Mrbill onyx2 deskside #1
MrBill
Unread postby MrBill » Thu Feb 09, 2017 3:26 pm
IRIS 80# hinv -vm
        MODULEID Board: barcode K0028400   part              rev
            IP31 Board: barcode KRJ150     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRT272     part 030-1423-002 rev  G
      4P1G5_MPLN Board: barcode DKA559     part 030-1066-002 rev  J
          GE16-4 Board: barcode GLN976     part 030-1398-001 rev  A
           MSCSI Board: barcode FDZ072     part 030-1243-001 rev  C
             MIO Board: barcode KXT932     part 030-0880-003 rev  G
          BASEIO Board: barcode KYB647     part 030-0734-002 rev  P
2 400 MHZ IP27 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
CPU 0 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Memory at Module 1/Slot 81: 4096 MB (enabled)
  Bank 0 contains 512 MB (Premium) DIMMS (enabled)
  Bank 1 contains 512 MB (Premium) DIMMS (enabled)
  Bank 2 contains 512 MB (Premium) DIMMS (enabled)
  Bank 3 contains 512 MB (Premium) DIMMS (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Integral SCSI controller 4: Version QL1040B (rev. 2), differential
Integral SCSI controller 5: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version QL1040B (rev. 2), differential
Integral SCSI controller 7: Version QL1040B (rev. 2), differential
  Disk drive: unit 5 on SCSI controller 0 (unit 5)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2E
Iris Audio Processor: version RAD revision 7.0, number 1
Origin MSCSI board, module 1 slot 5: Revision 3
  PCI Adapter ID (vendor 0x1077, device 0x1020) PCI slot 2
  PCI Adapter ID (vendor 0x1077, device 0x1020) PCI slot 3
Origin BASEIO board, module 1 slot 1: Revision 4
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
HUB in Module 1/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
Gfxinfo
IRIS 151# /usr/gfx/gfxinfo
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        1 RM9 board (of 1) 1/0/0/0
        Texture Memory: 64MB/-/-/-
        Medium pixel depth
        32K cmap
Re: Mrbill onyx2 deskside #1
Unread postby vishnu » Wed Feb 15, 2017 10:01 pm
I bet it's a thing of beauty! :mrgreen: Pix? :?: :?: :?:
MrBill
Unread postby MrBill » Thu Feb 16, 2017 8:02 pm
vishnu wrote:I bet it's a thing of beauty! :mrgreen: Pix? :?: :?: :?:
Yes.
Unread postby vishnu » Thu Feb 16, 2017 10:14 pm
Wow! :shock:
It really is a thing of beauty... :P
Can I have it? :twisted:
MrBill
Unread postby MrBill » Fri Feb 17, 2017 8:05 pm
vishnu wrote:Wow! :shock:
I spent far to much on it. It just hit me i could have bought a very large van for what i bought it for.... so i think i need to at least hold on to it for the time being. if anything this onyx2 will be the main box and the pyramid of octanes will be the machines on the way out.
