Tezro, 4x R16k 800Mhz, 8 GB, V12
irix7
Unread postby irix7 » Fri Dec 30, 2016 11:12 am
Thanks to Doug Mashek http://www.mashek.com I now have an absolutely stunning Tezro system! Like my Fuel, I have it up and running on 6.5.30 with dual 275GB SSDs (using ACARD adaptors). I've wanted one of these for years and years but never found a reason to spend money on one. These really do look better in person (and are smaller) than photos led me to believe. I absolutely love it!
hinv -mv
       IP53_4CPU Board: barcode NJA589     part 030-1956-003 rev -A
       WS_INT_53 Board: barcode NDW520     part 030-1881-007 rev -A
      ODY128B1_2 Board: barcode NCM403     part 030-1884-002 rev -D
             IO9 Board: barcode RBG890     part 030-1771-006 rev -A
4 800 MHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 1 at Module 001c01/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V12
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 3
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 3
IOC4 firmware revision 83
USB controller: type OHCI
/usr/gfx/gfxinfo
        Managed (":0.0") 1920x1200
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -24560
         Video Output: 1920 pixels, 1200 lines, 60.00Hz (1920x1200_60p)
Re: Tezro, 4x R16k 800Mhz, 8 GB, V12
Unread postby uunix » Fri Dec 30, 2016 11:36 am
irix7 wrote:These really do look better in person (and are smaller) than photos led me to believe.
Nice one, and this line really intrigued me, as this has always put me off the Tezro.
[Edit] Can I ask how much you paid for such a machine?
Y888099
Unread postby Y888099 » Sat Dec 31, 2016 2:15 am
irix7 wrote:never found a reason to spend money on one
it sounds like - what are you going to do when you get one ? -
plans ? :D
Unread postby jan-jaap » Sat Dec 31, 2016 5:50 am
irix7 wrote:Thanks to Doug Mashek http://www.mashek.com I now have an absolutely stunning Tezro system! Like my Fuel, I have it up and running on 6.5.30 with dual 275GB SSDs (using ACARD adaptors).
Nice system, congrats!
Any reason you're going for dual ACARD adapters instead of one and a larger SSD? You must have spent more than a grand on the adapters alone.
irix7
Unread postby irix7 » Mon Jan 02, 2017 11:33 am
plans ? :D
I want to archive my software collection but I was finding that CDs were corrupt so I needed a way to test them, also I want to compile/update software packages. Beyond that, I missed the hardware and software I remembered from my past.
irix7
Unread postby irix7 » Mon Jan 02, 2017 11:37 am
Several reasons:
Someday ACARD might not be around or will stop selling these things. I want a few 'spares' just in case.
I like having a second local disk for quick backups/snapshots that I can otherwise leave unmounted. (For between full backups that live elsewhere/not on the same machine.)
I don't need a lot of local storage as I have a fairly beefy NFS server on my network for that.
It seems like 300GB was the largest SCSI disk these systems expected to see, I figure keeping it under that size is a safer bet.
Unread postby jan-jaap » Mon Jan 02, 2017 12:36 pm
irix7 wrote:Someday ACARD might not be around or will stop selling these things. I want a few 'spares' just in case.
OK, makes sense, thanks.
irix7 wrote:It seems like 300GB was the largest SCSI disk these systems expected to see, I figure keeping it under that size is a safer bet.
300GB was the largest parallel SCSI disk produced I think, bigger disks are SAS or SATA. But I expect no issues with disks up to 2TB. IRIX does only supports 32bit LUN numbers so with 512 byte blocks you'll hit a limitation there.
I have 2TB SATA disks in my Origin 350, attached to an LSI HBA, not an ACARD converter. Others have "verified" that 3TB SATA disks could not be 'fx'-ed.
Krokodil
Unread postby Krokodil » Mon Jan 09, 2017 11:17 am
That is quite a nice system you got.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
Unread postby vishnu » Sat Jan 14, 2017 9:22 pm
Very nice! It's kind of de rigueur to post pictures with one's hinv, hint hint... ;)
irix7
Unread postby irix7 » Sun Jan 29, 2017 1:05 pm
vishnu wrote:Very nice! It's kind of de rigueur to post pictures with one's hinv, hint hint... ;)
I didn't know... :)
I've not moved it to its more permanent home yet but when I do I'll post a few photos.
