Octane R10k 2x250MHz, 256MB, CADduo, GigE
japes
Unread postby japes » Tue Oct 17, 2017 11:45 pm
This is actually the Octane2 chassis I posted about elsewhere. Dug in a little and found the front plane only seems to accept older style motherboards and one particular new style motherboard I had available to test with. Since I had some bad memory there was some swapping going on and the end config is as follows.
The plastics are the new SGI style, but green and labeled Octane, not Octane2. Lightbar currently is stock, and working, incandescent bulbs.
Loaded up with a pair of ESI graphics, Gigabit Ethernet (machine can't keep up with that), and CADduo. The file /usr/lib/X11/xdm/Xservers.2key is in place of /usr/lib/X11/xdm/Xservers setting the workstation up for two interactive desktop logins.
duo250 1# hinv -vm
            PM20 Board: barcode GPD388     part 030-1286-002 rev  B
            IP30 Board: barcode GRT619     part 030-0887-003 rev  M
             FP1 Board: barcode KVH301     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE0230673 part 060-0035-002 rev  A
        XTALKPCI Board: barcode JKK323     part 030-0952-005 rev  E
        PCI_ENET Board: barcode JJM218     part 030-1155-002 rev  D
           MOT10 Board: barcode GSG047     part 030-1241-002 rev  F
           MOT10 Board: barcode GSG105     part 030-1241-002 rev  F
2 250 MHZ IP30 Processors
Heart ASIC: Revision E
Main memory size: 256 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: ESI
Graphics board: ESI
Fast Ethernet: ef1, version 1, pci 1
Gigabit Ethernet: tg1, PCI slot 3
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 1
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 3
I'm not logged in on the second head so board 1 shows unmanaged
duo250 2# /usr/gfx/gfxinfo -v
        VC3 rev A, CMAP rev E, Heart rev E
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
        Unmanaged 1280x1024
        Xvc info not available for unmanaged boards
Users browsing this forum: jollyroger and 3 guests
