O2+ 600Mhz R7k with Synology, LTO4.
khalidschofield
Unread postby khalidschofield » Sat Dec 10, 2016 5:56 am
Finally have the O2 up and running that I've always wanted. The system is in perfect cosmetic condition and I have two O2+ systems. One spare and this one. Sadly only one has the 600Mhz CPU.
ILLU 1# hinv -v
CPU: QED RM7000 Processor Chip Revision: 5.1
FPU: QED RM7000 Floating Point Coprocessor Revision: 5.0
1 602 MHZ IP32 Processor
Main memory size: 1024 Mbytes
Secondary unified instruction/data cache size: 256 Kbytes on Processor 0
Ternary unified instruction/data cache size: 1 Mbyte on Processor 0
Data cache size: 16 Kbytes
FLASH PROM version 4.18
  Tape drive: unit 6 on SCSI controller 1: unknown
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
PCI Fast Ethernet: ec1, 10/100Mb, bus 0, slot 3, id 0x104c, rev 3.0
  PCI Adapter ID (vendor 0x104c, device 0x0500) PCI slot 3
Video: MVP unit 0 version 1.4
Vice: TRE
ILLU 4# /usr/gfx/gfxinfo
        32 + 32 bitplanes
         Monitor 0 type: DEL 28686
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
ILLU 5#
ILLU 6# df -h
Filesystem             Type  Size   use  avail  %use  Mounted on
/dev/root               xfs  931G  143G   789G   16%  /
10.0.0.200:/volume1/khalid     nfs   11T  2.8T   8.0T   27%  /san
ILLU 7# mount
/dev/root on / type xfs (rw,raw=/dev/rroot)
/hw on /hw type hwgfs (rw)
/proc on /proc type proc (rw)
/dev/fd on /dev/fd type fd (rw)
10.0.0.200:/volume1/khalid on /san type nfs (vers=3,rw,proto=tcp,dev=140001)
ILLU 8#
ILLU 8# mt -f /dev/tape status
        Controller: SCSI
        Device: HP: Ultrium 4-SCSI  B63D
        Status: 0x20262
        Drive type: unknown
        Media : READY, writable, at BOT
ILLU 9#
I've got my synology running dropbox and google drive. This is mounted on NFS on the O2 and it back's up everything to the LTO4 drive. IRIX runs fetchmail also to keep a local backup of my gmail account which in turn dumps to tape once in a while. It's about all the use I could think for the system sadly. Suggestions?
Re-install with OpenBSD :)
Re: O2+ 600Mhz R7k with Synology, LTO4.
Unread postby vishnu » Tue Dec 13, 2016 5:00 pm
That is a rare bird indeed, did you do the 600MHz upgrade yourself? Be nice to see what it could do with Maya or Pro/E... :mrgreen:
khalidschofield
Unread postby khalidschofield » Wed Dec 14, 2016 4:53 am
No i bought the system as 600Mhz but I have all the bits plus prom programmer and tonnes of cpu's in my office. If someone wants to have a go at doing the upgrade I'm gain.
Titox
Unread postby Titox » Thu Dec 15, 2016 12:34 pm
ILLU 6# df -h
Wuau!!! 1TB SCSI?
http://www.f3b.es
http://unixverse.blogspot.com
Unread postby vishnu » Thu Dec 15, 2016 2:07 pm
Titox wrote:
ILLU 6# df -h
Wuau!!! 1TB SCSI?
What?! I didn't know they made such things! Who's the manufacturer?
Unread postby jan-jaap » Thu Dec 15, 2016 3:04 pm
vishnu wrote:
Titox wrote:
ILLU 6# df -h
Wuau!!! 1TB SCSI?
AFAIK they didn't. SATA-SCSI adapter and a SATA SSD or laptop disk?
khalidschofield
Unread postby khalidschofield » Fri Dec 16, 2016 12:12 am
Yup an acard sata/ scsi with a Samsung 1tb sad on it. I switched off xfsfsr in crontab to slow the death of thme ssd. Wonder if I should do anything else?
