Fibre Channel LS949X Port 1
Integral SCSI controller 16: Version Fibre Channel LS949X Port 0
IOC3/IOC4 serial port: tty11
IOC3/IOC4 serial port: tty12
IOC3/IOC4 serial port: tty13
IOC3/IOC4 serial port: tty14
Graphics board: V12
Gigabit Ethernet: tg2, module 001c03, PCI bus 1 slot 4
10 Gigabit Ethernet: xg2, module 001c03, 100 MHz PCIX bus 2 slot 2
XT-DIGVID Multi-standard Digital Video: controller 1, unit 1, version 0x0
IOC3/IOC4 external interrupts: 3
HUB in Module 001c03/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c03/Slot n0: Revision 6.201
Here is L1 serial report without CPU Board:
dubious 5# l1cmd '* serial all'
001c01:
Local System Serial Number      NVRAM         M2004476
Reference System Serial Number  Attached C    M2004476
Local Brick Serial Number       EEPROM        REF634
Reference Brick Serial Number   NVRAM         REF634
INTERFACE   2U_INT_53       REF634         030_1809_006          D    000000
IO9         IO9             NZT098         030_1771_006          A    00
ODYSSEY     no hardware detected
RISER       2U_RISER        NSG552         030_1808_006          C    00
NODE        IP53_4CPU       NRG676         030_1956_003          A    00
SNOWBALL    SNOWBALL_EDGE   NDJ045         030_1927_003          B    00
PS 1        DPS-500EBE      XPD0710000209  060-0178-003          S4
PS 2        DPS-500EBE      XPD0710000057  060-0178-003          S4
DIMM 0     7F94FFFFFFFFFFFF24DFD01D SM57228DSGI100M    00FF   8.0  N/A
DIMM 2     7F94FFFFFFFFFFFF3DEF180D SM57228DSGI100M    00FF   8.0  N/A
DIMM 4     7F94FFFFFFFFFFFFA5EF180D SM57228DSGI100M    00FF   8.0  N/A
DIMM 6     7F94FFFFFFFFFFFFF39D501D SM57228DSGI100M    00FF   8.0  N/A
DIMM 1     7F94FFFFFFFFFFFFD63B680D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 3     7F94FFFFFFFFFFFF85EF180D SM57228DSGI100M    00FF   8.0  N/A
DIMM 5     7F94FFFFFFFFFFFF3A1F180D SM57228DSGI100M    00FF   8.0  N/A
DIMM 7     7F94FFFFFFFFFFFF1A1F180D SM57228DSGI100M    00FF   8.0  N/A
001e03:
Local Brick Serial Number       EEPROM        RBY376
Reference Brick Serial Number   NVRAM         RBY376
INTERFACE   2U_INT_53       RBY376         030_1809_006          D    000000
IO9         IO9             RBG126         030_1771_006          A    00
RISER       2U_RISER        RBS935         030_1808_006          C    00
NODE        no hardware detected
PS 1        no hardware detected
PS 2        DPS-500EBE      XPD0816000197  060-0178-003          S4
DIMM 0     no hardware detected
DIMM 2     no hardware detected
DIMM 4     no hardware detected
DIMM 6     no hardware detected
DIMM 1     no hardware detected
DIMM 3     no hardware detected
DIMM 5     no hardware detected
DIMM 7     no hardware detected
here is L1 serial report with CPU Board:
dubious 1# l1cmd '* serial all'
001c01:
Reference System Serial Number  Attch'd C L2  M2004476
001c03:
Reference System Serial Number  Attached L2   M2004476
ODYSSEY     ODY128B1_2      RCZ635         030_1909_008          B    00
NODE        IP53_4CPU       NET662         030_1868_001          C    00
DIMM 0     CE000000000000000CC70700 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 2     CE000000000000000CE44500 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 4     CE000000000000000C977E00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 6     CE000000000000000C8C7E00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 1     CE000000000000000C642F00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 3     CE000000000000000C917E00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 5     CE000000000000000C877E00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 7     CE000000000000000CFF4500 M3 46L2820DT2-CA0   2D   10.0  N/A
Also for those interested in FAN variation.
L1 env report without CPU Board:
NOTE: Scroll down to Rack/Slot Chassis 001e03/001c03 to see variation (where reports flips from c == compute to e == expansion depending on configuration)
dubious 6# l1cmd '* env'
001c01:
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.777
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.320
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
    PCI 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      PCI 3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
      PCI 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.496
        PCI 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.940
  XIO 12V BIAS <not present>
        XIO 5V <not present>
      XIO 2.5V <not present>
  XIO 3.3V AUX <not present>
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
     IP53 VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.241
     IP53 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.480
FAN  0  EXHST 1    Enabled         1980         2410
FAN  1       PS    Enabled         3200         4891
FAN  2    PCI 1    Enabled         1980         2428
FAN  3    PCI 2    Enabled         1980         2636
FAN  4      ODY    Enabled         1679         1896
 0 INTERFACE 0       Enabled    [Autofan Control]    75C/167F   45C/113F
 1 INTERFACE 1       Enabled    [Autofan Control]    75C/167F   46C/114F
 2 INTERFACE 2       Enabled    [Autofan Control]    75C/167F   34C/ 93F
 3 PCI RISER         Enabled    [Autofan Control]    75C/167F   30C/ 86F
 4 ODYSSEY        <not present>
 5 NODE              Enabled    [Autofan Control]    75C/167F   33C/ 91F
 6 BEDROCK           Enabled    [Autofan Control]    75C/167F   50C/122F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
EXHST       Enabled     0,1,2,5,6  47C/116F  41C/105F          0   18%/ 18%
PS          Enabled     0,1,2,5,6  47C/116F  41C/105F          1   55%/ 55%
PCI         Enabled             3  45C/113F  30C/ 86F        2,3   55%/ 55%
SNO         Enabled             4  35C/ 95F   0C/ 32F          4   55%/ 55%
001e03:
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.791
           12V <not present>
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.268
      PCI 3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
      PCI 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.509
        PCI 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.966
 IP53 3.3V AUX <not present>
   IP53 5V AUX <not present>
      IP53 12V <not present>
     IP53 VCPU <not present>
     IP53 SRAM <not present>
     IP53 1.5V <not present>
FAN  0  EXHST 1    Enabled         3330         5443
FAN  1  EXHST 2      Fault         3330            0
FAN  2       PS    Enabled         5779         7500
FAN  3    PCI 1    Enabled         3330         3792
FAN  4    PCI 2    Enabled         3330         4326
 0 INTERFACE 0       Enabled   50C/122F   54C/129F   58C/136F   27C/ 80F
 1 INTERFACE 1       Enabled   50C/122F   54C/129F   58C/136F   28C/ 82F
 2 INTERFACE 2       Enabled   50C/122F   54C/129F   58C/136F   28C/ 82F
 3 PCI RISER         Enabled   50C/122F   54C/129F   58C/136F   28C/ 82F
 5 NODE           <not present>
 6 BEDROCK        <not present>
And here is L1 env report with CPU Board:
dubious 2# l1cmd '* env'
001c01:
FAN  1       PS    Enabled         3200         4963
FAN  4      ODY    Enabled         1679         1906
 0 INTERFACE 0       Enabled    [Autofan Control]    75C/167F   49C/120F
 1 INTERFACE 1       Enabled    [Autofan Control]    75C/167F   50C/122F
 2 INTERFACE 2       Enabled    [Autofan Control]    75C/167F   37C/ 98F
 3 PCI RISER         Enabled    [Autofan Control]    75C/167F   33C/ 91F
 5 NODE              Enabled    [Autofan Control]    75C/167F   35C/ 95F
 6 BEDROCK           Enabled    [Autofan Control]    75C/167F   53C/127F
EXHST       Enabled     0,1,2,5,6  47C/116F  44C/111F          0   18%/ 18%
PS          Enabled     0,1,2,5,6  47C/116F  44C/111F          1   55%/ 55%
PCI         Enabled             3  45C/113F  33C/ 91F        2,3   55%/ 55%
001c03:
           12V <not present>
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.940
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.251
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.495
FAN  0  EXHST 1    Enabled         1980         2265
FAN  1       PS    Enabled         3200         5037
FAN  2    PCI 1    Enabled         1980         2360
FAN  3    PCI 2    Enabled         1980         2576
 0 INTERFACE 0       Enabled    [Autofan Control]    75C/167F   50C/122F
 1 INTERFACE 1       Enabled    [Autofan Control]    75C/167F   52C/125F
 2 INTERFACE 2       Enabled    [Autofan Control]    75C/167F   39C/102F
 3 PCI RISER         Enabled    [Autofan Control]    75C/167F   36C/ 96F
 4 ODYSSEY           Enabled    [Autofan Control]    75C/167F   47C/116F
 5 NODE              Enabled    [Autofan Control]    75C/167F   37C/ 98F
NODE        Enabled     0,1,2,5,6  47C/116F  46C/114F          0   18%/ 18%
PS          Enabled     0,1,2,5,6  47C/116F  46C/114F          1   55%/ 55%
PCI         Enabled             3  45C/113F  36C/ 96F        2,3   55%/ 55%
ODY         Enabled             4  48C/118F  47C/116F          4   55%/ 55%
You can see that the fans report differently for CPU Less case which has:
FAN 2 EXHST 2 Fault
while with CPU board EXHST 2 is no longer reported and instead has:
FAN 4 ODY Enabled
In both cases total of 5 Fans reported.
Summary:
It is not possible to use "standard" CPU-Less (no IP53/IP59 CPU Board) Origin350/Onyx350 Chassis to provide XIO2 based expansion.
This might be possible with MPX Chassis (which has IP53_0CPU board) and so is likely to behave the same as Chassis with IP53_xCPU / IP59_4CPU boards and have XIO2 slot enabled.
So I have now decided to split my Origin350/Onxy350 into two sets, one for media (V12/DM3/Audio) and one for compute (2 x IP59_4CPU == 8 x 1GHZ) with G2 (ATI graphics) with Numalink btw computes & XIO2 to ATI which is AGP mutant and has special riser.
Pending finding AC Power 2U Numalink (3) Router, in which case I will link them all together.
Will post hinv of other set up in other hinv thread: viewtopic.php?f=14&t=16732403
Cheers,
jwhat.
Unread postby robespierre » Mon Dec 25, 2017 9:13 pm
jwhat wrote:Motivation for posting updated hinv was due to putting in 10Gb Ethernet, was hoping to get big NFS performance boost with this.
The simplest least expensive way is to take the copper 10GBASE-T SFP+ out of the switch and put a 10GBASE-SR SFP+ into it. Then you can connect them with a multimode fiber with LC connectors.
It may also be possible to source a DA (direct attach) cable with XPAK on one end and SFP+ on the other.
jwhat
Unread postby jwhat » Mon Dec 25, 2017 10:41 pm
Hi robespierre,
my netgear switch is XS712T, so I purchased a couple of 10Gb SFP+ SR transceivers (for switch), which worked fine with LC/LC SR/Multimode patch cable I had. Problem is that switch is in middle of house in comms cabinet under staircases and computers are either in basement or my study and cabling is all cat5/6.
Actually cat6e for main cables and some cat5 where it is never going to be high bandwidth (cat6e is much thicker, stiffer and harder to work with).
Hence need to move 350s to stair well to test.
Cheapest way appears to be to try to hack Cisco X2 module, but this is heading into unexplored territory.
Cheers,
jwhat.
Unread postby robespierre » Mon Dec 25, 2017 10:56 pm
OK, you're way ahead.
I don't think cat5 or cat5e is adequate for 10gbase-t over any appreciable distance; what I have read points to cat6 or cat7 being required.
I don't know anything about XPAK / X2 conversions. They both use XAUI interconnect but I'm sure there are some electrical differences.
jwhat
Unread postby jwhat » Fri Mar 02, 2018 3:04 am
Hi Nekochaners,
given up on trying to get 3 chassis O350 setup with V12/DM3 with 4x1GHZ.
Have gone to numalink options which lets you add chassis without all the problems.
I have also removed the Adaptec 3 x USB/2 x FW Board as testing with this found that Firewire did not work (consistent with Nekonoto's testing). I also tried board in Octane2 and even with the "systune pciio_multimater_override 1" option set the machine just crashed on boot.
Here is numalink'ed hinv result (16 CPUs across 4 chassis):
       IP59_4CPU Board: barcode RMB786     part 030-1989-003 rev -D
       2U_INT_53 Board: barcode NCA858     part 030-1809-003 rev -B
             IO9 Board: barcode RAD764     part 030-1771-006 rev -A
     PCI_SIO_UFC Board: barcode NFD033     part 030-1657-003 rev  A
Location: /hw/module/001c04/IXbrick/xtalk/15/pci-x/0/1/ioc4
          ROUTER Board: barcode NCW164     part 030-1634-003 rev -A
Processor 8: 1.0 GHZ IP35
Processor 9: 1.0 GHZ IP35
Processor 10: 1.0 GHZ IP35
Processor 11: 1.0 GHZ IP35
Processor 12: 1.0 GHZ IP35
Processor 13: 1.0 GHZ IP35
Processor 14: 1.0 GHZ IP35
Processor 15: 1.0 GHZ IP35
CPU 4 at Module 001c02/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 5 at Module 001c02/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c02/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c02/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 8 at Module 001c03/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 9 at Module 001c03/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 10 at Module 001c03/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 11 at Module 001c03/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 12 at Module 001c04/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 13 at Module 001c04/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 14 at Module 001c04/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 15 at Module 001c04/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Main memory size: 32768 Mbytes
Memory at Module 001c04/Slot 0: 8192 MB (enabled)
ROUTER in Module 001c02/Slot 0: Revision 1: Active Ports [2,3,4,5,] (enabled)
  CDROM: unit 0 on SCSI controller 9
Integral SCSI controller 21: Version IDE (ATA/ATAPI) IOC4
  Disk drive: unit 1 on SCSI controller 10 (unit 1)
  Disk drive: unit 2 on SCSI controller 10 (unit 2)
Integral SCSI controller 22: Version QL12160, low voltage differential
Integral SCSI controller 23: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty21
IOC3/IOC4 serial port: tty22
IOC3/IOC4 serial port: tty23
IOC3/IOC4 serial port: tty24
IOC3/IOC4 serial port: tty19
IOC3/IOC4 serial port: tty20
Graphics board: V12
Gigabit Ethernet: tg4, module 001c04, PCI bus 1 slot 4
Iris Audio Processor: version MAD revision 1, number 4
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 2
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 1
XT-DIGVID Multi-standard Digital Video: controller 2, unit 2, version 0x0
IOC3/IOC4 external interrupts: 5
HUB in Module 001c04/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c03/Slot n0: Revision 6.210
IP35prom in Module 001c04/Slot n0: Revision 6.210
Now that I have been playing about with the O350s, I really do think these are great SGI boxes.
It is pretty cool being able to go from single chassis with only 1 or 2 CPUs and scale up to 24 CPUs by using Numalink.
The fact that Numalink is still alive with HPE products is a testament to the quality of the original design.
As "personal" SGI box Octane is still my favourite, but as modular server the O350 is pretty damn good.
Cheers from Oz,
jwhat.
