Fuel V12 R16k 700Mhz 1.5GB
Kotomo
Unread postby Kotomo » Mon Nov 07, 2016 3:03 pm
The Fuel in my collection that I recently setup at my main work desk. I have dreams and aspirations to learn 3D modeling and animation. My *cough* Windows gamer desktop is more than capable. Just an SGI workstation to play around with the past intrigues me.
It's named Taokaka, because I gotta name one of my machines after a Catgirl.
hinv -vm output:
            IP34 Board: barcode MSZ166     part 030-1707-003 rev -H
        IP34PIMM Board: barcode MSY421     part 030-1891-001 rev -D
          ASTODY Board: barcode MSK322     part 030-1726-003 rev -E
1 700 MHZ IP35 Processor
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xa
Main memory size: 1536 Mbytes
Memory at Module 001c01/Slot 0: 1536 MB (enabled)
  Bank 2 contains 256 MB (Standard) DIMMS (enabled)
  Bank 3 contains 256 MB (Standard) DIMMS (enabled)
Graphics board: V12
  PCI Adapter ID (vendor 0x1102, device 0x0002) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x7002) PCI slot 2
USB controller: type OHCI
/usr/gfx/gfxinfo putput:
   Managed (":0.0") 1920x1200
   BUZZ version B.1
   PB&J version 1
   128MB memory
      Banks: 4, CAS latency: 3
   Compositor port 1 attached to channel 0 nic 0x1004a768
    Monitor 0 type: DEL 16437
    Video Output: 1920 pixels, 1200 lines, 60.00Hz (1920x1200_60p)
:Octane: :Octane: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :O2: :O2: :O2: :O2000: :O2000:
Re: Fuel V12 R16k 700Mhz 1.5GB
Unread postby uunix » Mon Nov 07, 2016 3:46 pm
Beautiful man.. just beautiful..
Kotomo
Unread postby Kotomo » Mon Nov 07, 2016 7:53 pm
Thanks!
Don't mind my scuff marks.
Unread postby Trippynet » Tue Nov 08, 2016 1:23 am
Nice little system! When it runs properly, the Fuel is a good system. It's just that they can be a bit flimsy and finicky at times...
s0ke
Unread postby s0ke » Tue Nov 08, 2016 6:26 am
Very finicky
:Fuel: REFUSE
R16K 700: 2GB: V10: Noctua Fans
Unread postby ClassicHasClass » Tue Nov 08, 2016 7:57 am
Sexy red!
A little gentle buffing on the front and some wax pencils might be able to reduce those marks.
Kotomo
Unread postby Kotomo » Wed Nov 09, 2016 11:57 am
ClassicHasClass wrote:Sexy red!
Thanks for the tip.
I have a feeling this machine did not see a whole lot of use in it's day. It was very clean inside when I got it. Knock on wood.
