Rackmount Tezro, 2x R16K/1GHz (16MB), 2GB, V10, CDRW, SAS 3800X, QLA12160, Revolution 7.1
mapesdhs
Unread postby mapesdhs » Thu Jan 19, 2017 6:27 pm
My Fuel has served me well, but it was time to move on, sold it for a good price, replaced with a rackmount Tezro with gfx-mod courtesy of the most awesome mopar5150. Here's a picture:
The Fuel had a lot of internal devices, especially storage; these had to be external for the Tezro. With a budget of zero, I made use of an old DLT case and SCSI case to hold two IcyDock units, each with 4x 2.5" bays; these are connected to an LSI SAS3800X. The larger DLT case holds a CDRW aswell, connected to the built-in SCSI port.
Some of the SATA devices are temporary (several 240GB Vertex2Es, V2E for short) while I run tests to determine the best final options (I have a substantial range to test), though I've not yet found any SSD faster than the V2E since all newer SATA3s tend to end up with the wrong link speed with LSI 1030/1060 cards in SGIs, often running at 1.5Gbit instead of 3Gbit.
Not yet connected is a Sony DDS4 to one of the other SCSI ports.
The Fuel had a dual-SSD split file system (root on a 60GB V2E in an ARS-2160H, /usr and /var on a 120GB V2E connected to a SAS3442X-R), but I couldn't use the ARS box in the Tezro as it's the 68pin version, so for the moment the OS has been cloned onto a 146GB 15K. The 120GB is in one of the IcyDocks (DLT case), I'll setup the SSD file system split again once I've sorted out a spare ARS-2160 SCA unit. In the same IcyDock is a 240GB V2E which holds my main user account. The other two bays will eventully hold a two 1TB SSDs (240GB V2E standins just now for testing) which replace a Seagate 600GB 15K SAS (CD dumps/images, OS images, sw archive, etc.) and 1TB Samsung F3 SATA (video archive) I had in the Fuel.
The other IcyDock (in a smaller case on its own) is for backup, containg 120GB and 240GB V2Es for the OS and user account, and two cheaper laptop-type SATA drives for backup of the 1TB SSDs that'll be in the main IcyDock, though one of them is a temp 750GB just for testing and making sure the unit handles the power draw ok
Here's a picture of the rear, which isn't yet finished (couple of blanking plates to fit):
Power to the whole setup is via a radio-controlled switch, so no need to reach fiddly switches at the back of the cases. Now for the obligatory info...
hinv:
2 1.0 GHZ IP35 Processors
Main memory size: 2048 Mbytes
Integral SCSI controller 3: Version SAS/SATA LS1068
  Disk drive: unit 0 on SCSI controller 3
  Disk drive: unit 1 on SCSI controller 3
  Disk drive: unit 2 on SCSI controller 3
  Disk drive: unit 3 on SCSI controller 3
  Disk drive: unit 4 on SCSI controller 3
  Disk drive: unit 5 on SCSI controller 3
  Disk drive: unit 6 on SCSI controller 3
  Disk drive: unit 7 on SCSI controller 3
  CDROM: unit 3 on SCSI controller 1
Integral SCSI controller 5: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: V10
Integral Gigabit Ethernet: tg0, module 001c18, PCI bus 1 slot 4
hinv -vm:
       IP59_2CPU Board: barcode NSC662     part 030-2059-002 rev -B
       ASTODYV10 Board: barcode NAV677     part 030-1826-001 rev -B
       2U_INT_53 Board: barcode NFE417     part 030-1809-004 rev -A
Location: /hw/module/001c18/IXbrick/xtalk/15/pci-x/0/1/ioc4
             IO9 Board: barcode NDZ731     part 030-1771-005 rev -A
CPU 0 at Module 001c18/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
  Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz  Tap 0x15
CPU 1 at Module 001c18/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Memory at Module 001c18/Slot 0: 2048 MB (enabled)
  Disk drive: unit 0 on SCSI controller 3 (unit 0)
  Disk drive: unit 1 on SCSI controller 3 (unit 1)
  Disk drive: unit 2 on SCSI controller 3 (unit 2)
  Disk drive: unit 3 on SCSI controller 3 (unit 3)
  Disk drive: unit 4 on SCSI controller 3 (unit 4)
  Disk drive: unit 5 on SCSI controller 3 (unit 5)
  Disk drive: unit 6 on SCSI controller 3 (unit 6)
  Disk drive: unit 7 on SCSI controller 3 (unit 7)
Graphics board: V10
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
IOC4 firmware revision 79
HUB in Module 001c18/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c18/Slot n0: Revision 6.210
gfxinfo (no need for a V12):
        Managed (":0.0") 1920x1200
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: HWP 9974
         Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
diskpatch -v:
sc0d1l0:  Disk         COMPAQ  BF1468B26B      HPB9  Serial: 3LN0AM12
sc3d0l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d1l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d2l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d3l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d4l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d5l0:  Disk         ATA     Hitachi HTS54101A480  Serial: J8100076
sc3d6l0:  Disk         ATA     OCZ-VERTEX2     1.37  Serial: OCZ
sc3d7l0:  Disk         ATA     Hitachi HTS72757A0D0  Serial: J3740084
To do: mod the fans! Atm the Tezro itself is way too loud, but that's for the future. Also need to rig up the audio.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Y888099
Re: Rackmount Tezro, 2x R16K/1GHz (16MB), 2GB, V10, CDRW, SAS 3800X, QLA12160, Revolution 7.1
Unread postby Y888099 » Fri Jan 20, 2017 8:25 am
mapesdhs wrote:Power to the whole setup is via a radio-controlled switch, so no need to reach fiddly switches at the back of the cases.
More info, please :D
Titox
Unread postby Titox » Fri Jan 20, 2017 11:45 am
We need more pics!!!!
http://www.f3b.es
http://unixverse.blogspot.com
Unread postby vishnu » Fri Jan 20, 2017 3:36 pm
mapesdhs wrote:...a rackmount Tezro with gfx-mod courtesy of the most awesome mopar5150.
That reminds me I got an Onyx4 6x1Ghz/ 16g/ 2x 143g/ V12/ DVD/ m-audio system from the most awesome mopar5150 that I need to post an hinv for. Yes, I just ended that sentence with a preposition... 8-)
mapesdhs
Unread postby mapesdhs » Fri Jan 20, 2017 3:44 pm
I can't take any new pics as it's all setup now, but I did take a few before putting it together (and after the cards went in):
Y888099 asked about power; not much to say really, visually it's just a 4-way 13A mains extension unit, but it comes with a small 5-button radio remote control. Each socket can be individually turned on/off, or the 5th button turns all sockets on/off. The unit uses coded pairing with the remote, so it's possible to setup one remote that controls multiple units, or multiple remotes for a single unit (eg. several family members). The idea is that when I'm not using the system then power is fully off, so no wasted standby power. and then when I do want to use the system I don't have to reach round the back of the boxes since they're a bit hard to get at (my PC oc/benching testing area is in the way). So pressing one button on the remote allows the external units to power up, and meanwhile the Tezro becomes ready. After a few seconds I press the main button on the Tezro.
Not sure if they're sold elsewhere, but in the UK the radio controlled mains extension units were sold by Maplin. They were normally quite expensive, but I bought half a dozen when Maplin suddenly had them in store for half-price, so mine were about 15 UKP each.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
japes
Unread postby japes » Fri Jan 20, 2017 7:04 pm
Keeping the power disconnected when the Tezro/Origin350/Onyx350/IP35 2U wonder machine is probably smart. I noticed if I left the Origin350 in standby something causes one of the environmental sensors to get to/beyond the high temp threshold. I didn't look into it much or don't remember if it was the L1 controller or a PSU - not much besides that in there. It cools off quickly when powered on but registers an alarm and causes the fans to run at high speed right from startup.
What does the Tezro do in your workflow? hold all your IRIX software and network installs I'm guessing. Does it do anything else fun?
EDIT: Hey, is that a SGI logo from a SGI rack door? is that powersupply to power it?
mapesdhs
Unread postby mapesdhs » Sat Jan 21, 2017 9:09 am
japes writes:
> Keeping the power disconnected when the Tezro/Origin350/Onyx350/IP35 2U wonder machine is probably smart. ...
For me it's more about power consumption, practicality, and the visual irritation of a veritable galaxy of LEDs which are annoying when I'm trying to play E.D. :D
Holds my main email archive, all web site data, earlier picture/video archive (newer HD stuff is on a 5GHz PC), disk images, CD images and dumps, and acts as an installation server. Honestly I would use an O2 if it were fast enough, but it's sadly not, and the SSDs do make searching my email archive considerably faster.
Yes and yes. Haven't decided where to put it yet. It was a gift from one of the resellers.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Hombre71
Unread postby Hombre71 » Mon Jan 23, 2017 2:13 pm
Out of interest, can the Tezro (and for that matter the Fuel) boot from Sata? Or do you always still need a ScSi disk for that?
Unread postby uunix » Mon Jan 23, 2017 2:33 pm
Hombre71 wrote:Out of interest, can the Tezro (and for that matter the Fuel) boot from Sata? Or do you always still need a ScSi disk for that?
Must boot from SCSI.
mapesdhs
Unread postby mapesdhs » Mon Jan 23, 2017 3:41 pm
That's why the SSD is inside an ARS-2160 SCSI/SATA bridge box, but /usr and /var come from a SAS card attached LSI, so all accesses to those areas are fast, which normally includes /usr/people aswell, but I have a separate SSD for my user account.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
