Origin 350, 4xR16K 700MHz, 2GB
archaic
Unread postby archaic » Fri Dec 23, 2016 7:26 am
I finally unboxed my new Origin 350 system! It is nice to have something new to play with rather than fight with. :)
4 700 MHZ IP35 Processors
Main memory size: 2048 Mbytes
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Patrick
- You have got to be kidding... -
Users browsing this forum: Yahoo [Bot] and 2 guests
