320 Visual Workstation dual 1GHz, 512MB
Irinikus
Unread postby Irinikus » Sun Dec 03, 2017 7:09 am
My 320:
Image ... Image Image Image Image Image Image Image Image Image
Image ... Image
Image ... Image
Image ... Image, Image, Image, Image Image ... Image, Image, Image, Image, Image, Image, Image
Image ... Image Image Image ... Image Image
Hombre71
Re: 320 Visual Workstation dual 1GHz, 512MB
Unread postby Hombre71 » Fri Dec 08, 2017 7:06 am
Nice, did you buy it upgraded or did you plonk out for the dual 1ghz yourself?
Unread postby vishnu » Fri Dec 08, 2017 9:35 am
Nice! Those skins are mint... 8-)
Irinikus
Unread postby Irinikus » Fri Dec 08, 2017 10:34 am
Hombre71 wrote:Nice, did you buy it upgraded or did you plonk out for the dual 1ghz yourself?
I bought the system from Ian Mapleson with the two CPU's installed, but without the VRM which I bought from a guy in Germany. (as Ian was all out of VRM's)
Image ... Image
Image ... Image
Irinikus
Unread postby Irinikus » Fri Dec 08, 2017 10:36 am
vishnu wrote:Nice! Those skins are mint... 8-)
It's a neat little machine and definitely one of my favorites. :D
Image ... Image
Image ... Image
GL1zdA
Unread postby GL1zdA » Sun Dec 10, 2017 3:58 am
Nice ;) I see GPU-Z and Sandra on your desktop - do they show anything useful? GPU-Z on old pro graphics hardware usually just returns "unknown architecture". And Sandra crashed often on my VW540, tough I have noted, that the first 2004 version did work (san989.zip).
Have you overclocked it? Because CPU-Z shows 116 MHz FSB and 1160 CPU Clock.
Irinikus
Unread postby Irinikus » Sun Dec 10, 2017 6:15 am
GL1zdA wrote:Have you overclocked it? Because CPU-Z shows 116 MHz FSB and 1160 CPU Clock.
It does appear to be overclocked a little, but this was not intentional.
It does however run stable with these clocks.
Here is some more information on the system:
Here's a picture of the system's internals. It has a 35GB 15K SCSI drive installed:
It played Return to Castle Wolfenstein rather well considering its age:
Image ... Image
Image ... Image
GL1zdA
Unread postby GL1zdA » Sun Dec 10, 2017 12:54 pm
I think it's CPU-Z error to show it as 1160 MHz. PCMark04 shows the right value. On my 540 many programs also report odd clocks.
