CPU: MIPS R5000 Processor Chip Revision: 10.0
FPU: MIPS R5000 Floating Point Coprocessor Revision: 10.0
1 300 MHZ IP32 Processor
Main memory size: 896 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
Presenter adapter board and display.
32 + 32 bitplanes
Monitor 0 type: Unknown
Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60p]
