Origin 2400 / Onyx2 SI/MXI
Voralyan
Unread postby Voralyan » Sun Nov 20, 2016 6:08 am
After some years it happened again... - New hardware.
I moved twice in the last years and at some point in time I swore
(while lifting the whole stuff up to the 5th floor (no elevator!), to
be exact) to never get more.
Well... I got an Origin 2400 rack. :lol:
Getting things ready for transport...
Partly assembled after getting it up to the 4th floor this time
(No elevator again, next flat will definitively be at ground level or have an elevator)
Bits and pieces waiting to be installed again
Had to free up some space, my O2100 deskside sits in another corner of the room now.
The cabling needs to be changed, not a nice job as everything is wrapped in these spiral
PE sleeves. But surely it helps to get everything well organized...
First tests, 3 nodeboards in the lower module showed bad RAM, one has occasional CPU
errors. I moved these boards in the deskside for the time being, needs to be examined later.
The four 400 MHz R12k boards from the O2100 are now in the upper module, the lower one has
three 250Mhz and one 300Mhz now.
The MSC board in the upper module had a broken key switch. It was easily fixed with a drip
plastic glue...
Current picture, I haven't decided if I install the "door" thingy again. I think about connecting
it to the deskside to get a 24 CPU system, but I have to find two NUMAlink >= 2 meters first
I installed a SI Impact graphics card I had lying around, making the machine an Onyx2 SI/MXI
hinv follows soon...
(Sorry for the crappy pictures)
:A3502L: :O2000: :O200: = :O200: - :O200: :O200: :Octane: :Octane: :320: :O2: :Indigo2IMP: :Indy:
+ | d | i | g | i | t | a | l | +apple +[...] ;)
Voralyan
Re: Origin 2400 / Onyx2 SI/MXI
Unread postby Voralyan » Sun Nov 20, 2016 6:17 am
Current config:
Boot output:
$ CONSOLES/Origin2400_MMSC
Trying 192.168.1.27...
Connected to 192.168.1.27.
Escape character is '^]'.
 MMSC> pwr u
R1U:ok
R1L:ok
IP27 PROM SGI Version 6.156  built 11:27:56 AM Nov 18, 2003
*** Diag level set to None (2)
Testing/Initializing memory ...............      DONE
Copying PROM code to memory ...............      DONE
Discovering local IO ......................      DONE
Discovering NUMAlink connectivity .........      DONE
Found 12 objects (8 hubs, 4 routers) in 15362 usec
Waiting for peers to complete discovery....      DONE
Recognized 390 MHz midplane
Global master is /hw/module/1/slot/n1
Testing/Initializing all memory ...........      DONE
waiting for node with nic 4d5d39 at module 3 slot 2 at global barrier.....
Checking partitioning information .........      DONE
Loading BASEIO prom .......................      DONE
BASEIO PROM Monitor SGI Version 6.156  built 11:26:28 AM Nov 18, 2003 (BE64)
16 CPUs on 8 nodes found.
Walking SCSI Adapter 0 (/hw/module/1/slot/io1), (pci id 0)
1+ 2- 3- 4- 5- 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 1 device(s)
Walking SCSI Adapter 1 (/hw/module/1/slot/io1), (pci id 1)
Checking hardware inventory ...............              DONE
**** System Configuration and Diagnostics Summary ****
CONFIG:
         No. of NODEs enabled    = 8
         No. of NODEs disabled   = 0
         No. of CPUs enabled     = 16
         No. of CPUs disabled    = 0
         Mem enabled             = 23040 MB
         Mem disabled            = 0 MB
         No. of RTRs enabled     = 4
         No. of RTRs disabled    = 0
DIAG RESULTS:
         NO DIAGS WERE RUN!
System Maintenance Menu
1) Start System
2) Install System Software
3) Run Diagnostics
4) Recover System
5) Enter Command Monitor
Option? 1
                           Starting up the system...
IRIX Release 6.5 IP27 Version 07202013 System V - 64 Bit
Copyright 1987-2006 Silicon Graphics, Inc.
 hinv -mv
        MODULEID Board: barcode K0015528   part              rev
            IP31 Board: barcode GCD995     part 030-1255-003 rev  B
        IP31PIMM Board: barcode HJS680     part 030-1313-002 rev  A
       8P12_MPLN Board: barcode GBY494     part 030-0762-006 rev  K
        IP31PIMM Board: barcode DLE906     part 030-1313-002 rev  A
            IP31 Board: barcode GFD231     part 030-1255-003 rev  B
            IP31 Board: barcode JHH671     part 030-1255-004 rev  A
     IP31PIMM8MB Board: barcode JGV418     part 030-1401-003 rev  A
            IP31 Board: barcode JGY884     part 030-1255-003 rev  D
        IP31PIMM Board: barcode GFC040     part 030-1313-002 rev  A
      ROUTER_IR1 Board: barcode HMA614     part 030-0841-003 rev  B
      ROUTER_IR1 Board: barcode HMA650     part 030-0841-003 rev  B
         PCI_XIO Board: barcode GFS776     part 030-1062-002 rev  D
        PCI_ENET Board: barcode JHX727     part 030-1155-002 rev  D
    HIPPI_SERIAL Board: barcode JHV649     part 030-0968-004 rev  F
          BASEIO Board: barcode HJZ626     part 030-1124-002 rev  M
        MODULEID Board: barcode K0018076   part              rev
       8P12_MPLN Board: barcode DFC471     part 030-0762-006 rev  K
   IP31PIMMR12KS Board: barcode KRH959     part 030-1423-002 rev  G
            IP31 Board: barcode KSB420     part 030-1523-001 rev  C
            IP31 Board: barcode KSB458     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRH935     part 030-1423-002 rev  G
            IP31 Board: barcode KSB421     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRH853     part 030-1423-002 rev  G
            IP31 Board: barcode KSB362     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRH933     part 030-1423-002 rev  G
      ROUTER_IR1 Board: barcode HMA748     part 030-0841-003 rev  B
      ROUTER_IR1 Board: barcode HAM262     part 030-0841-003 rev  B
            GM10 Board: barcode FSK904     part 030-0938-003 rev  T
          BASEIO Board: barcode GND369     part 030-1124-002 rev  M
Processor 0: 250 MHZ IP27
FPU: MIPS R10010 Floating Point Chip Revision: 3.4
Processor 1: 250 MHZ IP27
Processor 2: 250 MHZ IP27
Processor 3: 250 MHZ IP27
Processor 4: 300 MHZ IP27
CPU: MIPS R12000 Processor Chip Revision: 2.5
FPU: MIPS R12010 Floating Point Chip Revision: 2.5
Processor 5: 300 MHZ IP27
Processor 6: 250 MHZ IP27
Processor 7: 250 MHZ IP27
Processor 8: 400 MHZ IP27
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
Processor 9: 400 MHZ IP27
Processor 10: 400 MHZ IP27
Processor 11: 400 MHZ IP27
Processor 12: 400 MHZ IP27
Processor 13: 400 MHZ IP27
Processor 14: 400 MHZ IP27
Processor 15: 400 MHZ IP27
CPU 0 at Module 1/Slot 1/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 2/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 4 at Module 1/Slot 3/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.5. Scache: Size 8 MB Speed 200 Mhz  Tap 0xa
CPU 5 at Module 1/Slot 3/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 6 at Module 1/Slot 4/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 7 at Module 1/Slot 4/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 8 at Module 3/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 9 at Module 3/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 10 at Module 3/Slot 2/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 11 at Module 3/Slot 2/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 12 at Module 3/Slot 3/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 13 at Module 3/Slot 3/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 14 at Module 3/Slot 4/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 15 at Module 3/Slot 4/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 23040 Mbytes
Memory at Module 1/Slot 1: 2048 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
  Bank 1 contains 256 MB (Standard) DIMMS (enabled)
  Bank 2 contains 256 MB (Standard) DIMMS (enabled)
  Bank 3 contains 256 MB (Standard) DIMMS (enabled)
  Bank 4 contains 256 MB (Standard) DIMMS (enabled)
  Bank 5 contains 256 MB (Standard) DIMMS (enabled)
  Bank 6 contains 256 MB (Standard) DIMMS (enabled)
  Bank 7 contains 256 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 2: 2048 MB (enabled)
Memory at Module 1/Slot 3: 2048 MB (enabled)
Memory at Module 1/Slot 4: 1024 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 128 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
  Bank 4 contains 128 MB (Standard) DIMMS (enabled)
  Bank 5 contains 128 MB (Standard) DIMMS (enabled)
  Bank 6 contains 128 MB (Standard) DIMMS (enabled)
  Bank 7 contains 128 MB (Standard) DIMMS (enabled)
Memory at Module 3/Slot 1: 3584 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Memory at Module 3/Slot 2: 4096 MB (enabled)
Memory at Module 3/Slot 3: 4096 MB (enabled)
Memory at Module 3/Slot 4: 4096 MB (enabled)
ROUTER in Module 1/Slot 2: Revision 2: Active Ports [1,2,4,5,6] (enabled)
ROUTER in Module 1/Slot 4: Revision 2: Active Ports [1,2,4,5,6] (enabled)
ROUTER in Module 3/Slot 2: Revision 2: Active Ports [1,2,4,5,6] (enabled)
ROUTER in Module 3/Slot 4: Revision 2: Active Ports [1,2,4,5,6] (enabled)
Integral SCSI controller 4: Version Fibre Channel QL2200A, 33 MHz PCI
Integral SCSI controller 2: Version QL1040B (rev. 2), single ended
Integral SCSI controller 3: Version QL1040B (rev. 2), single ended
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: SI
Gigabit Ethernet: tg1, module 1, PCI bus 0 slot 0 port 0
Gigabit Ethernet: tg2, module 1, PCI bus 0 slot 0 port 1
HIPPI-Serial adapter: unit 0, in module 1 I/O slot 7
Fast Ethernet: ef2, version 1, module 3, slot io1, pci 2
Fast Ethernet: ef1, version 1, module 1, slot io2, pci 2
Origin PCI XIO board, module 1 slot 2: Revision 3
  PCI Adapter ID (vendor 0x14e4, device 0x1648) PCI slot 0
  PCI Adapter ID (vendor 0x1077, device 0x2200) PCI slot 1
Origin BASEIO board, module 3 slot 1: Revision 4
Origin BASEIO board, module 1 slot 1: Revision 4
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 1
HUB in Module 1/Slot 3: Revision 5 Speed 100.00 Mhz (enabled)
HUB in Module 1/Slot 4: Revision 5 Speed 100.00 Mhz (enabled)
HUB in Module 3/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 3/Slot 2: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 3/Slot 3: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 3/Slot 4: Revision 6 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n3: Revision 6.156
IP27prom in Module 1/Slot n4: Revision 6.156
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
IP27prom in Module 3/Slot n1: Revision 6.156
IP27prom in Module 3/Slot n2: Revision 6.156
IP27prom in Module 3/Slot n3: Revision 6.156
IP27prom in Module 3/Slot n4: Revision 6.156
$ /usr/gfx/gfxinfo -v
        VC3 rev A, CMAP rev E
        unknown, assuming 19" monitor (id 0xd)
Voralyan
Unread postby Voralyan » Sun Nov 20, 2016 6:22 am
Power consumption:
Unread postby uunix » Sun Nov 20, 2016 6:47 am
Awesome!!
Noisy?
Krokodil
Unread postby Krokodil » Sun Nov 20, 2016 9:47 am
That is quite a beast you have acquired.
Unread postby vishnu » Sun Nov 20, 2016 9:43 pm
Wow wow wow! :shock: :shock: :shock:
Unread postby jan-jaap » Mon Nov 21, 2016 3:03 am
Dr. Dave wrote:Once you step up to the big iron, you learn all about physics, electrical standards, and first aid - usually all in the same day
Nice catch :)
computron
Unread postby computron » Tue Nov 22, 2016 4:49 am
My previous O2k rack was quietter than my Proliant at start !!!
Cheers
Eve
duck
Unread postby duck » Tue Nov 22, 2016 8:40 am
Damn it, I'm jealous now.
___(o)=
\____)
Voralyan
Unread postby Voralyan » Tue Nov 22, 2016 2:40 pm
Yes, the noise level is quite bearable, as long fastfan mode is not active.
Which will happen sooner or later when the rooms heats up. Usually fastfan
is first activated on the upper module as the warm air collects under the
ceiling. Often the lower module stays "quiet" for another half to one hour.
I'm just going through the remaining nodeboards as I got a replacement PSU
for the deskside (many thanks to jan-jaap). I revived 3 of them, one of them
had a mysterious oily substance in the RAM sockets. Maybe some sort of contact
cleaner.
I have one left with problems on CPU A:
*** General Exception on node 1
*** EPC: 0x00000001fc388bc (0x00000001fc388bc)
*** Press ENTER to continue
(typed from screen, no network on the serial console notebook)
I plan to connect the deskside to the rack to build a 24 CPU system :-)
Kotomo
Unread postby Kotomo » Thu Nov 24, 2016 3:31 pm
This is beautiful. It's fantastic! Wonderful find.
I cannot imagine having all this in a flat and hauling all that up 4 flights of steps. Props to you.
Also, I've heard about dropping SI Graphics into an Origin 2000 series, haven't read up anything yet or got around to attempting it myself. I take it it's somewhat plug and play?
:Octane: :Octane: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :O2: :O2: :O2: :O2000: :O2000:
