Indy Newport R4600PC 100MHz 64MB
Geoman
Unread postby Geoman » Sat Sep 17, 2016 4:51 pm
don't click - size as preview
IRIS 1# hinv -v
Iris Audio Processor: version A2 revision 4.1.0
1 100 MHZ IP22 Processor
FPU: MIPS R4610 Floating Point Chip Revision: 0.0
CPU: MIPS R4600 Processor Chip Revision: 1.0
On-board serial ports: 2
Data cache size: 16 Kbytes
Main memory size: 64 Mbytes
Integral Ethernet: ecO, version 1
Graphics board: Indy 8-bit
Vino video: unit 0, revision 0, IndyCam connected
IRIS 2# usr/gfx/gxinfo
Graphics board 0 is "NG1" graphics.
        8 bitplanes, NG1 revision 3, REX3 revision B, VC2 revision A
        MC revision C, xmap9 revision A, cmap revision C, bt445 revision A
        Display 1280x1024 @ 72Hz, monitor id 11
The IndyCam reacts realtime-ish and the video image looks great despite being only 256 colors.
I installed IRIX 6.5, which took 2 hours to install and 5 minutes to boot.
Then I installed IRIX 5.3, which took 20 minutes and 1 minute to boot. IRIX 5.3 FTW. Everything runs fast and opens quick. Not missing that 2nd level cache that much.
But then 8bit GFX, OH GOD WHY SGI ?? Why not at least 32768/15bit? 8bit GFX is ugly as hell. This thing needs 24-bit XL.
Re: Indy Newport R4600PC 100MHz 64MB
Unread postby ClassicHasClass » Sun Sep 18, 2016 11:12 pm
Still, nice skins. Needs moar RAM tho. ;)
Geoman
Unread postby Geoman » Mon Sep 19, 2016 11:17 am
ClassicHasClass wrote:Still, nice skins. Needs moar RAM tho. ;)
Thanks!
Yes, that's true.
