O2+, R12k 400Mhz, 512MB, CRM
Unread postby irix7 » Thu Dec 22, 2016 4:14 pm
My first eBay find, no issues at all since. Swapped the HDD for an ACARD with an SSD (had to use the "force single-ended" jumper to make it work.) Will be used for testing builds/scripts.
I'm using a Startech.com (VGA2HDU) VGA to HDMI adaptor without issue, though it's a bit blurry. The USB power in is apparently unneeded. I also have a Black Box (KVUSB-PS2) PS2 to USB adaptor with an Apple USB keyboard and optical mouse connected. Works fine including 3-button support! So if you have modern peripherals it's possible to connect an O2 to them.
hinv -mv
1 400 MHZ IP32 Processor
Main memory size: 512 Mbytes
Secondary unified instruction/data cache size: 2 Mbytes on Processor 0
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
        32 bitplanes
         Monitor 0 type: HJW 0
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
