O2, R12000, 270MHz, 256MB
zuc
Unread postby zuc » Mon Oct 10, 2016 3:01 pm
Another fantastic eBay score ($130 US), *nearly* intact skins - I think the one crack that's appearing on the side is my own fault, but it's just starting to form and it's invisible without close inspection. Powered up fine, installed IRIX through the LAN with no problems:
hinv -v
1 270 MHZ IP32 Processor
Main memory size: 256 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
  PCI Adapter ID (vendor 0x104c, device 0x8009) PCI slot 3
Video: MVP unit 0 version 1.4
Vice: TRE
gfxinfo -v
        32 bitplanes
         Monitor 0 type: SAM 277
manxome 4% cat /tmp/gfxinfo
        32 bitplanes
         Video Output: 1280 pixels, 1024 lines, 75.03Hz (1280x1024_75)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
:Indy: Indy - (indy) - R4600 - 133MHZ - 128MB RAM - 6.5.22
:Indy: Indy - (mimsy) - R4600 - 133MHZ - 160MB RAM - 6.5.22
:Indy: Challenge S (WIP)
:Indigo2IMP: Indigo2 - (indigo2) - R4400 - 200MHZ - 128MB RAM - 6.5.22
:Octane: Octane - (octane) - R12K - 2X300MHZ - 640MB RAM - EMXI+4TRAMs - 6.5.30
:Octane: Octane - (petrol) - R12K - 1X300MHZ - 1.5GB RAM - 6.5.30
:O2: O2 - (manxome) - R12K - 270MHZ - 256MB RAM - 6.5.30
SPARCstation 4 - (sparcstep) - MicroSparc - 85MHZ - 32MB RAM - NeXTSTEP 3.3
SPARCstation 5 - (sparc5) - MicroSparc - 85MHZ - 128MB RAM - Solaris 8
SPARCstation 20 - (sparc20) - HyperSparc - 2X125MHZ+1X160MHZ - 512MB RAM - Solaris 9
Sun Ultra 5 - (ultrasol) - UltraSparc - 333MHZ - 128MB RAM - Solaris 8
NeXTStation Turbo Color - (blackhole) - m68040 - 33MHZ - 80MB RAM - NEXTSTEP 3.3
Krokodil
Re: O2, R12000, 270MHz, 256MB
Unread postby Krokodil » Wed Nov 16, 2016 6:52 pm
Not bad specs for an O2.
Dodoid
Unread postby Dodoid » Fri Nov 18, 2016 10:33 am
That's really impressive for an O2 full stop, letalone for $130. Video input card, lots of RAM, R12k, good condition, what looks like FireWire or AudioWire. Nice machine. Wonder why I didn't spot that for sale, might have tried to buy it...
and a small army of Image
