Origin 2000 2xR12k 400MHz 4xR12k 300MHz 6GB
Kotomo
Unread postby Kotomo » Thu Nov 03, 2016 8:19 pm
One of the Origin 2000's I have that I got working and Irix installed on to. It only has 3 node boards, no other add-ins. Power supply sometimes fails on first power up, but generally seems to be working. For now. It is unfortunately, skinless. For rescuing it from being recycled, I'd say it's a good deal.
I named it Navi, because Serial Experiments Lain is one of my obsessions.
hinv -vm output:
        MODULEID Board: barcode K0011550   part              rev
   IP31PIMMR12KS Board: barcode KHN336     part 030-1423-002 rev  F
       8P12_MPLN Board: barcode FLC907     part 013-1547-003 rev  E
            IP31 Board: barcode JZT602     part 030-1523-001 rev  C
            IP31 Board: barcode JEC171     part 030-1255-003 rev  D
     IP31PIMM8MB Board: barcode JDZ187     part 030-1401-002 rev  B
            IP31 Board: barcode JEE044     part 030-1255-003 rev  D
     IP31PIMM8MB Board: barcode JHG652     part 030-1401-002 rev  B
      ROUTER_IR1 Board: barcode HKR136     part 030-0841-003 rev  B
      ROUTER_IR1 Board: barcode KWM519     part 030-0841-003 rev  C
          BASEIO Board: barcode GAT862     part 030-1124-002 rev  J
Processor 0: 400 MHZ IP27
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
Processor 1: 400 MHZ IP27
Processor 2: 300 MHZ IP27
Processor 3: 300 MHZ IP27
Processor 4: 300 MHZ IP27
Processor 5: 300 MHZ IP27
CPU 0 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 8 MB Speed 200 Mhz  Tap 0xa
CPU 3 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 4 at Module 1/Slot 3/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 5 at Module 1/Slot 3/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 6144 Mbytes
Memory at Module 1/Slot 1: 2048 MB (enabled)
Memory at Module 1/Slot 2: 2048 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 128 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 4 contains 128 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 3: 2048 MB (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
  Bank 5 contains 128 MB (Standard) DIMMS (enabled)
ROUTER in Module 1/Slot 2: Revision 2: Active Ports [3,4,5,6] (enabled)
ROUTER in Module 1/Slot 3: Revision 2: Active Ports [3,5,6] (enabled)
HUB in Module 1/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 1/Slot 3: Revision 5 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n3: Revision 6.156
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
The front:
The Back:
:Octane: :Octane: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :O2: :O2: :O2: :O2000: :O2000:
smj
Re: Origin 2000 2xR12k 400MHz 4xR12k 300MHz 6GB
Unread postby smj » Fri Nov 04, 2016 5:36 am
Kotomo wrote:One of the Origin 2000's I have that I got working and Irix installed on to. It only has 3 node boards, no other add-ins.
A fine machine for experiencing the server-side of IRIX, and when you get the other O2k running you might want to try using the CRAYlink/NUMAlink to operate them as a single system.
Kotomo wrote:I named it Navi, because Serial Experiments Lain is one of my obsessions.
One of my favorites too!
Unread postby jan-jaap » Fri Nov 04, 2016 5:41 am
I think I recognize a Compaq 19" rack. I have essentially the same, but in dark grey and with an HP badge.
Kotomo
Unread postby Kotomo » Fri Nov 04, 2016 6:24 am
jan-jaap wrote:I think I recognize a Compaq 19" rack. I have essentially the same, but in dark grey and with an HP badge.
Yes, that's exactly what it is. It's an eBay Special, 42U Compaq rack. My pFSense router, Storage server, VMware ESXi box, and home laser printer are housed in it.
Unread postby jan-jaap » Fri Nov 04, 2016 7:12 am
I pulled mine out of some guys horse stable I think. Been a while. Some photos HERE and HERE.
Since those photos I upgraded the SAN switch to a Brocade 5000 and moved to a new 2U (rack mounted) server.
One of the things I like best about this setup is the rack mounted PDU which allows me to switch things on and off remotely. Not only does this keep power consumption reasonable, it also means I can push the rack into a corner without having to worry about not being able to reach things.
Kotomo
Unread postby Kotomo » Fri Nov 04, 2016 11:34 am
jan-jaap wrote:I pulled mine out of some guys horse stable I think. Been a while. Some photos HERE and HERE.
Awesome setup! I am particularly fond of the space you have for everything. Looks cozy and welcoming. I'm still working in my dark basement which I fully intend to refinish and make more livable. Possibly when I'm done grad school.
Dodoid
Unread postby Dodoid » Fri Nov 04, 2016 11:39 am
Jan-jaap's pictures are making me want to clean up my lab. and stop cramming all the SGIs in a corner.
and a small army of Image
archaic
Unread postby archaic » Fri Nov 11, 2016 8:32 am
I see you have the express link adapter on the node boards. Nice. It is so much better than having to have a NUMALink cable to enable that functionality.
Patrick
- You have got to be kidding... -
Kotomo
Unread postby Kotomo » Mon Nov 14, 2016 8:45 am
Yes, that was highly convenient. Both my Origins came with two router boards and the express link adapter. So yaaaaay!
