I have continued to try various combinations of Onyx 4 chassis’s with V12 & SG2 graphics.
To test that the Onyx 4/G2 (ATI Graphics with no CPUs) is pretty much a standard Chimera, I put a 4x700MHz CPU Processor board from deskside Tezro into the CPU-less G2 chassis. As the G2 has no IO9 board I then numalink'ed it to second 4x1GHz Onyx 4.
To get this up and running I had to do clean IRIX install, as I could not get existing IP35/V12 Graphics boot disk to upgrade to SG2 graphics.
This setup works. So I have have: [Onyx 4/Onyx 4 with V12] combo and [Onyx 4/Onyx 4 with SG2 (Voyager/ATI] combination.
By adding of 4x700MHz CPU board to G2, that makes it an G2N node now (as per "SGI Onyx Next Generation Scalable Graphics Platform User’s Guide" documentation: http://irix7.com/techpubs/007-4634-001.pdf).
Here is hinv / uname / gfxinfo:
# hinv -mv
IP59_4CPU Board: barcode RMB786 part 030-1989-003 rev -D
2U_INT_53 Board: barcode NCA858 part 030-1809-003 rev -B
Location: /hw/module/001c02/IXbrick/xtalk/15/pci-x/0/1/ioc4
IO9 Board: barcode RAD764 part 030-1771-006 rev -A
IP53_4CPU Board: barcode NET662 part 030-1868-001 rev -C
2U_INT_53 Board: barcode NLA195 part 030-1809-006 rev -B
Processor 0: 1.0 GHZ IP35
Processor 1: 1.0 GHZ IP35
Processor 2: 1.0 GHZ IP35
Processor 3: 1.0 GHZ IP35
Processor 4: 700 MHZ IP35
Processor 5: 700 MHZ IP35
Processor 6: 700 MHZ IP35
Processor 7: 700 MHZ IP35
CPU 0 at Module 001c02/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz Tap 0x15
CPU 1 at Module 001c02/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c02/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c02/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c03/Slot 0/Slice A: 700 Mhz MIPS R16000 Processor Chip (enabled)
Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz Tap 0xc
CPU 5 at Module 001c03/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c03/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c03/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Memory at Module 001c02/Slot 0: 4096 MB (enabled)
Bank 0 contains 512 MB (Premium) DIMMS (enabled)
Bank 1 contains 512 MB (Premium) DIMMS (enabled)
Bank 2 contains 512 MB (Premium) DIMMS (enabled)
Bank 3 contains 512 MB (Premium) DIMMS (enabled)
Bank 4 contains 512 MB (Premium) DIMMS (enabled)
Bank 5 contains 512 MB (Premium) DIMMS (enabled)
Bank 6 contains 512 MB (Premium) DIMMS (enabled)
Bank 7 contains 512 MB (Premium) DIMMS (enabled)
Memory at Module 001c03/Slot 0: 4096 MB (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: SG2
Graphics board: SG2
Integral Gigabit Ethernet: tg0, module 001c02, PCI bus 1 slot 4
PCI Adapter ID (vendor 0x1002, device 0x4e47) PCI slot 1
PCI Adapter ID (vendor 0x1002, device 0x4e67) PCI slot 1
IOC4 firmware revision 83
HUB in Module 001c03/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c03/Slot n0: Revision 6.210
# uname -aR
IRIX64 last 6.5 6.5.25f 07080049 IP35
# /usr/gfx/gfxinfo
Graphics board 0 is "SG2" graphics.
Memory Size: 128 MB
Video Output: 1280 pixels, 1024 lines, 75.02Hz (1280x1024)
Graphics board 1 is "SG2" graphics.
Managed (":0.1") 1280x1024
Memory Size: 128 MB
Video Output: 1280 pixels, 1024 lines, 85.02Hz (1280x1024)
I have yet to manage to get V12 or DM3 to work properly in a CPU-less chassic due to issues with FAN speeds, that result in machine shutting down before boot completes. So I have also recorded the l1 env result to try to see what is happening with fans on this test:
001c02-L1>env
Description State Warning Limits Fault Limits Current
1.8V Enabled 10% 1.62/ 1.98 20% 1.44/ 2.16 1.78
12V <not present>
12V #2 Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.32
12V IO Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.06
5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.02
3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.29
PCI 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.02
PCI 3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.32
PCI 2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.50
PCI 5V Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.94
XIO 12V BIAS <not present>
XIO 5V <not present>
XIO 2.5V <not present>
XIO 3.3V AUX <not present>
IP59 3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.29
IP59 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.04
IP59 12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
IP59 VCPU Enabled 10% 1.15/ 1.40 20% 1.02/ 1.53 1.25
IP59 SRAM Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.47
IP59 1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 1.49
Description State Warning RPM Current RPM
FAN 0 EXHST 1 Enabled 2160 2295
FAN 1 EXHST 2 Enabled 2160 2295
FAN 2 PS Enabled 3200 4066
FAN 3 PCI 1 Enabled 2160 2576
FAN 4 PCI 2 Enabled 2160 2836
FAN 5 N0 LEFT Enabled 2160 3125
FAN 6 N0 CNTR Enabled 2160 2884
FAN 7 N0 RIGHT Enabled 2160 3125
Advisory Critical Fault Current
Description State Temp Temp Temp Temp
0 INTERFACE 0 Enabled 31C/ 87F 48C/118F 55C/131F 18C/ 64F
1 INTERFACE 1 Enabled 31C/ 87F 48C/118F 55C/131F 18C/ 64F
2 INTERFACE 2 Enabled 31C/ 87F 48C/118F 55C/131F 23C/ 73F
3 PCI RISER Enabled 31C/ 87F 48C/118F 55C/131F 20C/ 68F
4 ODYSSEY <not present>
5 NODE Enabled 31C/ 87F 48C/118F 55C/131F 20C/ 68F
6 BEDROCK Enabled 31C/ 87F 48C/118F 55C/131F 17C/ 62F
001c03-L1>env
1.8V Enabled 10% 1.62/ 1.98 20% 1.44/ 2.16 1.79
12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.06
12V IO Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.07
3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.25
PCI 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.07
PCI 3.3V Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.30
PCI 2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.51
PCI 5V Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.91
IP53 3.3V AUX Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.23
IP53 5V AUX Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 5.04
IP53 12V Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.00
IP53 VCPU Enabled 10% 1.13/ 1.38 20% 1.00/ 1.50 1.24
IP53 SRAM Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.47
IP53 1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 1.49
FAN 0 EXHST 1 Enabled 2160 3183
FAN 1 PS Enabled 3200 5357
FAN 2 PCI 1 Enabled 1980 2250
FAN 3 PCI 2 Enabled 1980 2445
0 INTERFACE 0 Enabled [Autofan Control] 75C/167F 49C/120F
1 INTERFACE 1 Enabled [Autofan Control] 75C/167F 48C/118F
2 INTERFACE 2 Enabled [Autofan Control] 75C/167F 41C/105F
3 PCI RISER Enabled [Autofan Control] 75C/167F 32C/ 89F
5 NODE Enabled [Autofan Control] 75C/167F 35C/ 95F
6 BEDROCK Enabled [Autofan Control] 85C/185F 61C/141F
Zone Temp Target Current Zone Fan Curr/Min
Zone Name State Sensors Average Average Index Fan %
EXHST Enabled 0,1,2,5,6 47C/116F 46C/114F 0 41%/ 18%
PS Enabled 0,1,2,5,6 47C/116F 46C/114F 1 67%/ 55%
AGP Enabled 3 40C/104F 32C/ 89F 2,3 55%/ 55%
Getting to this stage took quite a long time as I once more went from using IRIX 6.5.21 then updated the up to 6.5.25 to ensure I got SW installed correctly.
I have still not managed to Get V12 or DM3 working in standalone chassis.....
Am thinking now that I will keep Tezro board in the Onyx 4 to make G2N.
Cheers, from Australia.
jwhat.
