Octane EMXI 2xR10000 195MHZ 1GB
Unread postby uunix » Tue Mar 21, 2017 4:49 am
So this machine was a pretty bog standard Octane2 with a 1.3 XBOW. The skins are a bit shabby though I must admit.
Added Digital Video, Fibre Channel (awaiting connectors) and EMXI Graphics, and a new motherboard, since the PS/2 connectors were slack/loose on the old one. This also has a floppy in it.
Hinv
OCTANE02 2# hinv -vm
            PM20 Board: barcode GGB217     part 030-0890-003 rev  H
            IP30 Board: barcode HXY928     part 030-1467-001 rev  B
             FP1 Board: barcode 42452C     part 030-0891-003 rev  E
    PWR.SPPLY.ER Board: barcode AAE9160539 part 060-0035-002 rev  A
           MOT20 Board: barcode HPC357     part 030-1240-003 rev  E
       GALILEO15 Board: barcode HLX484     part 030-0931-004 rev  C
   FIBRE_CHANNEL Board: barcode HPB031     part 030-0927-003 rev  D
2 195 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.3
  Disk drive / removable media: unit 2 on SCSI controller 0: 720K/1.44M floppy
Integral SCSI controller 2: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 3: Version Fibre Channel AIC-1160, revision 2
Graphics board: EMXI
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
Digital Video: unit 1, revision 5.2, TMI: revision 2, CSC: revision 1
GFXINFO
OCTANE02 3# /usr/gfx/gfxinfo
        HQ rev B, GE12 rev A, RE4 rev C, PP1 rev E,
        VC3 rev A, CMAP rev E, Heart rev F
        unknown, assuming 19" monitor (id 0x9)
        Video board present
         Video Output: 1280 pixels, 1024 lines, 72.24Hz (1280x1024_72)
Y888099
Re: Octane EMXI 2xR10000 195MHZ 1GB
Unread postby Y888099 » Tue Mar 21, 2017 5:39 am
I don't get your logical. Why are you collecting so many octane-units? Are you going to build a cluster? Willing to offer a rendering farm service dedicated for Maya? so you make your rendering x hundred times faster?
What's your hidden secret plan?
Unread postby uunix » Tue Mar 21, 2017 5:44 am
World domination.
I've actually only got three working Octanes, it's my build up of o2's that I'm worried about. I seem to be attracting those rather rapidly (6 at last count).
