Indigo2 R8000 75MHz 512MB Extreme
luaman
Unread postby luaman » Thu Sep 22, 2016 3:52 am
pretty average Power Indigo2...
1 75 MHZ IP26 Processor
CPU: MIPS R8000 Processor Chip Revision: 2.2
FPU: MIPS R8010 Floating Point Chip Revision: 0.1
On-board serial ports: 2
Data cache size: 16 Kbytes
Main memory size: 512 Mbytes
EISA bus: adapter 0
  Disk drive: unit 3 on SCSI controller 1
Graphics board: GU1-Extreme
   8 GEs, 2 REs, 24 bitplanes, 4 auxplanes, 4 cidplanes, Z-buffer
   GR2 revision 6, VB2.0
   HQ2.1 rev A, GE7 rev B,  RE3.1 rev A, VC1 rev B, MC rev D
   unknown, assuming 19" monitor
screenshot evidence:
Re: Indigo2 R8000 75MHz 512MB Extreme
Unread postby jan-jaap » Thu Sep 22, 2016 4:24 am
Nice, and with lots of RAM. And "average" is hardly the first that comes to mind when you're talking about *any* R8000 system.
Unread postby dexter1 » Thu Sep 22, 2016 4:27 am
Welcome to the R8K club, luaman :)
jpstewart
Unread postby jpstewart » Thu Sep 22, 2016 11:58 am
jan-jaap wrote:And "average" is hardly the first that comes to mind when you're talking about *any* R8000 system.
I was going to say the same thing. That's a very nice system, and from an apparent newcomer to the forums. What a great way to start! Congrats!
HP C8000
Unread postby Trippynet » Fri Sep 23, 2016 4:26 am
I agree with the above. That's a pretty rare system, and very nicely specced as well with that much RAM.
luaman
Unread postby luaman » Fri Sep 23, 2016 11:08 am
By the way it runs IRIX 6.2 off of an external drive since my drive sled literally fell apart (don't ask). And the IRIX install is partially broken due to the network (or something to do with the network), as it always complains that amsysinfo can't find the hostname... other than that it works fine.
And said external drive is meant for a Sun computer *gasp* but it was the only SCSI device I had. :lol:
Ryan Fox
Unread postby Ryan Fox » Thu Sep 29, 2016 12:29 am
Its a R8000! Finding one these days that still works is almost impossible. Very very finicky system. ESD will kill the CPU if you're not careful when handling it.
MAYA, nut-
