O2, r7k 350 Mhz, 1 GB, A/V Module
pierocks
Unread postby pierocks » Wed Nov 30, 2016 5:28 pm
After much cleaning and re-seating, two systems and a small handful of spare parts (care of hamei and scutboy) become one. Behold!
dbassett@jolene:~$ hinv -vm
CPU: QED RM7000 Processor Chip Revision: 3.3
FPU: QED RM7000 Floating Point Coprocessor Revision: 2.0
1 350 MHZ IP32 Processor
Main memory size: 1024 Mbytes
Secondary unified instruction/data cache size: 256 Kbytes on Processor 0
Ternary unified instruction/data cache size: 1 Mbyte on Processor 0
Data cache size: 16 Kbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
:O2: :O2: :O2:
Krokodil
Re: O2, r7k 350 Mhz, 1 GB, A/V Module
Unread postby Krokodil » Thu Dec 01, 2016 6:52 pm
That's a nice O2, almost an O2+.
Let me know how the analog a/v module works out. For some reason it doesn't like my VCR, or my N64, but is fine with my DVD player.
Unread postby ClassicHasClass » Fri Dec 02, 2016 12:42 am
Where's the case pr0n? I came here to ogle the case pr0n!
pierocks
Unread postby pierocks » Fri Dec 02, 2016 6:43 am
I will get some snaps, just for you Classic. Also, I have some goodies to forward on to you from Hamei...
:O2: :O2: :O2:
Users browsing this forum: Raion-Fox and 2 guests
